discourse-ai 플러그인에서 게시글 임베딩이 제대로 잘리지 않습니다
관련 게시물 매칭에 OpenAI의 ADA 텍스트 임베딩 모델을 사용할 때 다음과 같은 오류가 발생합니다:
OpenAI Embeddings failed with status: 400 body: { "error": { "message": "This model's maximum context length is 8191 tokens, however you requested 19370 tokens (19370 in your prompt; 0 for the c
/var/www/discourse/plugins/discourse-ai/lib/shared/inference/openai_embeddings.rb:24:in `perform!'
/var/www/discourse/plugins/discourse-ai/lib/modules/embeddings/models/text_embedding_ada_002.rb:37:in `generate_embeddings'
/var/www/discourse/plugins/discourse-ai/lib/modules/embeddings/manager.rb:22:in `generate!'
/var/www/discourse/plugins/discourse-ai/lib/modules/embeddings/jobs/regular/generate_embeddings.rb:14:in `execute'
/var/www/discourse/app/jobs/base.rb:292:in `block (2 levels) in perform'
rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:82:in `with_connection'
/var/www/discourse/app/jobs/base.rb:279:in `block in perform'
/var/www/discourse/app/jobs/base.rb:275:in `each'
/var/www/discourse/app/jobs/base.rb:275:in `perform'
sidekiq-6.5.9/lib/sidekiq/processor.rb:202:in `execute_job'
sidekiq-6.5.9/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
sidekiq-6.5.9/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:134:in `call'
sidekiq-6.5.9/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
sidekiq-6.5.9/lib/sidekiq/middleware/chain.rb:182:in `invoke'
sidekiq-6.5.9/lib/sidekiq/processor.rb:169:in `block in process'
sidekiq-6.5.9/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
sidekiq-6.5.9/lib/sidekiq/job_retry.rb:113:in `local'
sidekiq-6.5.9/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
sidekiq-6.5.9/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
sidekiq-6.5.9/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
sidekiq-6.5.9/lib/sidekiq/processor.rb:263:in `stats'
sidekiq-6.5.9/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
sidekiq-6.5.9/lib/sidekiq/job_logger.rb:13:in `call'
sidekiq-6.5.9/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
sidekiq-6.5.9/lib/sidekiq/job_retry.rb:80:in `global'
sidekiq-6.5.9/lib/sidekiq/processor.rb:124:in `block in dispatch'
sidekiq-6.5.9/lib/sidekiq/job_logger.rb:39:in `prepare'
sidekiq-6.5.9/lib/sidekiq/processor.rb:123:in `dispatch'
sidekiq-6.5.9/lib/sidekiq/processor.rb:168:in `process'
sidekiq-6.5.9/lib/sidekiq/processor.rb:78:in `process_one'
sidekiq-6.5.9/lib/sidekiq/processor.rb:68:in `run'
sidekiq-6.5.9/lib/sidekiq/component.rb:8:in `watchdog'
sidekiq-6.5.9/lib/sidekiq/component.rb:17:in `block in safe_thread'
게시물을 잘라야 할 수도 있습니다.
4개의 좋아요
리포트해 주셔서 감사합니다. 확인해 보겠습니다.
다행히도, 특정 토큰 수까지 단어 모음을 잘라낼 수 있는 메서드가 있습니다.
4개의 좋아요
좋아요! 감사합니다.
1개의 좋아요
다음 링크에 따라 이제 이 문제가 수정되었을 것 같습니다:
6개의 좋아요
알겠습니다. :+1: :muscle:
3개의 좋아요
이 주제는 3일 후 자동으로 닫혔습니다. 새로운 답변은 더 이상 허용되지 않습니다.
