Inbedding Post: Kan CSS Selectors niet lezen van React Site
Aaron_B is experiencing issues with embedding posts from a React site using Discourse, as the CSS selectors are not being picked up by the crawler. simon suggests that the issue may be due to Discourse caching content for 10 minutes, and provides additional details about the allowed embed selectors setting. pfaffman notes that Discourse presents a different view to crawlers, and simon provides the code used for pulling in external posts and suggests testing it in the Rails console to troubleshoot the issue. Aaron_B clarifies that the issue is with how Discourse crawls his React site, and simon offers to help debug the issue.
I have CSS tags on my content and have identified the CSS Selectors in the embedding admin settings but they are not being picked up by the crawler. I believe it is because my site is built with React and the css selectors are not accessible. How can I use this feature with a React site?
That may be the case although I’d expect the request that Discourse makes to the site to return HTML. Something else to look into is that Discourse caches the content that it’s pulled from the external site for 10 minutes. That means that if you are adjusting the allowed embed selectors site setting, you’ll have to wait up to 10 minutes to see the results of the new setting value.
If your Discourse site isn’t yet in production and you have access to the Discourse site’s Rails console, you can clear the cache from the console with Rails.cache.clear
Some additional details about the setting are here: Configuring allowed embed selectors.
Edit: I think that embedding is working as expected. It’s just tricky to configure for some sites. I’m going to move this topic to Support.
I created a Contribute > Feature topic a few months ago suggesting that Discourse should find a better way of parsing embedded posts: Topic embedding needs some love. I’ll put some time into that soon if no one gets to it before me.
Discourse presents a different view to crawlers. To see it you’ll need to visit with javascript turned off.
I would not expect embedded posts to be crawled since they do not exist on the site where they are embedded.
Hello, I’m referring to how Discourse crawls my React site with the embedded posts feature. I’m having a hard time telling it what content to include on the Discourse post because of how it sees my React page.
It it helps, the code that’s used for pulling in the external post is here: discourse/app/models/topic_embed.rb at main · discourse/discourse · GitHub
If you have access to your site’s Rails console, you can test it to get some idea of what’s going on. For example:
TopicEmbed.find_remote("https://blog.discourse.org/2023/04/introducing-discourse-ai/")
Where I’ve run into problems is with the parse_html method that’s called at the end of the find_remote method. Ruby Readability struggles with some HTML/CSS.
It’s also possible that HTML isn’t being returned from your React site. You could confirm that by running the code that’s in the find_remote method in steps from the console.
This is excellent, thank you!
