Error after installation - Discourse-doctor - antibiotics not working
A user is experiencing errors during the installation of Discourse, particularly with the discourse-doctor command and asset compilation. The main error is a NoMethodError in discourse_ip_info.rb related to MaxMindDB, which appears to be linked to the maxmind configuration. The user has disabled Transparent Huge Pages and attempted to resolve the issue by removing the MaxMindDB configuration, which resulted in a successful build. Other warnings include unmet peer dependencies and a clocksource warning from Redis. The user seeks advice on resolving the npm warnings and the clocksource issue. ElComputer is the primary user experiencing the issue, and Ed_S provides guidance on troubleshooting the MaxMindDB error and addressing the warnings.
I see these errors - how can i find the full error log for the installation and post it here for diagnose and maybe fix?
I, [2024-02-07T04:52:47.464805 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has unmet peer dependency "@typescript-eslint/parser@^6.15.0".
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has incorrect peer dependency "typescript@^5.3.3".
warning " > @glint/environment-ember-loose@1.3.0" has unmet peer dependency "@glimmer/component@^1.1.2".
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3339 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
3e14aea2f51d9bea24b23a8410308ed1326b59eed3442276faeb4a1acc17fa3c
Try the DIscourse Doctor:
I did try to run the doctor and yet recieve various errors eg:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3341 exit 1>
a8290de4d358001a4a43f9a101a03713112714c6e425ff08f036f5f62d3b889a
==================== END REBUILD LOG ====================
Failed to rebuild app.
and
WARNING: ember-test-selectors: You are using an unsupported ember-cli-babel version. data-test properties are not automatically stripped from your JS code.
building...
or
111:M 07 Feb 2024 04:57:18.394 * Background saving terminated with success
Purging temp files
Bundling assets
#<Thread:0x00007f08e4ea9018 /var/www/discourse/lib/tasks/maxminddb.rake:62 run> terminated with exception (report_on_exception is true):
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
    filename = File.basename(gz_file.path)
or
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning Pattern ["wrap-ansi@^7.0.0"] is trying to unpack in the same destination "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/node_modules/wrap-ansi-cjs" as pattern ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. This could result in non-deterministic behavior, skipping.
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
Its worth mentioning the application is running but i prefer to fix these issues so i know everything is running smoothly
So discourse doctor restarted your old container?
You don’t include the actual error, but I bet that it was “exit code 137”. It that’s the case you case try making the changes this describes
Warnings: overcommit_memory and Transparent Huge Pages. (I’m not clear if that post describes your to change this settings, so you night need to look elsewhere). It would be interesting to know if that solved the problem. If not, you can increase swap.
How much memory do you have?
Eww - that linked post with the accepted solution is exactly wrong, these days! It is wise to fix those settings. See here instead for one of the most recent cases.
I actually allowed overcommitting.
My machine is a EC2 with 2 GB ram and 4 GB swap file
Thanks for noticing that! I wanted to link to our earlier constatation but couldn’t find it on my phone in the middle of the night…
I have successfully
root@forum:/home/ubuntu# cat /sys/kernel/mm/transparent_hugepage/enabled always madvise [never]
i created a service
sudo -s
/etc/systemd/system/disable-thp.service
[Unit]
Description=Disable Transparent Huge Pages (THP)
[Service]
Type=simple
ExecStart=/bin/sh -c 'echo never > /sys/kernel/mm/transparent_hugepage/enabled'
inserted the follow:
[Install]
WantedBy=multi-user.target`
saved the file and then started the service
sudo systemctl enable disable-thp.service
sudo systemctl start disable-thp.service
restarted the machine  (sudo reboot)
now i will try to make any change, rebuild the app and report back.
