Hello,
I tried to upgrade today from beta1 to beta2. In that process somehow it got stuck and it showed as upgrading… I reseted the upgrade now it shows i am at the latest version when i am not?
Hello,
I hope I’m not hijacking your thread, and it’s not the same error as yours, but when I tried updating from +281 to beta 2 yesterday it would always fail with the following:
$ cd /var/www/discourse && git fetch && git reset --hard HEAD@{upstream}
HEAD is now at e7d1fa8 Merge pull request #4186 from shaktikatare1989/suspention-details-in-log
Compressing: docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js
gzip /var/www/discourse/public/assets/docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js
Bundling assets
Compressing Javascript and Generating Source Maps
rake aborted!
Errno::ENOMEM: Cannot allocate memory - gzip -f -c -7 /var/www/discourse/public/assets/docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js > /var/www/discourse/public/assets/docker-manager-app-c32d676193f61b3085ec0e77f8d9fca361291a549828d82d1e33c356786f8ca0.js.gz
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.6/lib/active_support/core_ext/kernel/agnostics.rb:7:in ``'
/var/www/discourse/lib/tasks/assets.rake:108:in `gzip'
/var/www/discourse/lib/tasks/assets.rake:161:in `block (4 levels) in '
/var/www/discourse/lib/tasks/assets.rake:125:in `call'
/var/www/discourse/lib/tasks/assets.rake:125:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:152:in `call'
/var/www/discourse/lib/tasks/assets.rake:152:in `block (3 levels) in '
/var/www/discourse/lib/tasks/assets.rake:141:in `each'
/var/www/discourse/lib/tasks/assets.rake:141:in `block (2 levels) in '
/var/www/discourse/lib/tasks/assets.rake:125:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:137:in `block in '
Tasks: TOP => assets:precompile
Be sure to add swap to this instance of yours.
Already has 2GB swap. I added swap immediately after the Droplet was created.
What does free return?
It returns that I should hang my head in shame. I added swap but did not edit the /etc/fstab file, so I lost swap during a reboot somewhere. I have corrected that.
I also went ahead and added the following entries to /etc/sysctl.conf:
vm.swappiness=10
vm.vfs_cache_pressure=50
Returning to this topic’s original flavour of upgrade error:
Me too
after git pull and ./launcher rebuild app
I have the same problem described in more details here: Cannot access topics after upgrade from 1.6.0.beta1 to beta2
Bumping this topic since it got derailed, i did git pull and rebuild too
Did you reboot your server?
Nope? Should i do that?
Yes, you should try that.
What mechanism is there to use v1.6.0.beta2 if there is a more recent test_pass version? It looks like my build is saying the identical (wrong) thing and pointing to this commit but stating this is v1.6.0.beta1+281. I’ll try if my problem still happens if I explicitely use
Umm any other way i can solve this??
You are simply referring to the version mis-match right? If so, don’t sweat it. You can always visit admin/upgrade to pick up the latest changes. My sandbox is showing the same thing as your screenshot.
Same here:
I’ve already tried:
cd /var/discourse
git pull
Well then this is completely unrelated to the OP on the topic but somehow we forgot to bump versions right @neil
Meta is at v1.6.0.beta1 +316 … latest is beta2
Well that explains all the version issue reports
