404 页面未找到时表情符号未显示
On our 404 page not found, I see that :mega doesn’t become the :mega: emoji (see first post).
The calendar emoji on the last post is rendering, but I didn’t use Discourse’s emoji chooser to get that particular emoji.
2 个赞
AFAIK it’s the same reason the markdown links weren’t parsed in the other report you made about the 404 page.
Not quite, I think this should go through the same rendering path for topic titles. Who was the last person to work on 404 page @sam?
I think @techAPJ did but not sure. I am not sure if we even have a server side function to “emojify” a bunch of text, we always do this on the client.
I would not mind getting this fixed but it is fiddly, @j.jaffeux can you think of an easy fix here?
3 个赞
I think that should do it:
https://github.com/discourse/discourse/pull/7802
The following topic title:
FREE to USA Discourse hoster :blush: :man:t2:
Would result in (both unicode and code replaced, and works with skin tones):
6 个赞
Will this be a perf issue? We need to confirm as 404 gets hit a lot, and systematically sometimes.
3 个赞
No this won’t, this page is cached in redis.
Also the lookup wont happen with filesystem, but using the Emoji list which is in memory (redis too).
3 个赞
Merged