Here is the full log, since i cannot post in one body message, i have to explit it in two
root@forum:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20231218-0429: Pulling from discourse/base
Digest: sha256:468f70b9bb4c6d0c6c2bbb3efc1a5e12d145eae57bdb6946b7fe5558beb52dc1
Status: Image is up to date for discourse/base:2.0.20231218-0429
docker.io/discourse/base:2.0.20231218-0429
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-02-07T09:47:28.035467 #1]  INFO -- : Reading from stdin
I, [2024-02-07T09:47:28.042109 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2024-02-07T09:47:28.079949 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-02-07T09:47:28.080639 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2024-02-07T09:47:28.084146 #1]  INFO -- :
I, [2024-02-07T09:47:28.084793 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2024-02-07T09:47:28.087691 #1]  INFO -- :
I, [2024-02-07T09:47:28.088305 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2024-02-07T09:47:28.090841 #1]  INFO -- :
I, [2024-02-07T09:47:28.091354 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2024-02-07T09:47:28.094804 #1]  INFO -- :
I, [2024-02-07T09:47:28.095396 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2024-02-07T09:47:28.098993 #1]  INFO -- :
I, [2024-02-07T09:47:28.099576 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2024/02/07 09:47:28 socat[19] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2024-02-07T09:47:28.121468 #1]  INFO -- :
I, [2024-02-07T09:47:28.121935 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2024-02-07T09:47:28.125133 #1]  INFO -- :
I, [2024-02-07T09:47:28.125586 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2024-02-07T09:47:28.128594 #1]  INFO -- :
I, [2024-02-07T09:47:28.129009 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-07T09:47:28.131459 #1]  INFO -- :
I, [2024-02-07T09:47:28.132081 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-07T09:47:28.134362 #1]  INFO -- :
I, [2024-02-07T09:47:28.139443 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-02-07T09:47:28.144552 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-02-07T09:47:28.149732 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-02-07T09:47:28.154622 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-02-07T09:47:28.155246 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2024-02-07T09:47:30.751125 #1]  INFO -- :
I, [2024-02-07T09:47:30.751953 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2024-02-07T09:47:30.754323 #1]  INFO -- :
I, [2024-02-07T09:47:30.754740 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2024-02-07T09:47:30.778074 #1]  INFO -- :
I, [2024-02-07T09:47:30.778847 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2024-02-07T09:47:30.781642 #1]  INFO -- :
I, [2024-02-07T09:47:30.782206 #1]  INFO -- : > /root/upgrade_postgres
I, [2024-02-07T09:47:30.787657 #1]  INFO -- :
I, [2024-02-07T09:47:30.788218 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2024-02-07T09:47:30.790362 #1]  INFO -- :
I, [2024-02-07T09:47:30.791615 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.792496 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.793083 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.793938 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.799721 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.801028 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.801771 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2024-02-07T09:47:30.808467 #1]  INFO -- :
I, [2024-02-07T09:47:30.809189 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.811070 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.812115 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.814049 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-07T09:47:30.814619 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-07T09:47:30.815142 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-07T09:47:30.815937 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-02-07T09:47:30.817772 #1]  INFO -- : > sleep 5
2024-02-07 09:47:30.880 UTC [42] LOG:  starting PostgreSQL 13.13 (Debian 13.13-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-02-07 09:47:30.881 UTC [42] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-02-07 09:47:30.881 UTC [42] LOG:  listening on IPv6 address "::", port 5432
2024-02-07 09:47:30.889 UTC [42] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-02-07 09:47:30.898 UTC [45] LOG:  database system was shut down at 2024-02-07 09:47:17 UTC
2024-02-07 09:47:30.906 UTC [42] LOG:  database system is ready to accept connections
I, [2024-02-07T09:47:35.821930 #1]  INFO -- :
I, [2024-02-07T09:47:35.822141 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2024-02-07 09:47:35.897 UTC [55] postgres@postgres ERROR:  database "discourse" already exists
2024-02-07 09:47:35.897 UTC [55] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2024-02-07T09:47:35.900564 #1]  INFO -- :
I, [2024-02-07T09:47:35.901065 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2024-02-07 09:47:35.980 UTC [59] postgres@discourse ERROR:  role "discourse" already exists
2024-02-07 09:47:35.980 UTC [59] postgres@discourse STATEMENT:  create user discourse;
I, [2024-02-07T09:47:35.983378 #1]  INFO -- :
I, [2024-02-07T09:47:35.983867 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2024-02-07T09:47:36.041879 #1]  INFO -- : GRANT
I, [2024-02-07T09:47:36.042564 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2024-02-07T09:47:36.101153 #1]  INFO -- : ALTER SCHEMA
I, [2024-02-07T09:47:36.101850 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2024-02-07T09:47:36.168551 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.169099 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2024-02-07T09:47:36.225091 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.225656 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
NOTICE:  extension "vector" already exists, skipping
I, [2024-02-07T09:47:36.282090 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.282643 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2024-02-07T09:47:36.340426 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.340963 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2024-02-07T09:47:36.397482 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.398028 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2024-02-07T09:47:36.455492 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.456161 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2024-02-07T09:47:36.464961 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2024-02-07T09:47:36.566296 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-02-07T09:47:36.569940 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-02-07T09:47:36.570518 #1]  INFO -- : > echo postgres installed!
