צור קובץ החלפה לשרת Linux שלך
:bulb: For servers with <= 4GB of RAM, running ./discourse-setup will prompt for and automatically create a 2GB swapfile.
Most cloud virtual machine providers do not set up swapfiles as part of their server provisioning.
In particular, upgrading Discourse produces a lot of memory pressure. With a swap file, rather than randomly terminating processes with an out of memory error, things will slow down instead. Having a swap file is a cheap insurance policy that protects you from many other load related failures.
This can be done at any time from the command line on your server.
Set up a 2GB swap file
We recommend a 2GB swap file for Discourse, unless your server has more than 4GB of memory.
In the shell you have opened to your droplet, do the following:
:warning: You will need to be root for much of this, so either be root or sudo -s before running these commands! Don’t forget to exit root afterwards.
  1. Create an empty swapfile
     install -o root -g root -m 0600 /dev/null /swapfile
  2. Allocate a 2GB file named ‘swapfile’
     fallocate -l 2G /swapfile
  3. tell linux this is the swap file:
     mkswap /swapfile
  4. Activate it
     swapon /swapfile
  5. Add it to the file system table so its there after reboot:
     echo "/swapfile       swap    swap    auto      0       0" | tee -a /etc/fstab
  6. Set the swappiness to 10 so its only uses as an emergency buffer
     sysctl -w vm.swappiness=10
     echo 'vm.swappiness = 10' > /etc/sysctl.d/30-discourse-swap.conf
The whole thing as a single copy and pastable script:
mkswap /swapfile
swapon /swapfile
96 לייקים
I’ve been trying to set up a larger swapfile (4GB instead of the default 2GB), but have run into this when running the script above:
rm: cannot remove `swapfile’: Operation not permitted
To get around this, I’ve had to do this first:
  1. Reboot the server (it wouldn’t let me swapoff, presumably due to heavy swapfile use)
  2. swapoff -a -v
3 לייקים
For similar reasons, I run with two swapfiles:
# swapon
NAME                       TYPE  SIZE  USED PRIO
/var/local/swap/swapfile.0 file 1024M 44.9M   -3
/var/local/swap/swapfile.1 file 1024M 1024M   -2
A second swap file could be a clever way to avoid the reboot. Just create a second swap file, enable it, and then remove the first.
4 לייקים
So we won’t be needing to follow this guide to make the 2GB swap file since the installation already does that if we have less that 2GB of memory?
Yes - but if you change your server config, or perhaps if you do a migration, you might need to look after this yourself. (At the same time there are two important kernel configs to change which the installation does not look after - see MKJ’s Opinionated Discourse Deployment Configuration
10 posts were split to a new topic: High rebuild memory requirements: April 2025 edition
