I just ran an update and got the following error. Then when I refreshed the page to run it again it showed that the update had already been applied. Any thoughts?
Errno::ENOMEM: Cannot allocate memory - gzip -f -c -7 /var/www/discourse/public/assets/docker-manager-app-5abf141467f1e67d5d860236f75651be.js > /var/www/discourse/public/assets/docker-manager-app-5abf141467f1e67d5d860236f75651be.js.gz
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.6/lib/active_support/core_ext/kernel/agnostics.rb:7:in ``'
/var/www/discourse/lib/tasks/assets.rake:108:in `gzip'
/var/www/discourse/lib/tasks/assets.rake:161:in `block (4 levels) in '
/var/www/discourse/lib/tasks/assets.rake:125:in `call'
/var/www/discourse/lib/tasks/assets.rake:125:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:152:in `call'
/var/www/discourse/lib/tasks/assets.rake:152:in `block (3 levels) in '
/var/www/discourse/lib/tasks/assets.rake:141:in `each'
/var/www/discourse/lib/tasks/assets.rake:141:in `block (2 levels) in '
/var/www/discourse/lib/tasks/assets.rake:125:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:137:in `block in '
Falco
(Falco)
5 mei 2016 om 14:36
Do you have enough ram and swap?
free -m
@SkritterJosh ME TOO!!
2gb droplet - way more than enough. I just saw the update and tried it.
100% same err. Def have enough mem.
@Falco Yes, I do have enough ram and swap.
@dylanh724 I just updated docker and discourse using the terminal and it seemed to work, but using the discourse admin interface it didn’t.
Show us the output of free -m
avorio
(Avorio)
5 mei 2016 om 22:32
6
I got exactly the same error. Here’s the output:
Compressing: docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js
gzip /var/www/discourse/public/assets/docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js
Bundling assets
Compressing Javascript and Generating Source Maps
rake aborted!
Errno::ENOMEM: Cannot allocate memory - gzip -f -c -7 /var/www/discourse/public/assets/docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js > /var/www/discourse/public/assets/docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js.gz
/var/www/discourse/lib/tasks/assets.rake:149:in `block (2 levels) in '
/var/www/discourse/lib/tasks/assets.rake:130:in `each'
/var/www/discourse/lib/tasks/assets.rake:130:in `block in '
Tasks: TOP => assets:precompile
And here’s free -m:
root@xyz:~# free -m
total used free shared buffers cached
Mem: 2000 1586 414 36 63 276
-/+ buffers/cache: 1246 754
Swap: 0 0 0
root@xyz:~#
However, now admin/upgrade says that docker_manager is up to date:
docker_manager (9b59950)
avorio
(Avorio)
5 mei 2016 om 22:50
8
Thanks. I just did that.
Is it safe to assume that the upgrade went well, then? Or how do I double-check?
Falco
(Falco)
5 mei 2016 om 22:53
9
There is the version on /admin, and the version hash on the page source (CTRL +U ) that you can check.
@avorio I’m not sure if it’s safe to assume that. I also experienced the same thing where the upgrade failed, but then later it said everything was up to date. I went ahead and manually updated both docker and discourse. It did appear they still had updates perform and the dashboard was producing a false positive on the update.
avorio
(Avorio)
6 mei 2016 om 21:46
11
Hi @SkritterJosh ! Thanks for that.
How do I manually update both docker and discourse, please?
On my particular setup using Ubuntu I ran the following commands to get things updated.
Docker:
apt-get update
apt-get upgrade lxc-docker
Discourse
cd /var/discourse
git pull
./launcher rebuild app
sam
(Sam Saffron)
6 mei 2016 om 23:19
13
see: Install Docker Engine on Ubuntu | Docker Docs
you want docker-engine, lxc-docker should be removed.
I believe lxc-docker can be upgraded to 1.9.1 but no higher.
sam
(Sam Saffron)
16 januari 2019 om 19:36
16
General solution to this error is adding swap, in some cases you may need a bigger swap
