Encrypt plug-in issue
A user reports multiple issues with the Discourse Encrypt plugin: (1) They could read a PM from a transactional email service, which they believed shouldn’t be possible; (2) A new account failed to display the key setup prompt after logout/login, preventing email sending and showing misleading “key already exists” messages; (3) A pre-populated recipient field appeared in new PMs, and they couldn’t navigate to their inbox. The user suspects the first issue relates to their machine being registered to decrypt messages, notes others couldn’t read the same PM, and suggests better warnings are needed for key setup. They also observe an “integrity” message in PMs that disappears after liking. sam clarifies that Discourse Encrypt is deprecated and no longer supported on Meta; any future development requires a third-party plugin maintained in a dedicated topic.
I seem to have an issue with the encryption plug-in seems to be twofold
First I noted I could read a PM from my transactional email service
So I sent that test message to someone who recently just had to reactivate their encryption, they lost their key, so I feel confident they do have it working
It can be read, I didn’t think that was possible
As I had set up a second account today to test a different setting I decided to log into that and send my own
Here’s the second thing
This is whats at the top as expected, new account, alert to set up and save a key pair
As it was a test I didn’t set it up earlier and when I logged in I found
I could not even send an email , so a new user who doesn’t set up their account loses that top notice about keys
When I go to security to set it up
It just reads to activate with the appearance there is a key
click activate and it reads wrong key
So I delete the key I never set up and it reads
Save the key and go back
Still missing the email button
So I decide to send one to that account and find a new PM has me entered to receive already populated, a third issue IMO
I got it but still can’t find a way to navigate to my inbox
As I was logged into both no email was sent to test but is this a bug?
This was solved as a TL0 issue
This I’m thinking is due to my machine being registered to read the PM?
I found others and they could not be read
Seems a better warning needs to be in place on the paper key needing to be set up right away as the forum seems to think you did if you log out and back in, no change
Still an odd thing I don’t understand
And I see this somewhat often which is not understood in the PM’s
integrity
Its odd as soon as you give a like it disappears
Discourse Encrypt has been deprecated we are no longer tracking issues with the plugin on meta.
To move anything forward here a third party plugin will need to be created and maintained (in a dedicated plugin topic)
