Error 1
Job exception: No inference endpoint configured
| hostname | vmi1371983-app |
| process_id | 3544209 |
| application_version | d178d75e1e05d7c2b137b167cab45cac838e1f73 |
| current_db | default |
| current_hostname | dex-forum.com |
| job | Jobs::EmbeddingsBackfill |
| problem_db | default |
| time | 6:51 pm |
| opts | |
| /var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/bge_large_en.rb:24:in `vector_from’ | |
| /var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:145:in `generate_representation_from’ | |
| /var/www/discourse/plugins/discourse-ai/app/jobs/scheduled/embeddings_backfill.rb:31:in `block in execute’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:71:in `each’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:71:in `block in find_each’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:138:in `block in find_in_batches’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:245:in `block in in_batches’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:229:in `loop’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:229:in `in_batches’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:137:in `find_in_batches’ | |
| activerecord-7.0.8/lib/active_record/relation/batches.rb:70:in `find_each’ | |
| /var/www/discourse/plugins/discourse-ai/app/jobs/scheduled/embeddings_backfill.rb:30:in `execute’ | |
| /var/www/discourse/app/jobs/base.rb:297:in `block (2 levels) in perform’ | |
| rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:82:in `with_connection’ | |
| /var/www/discourse/app/jobs/base.rb:284:in `block in perform’ | |
| /var/www/discourse/app/jobs/base.rb:280:in `each’ | |
| /var/www/discourse/app/jobs/base.rb:280:in `perform’ | |
| /var/www/discourse/app/jobs/base.rb:351:in `perform’ | |
| mini_scheduler-0.16.0/lib/mini_scheduler/manager.rb:122:in `process_queue’ | |
| mini_scheduler-0.16.0/lib/mini_scheduler/manager.rb:70:in `worker_loop’ | |
| mini_scheduler-0.16.0/lib/mini_scheduler/manager.rb:59:in `block (2 levels) in ensure_worker_threads’ |
Error 2 error when trying to load /lastest.json
error 3 Sidekiq is consuming too much memory (using: 523.54M) for ‘dex-forum.com’, restarting
error 4 Deprecation notice: Array types for custom fields are deprecated, use type :json instead (removal in Discourse 3.3.0)
At /var/www/discourse/lib/plugin/instance.rb:580:in block in register_post_custom_field_type