I, [2024-02-07T09:47:36.573234 #1]  INFO -- : postgres installed!
I, [2024-02-07T09:47:36.579028 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-02-07T09:47:36.584300 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-02-07T09:47:36.589237 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-02-07T09:47:36.591553 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.592681 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.593494 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-02-07T09:47:36.596887 #1]  INFO -- :
I, [2024-02-07T09:47:36.597723 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.598600 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.600144 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.601562 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.602979 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.604383 #1]  INFO -- : > echo redis installed
I, [2024-02-07T09:47:36.607125 #1]  INFO -- : redis installed
I, [2024-02-07T09:47:36.607787 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-02-07T09:47:36.612950 #1]  INFO -- : logfile ""
I, [2024-02-07T09:47:36.613545 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-07T09:47:36.615296 #1]  INFO -- : > sleep 10
111:C 07 Feb 2024 09:47:36.630 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
111:C 07 Feb 2024 09:47:36.630 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=111, just started
111:C 07 Feb 2024 09:47:36.630 # Configuration loaded
111:M 07 Feb 2024 09:47:36.631 * monotonic clock: POSIX clock_gettime
111:M 07 Feb 2024 09:47:36.632 * Running mode=standalone, port=6379.
111:M 07 Feb 2024 09:47:36.632 # Server initialized
111:M 07 Feb 2024 09:47:36.633 # WARNING Your system is configured to use the 'xen' clocksource which might lead to degraded performance. Check the result of the [slow-clocksource] system check: run 'redis-server --check-system' to check if the system's clocksource isn't degrading performance.
111:M 07 Feb 2024 09:47:36.633 * Loading RDB produced by version 7.0.7
111:M 07 Feb 2024 09:47:36.634 * RDB age 20 seconds
111:M 07 Feb 2024 09:47:36.634 * RDB memory usage when created 13.66 Mb
111:M 07 Feb 2024 09:47:36.655 * Done loading RDB, keys loaded: 404, keys expired: 2.
111:M 07 Feb 2024 09:47:36.656 * DB loaded from disk: 0.022 seconds
111:M 07 Feb 2024 09:47:36.656 * Ready to accept connections
I, [2024-02-07T09:47:46.619646 #1]  INFO -- :
I, [2024-02-07T09:47:46.620451 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-02-07T09:47:46.625010 #1]  INFO -- : thpoff is installed!
I, [2024-02-07T09:47:46.625638 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-02-07T09:47:46.706869 #1]  INFO -- :
I, [2024-02-07T09:47:46.707567 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-02-07T09:47:46.788356 #1]  INFO -- :
I, [2024-02-07T09:47:46.789065 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-02-07T09:47:46.869768 #1]  INFO -- :
I, [2024-02-07T09:47:46.870447 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-02-07T09:47:46.873269 #1]  INFO -- :
I, [2024-02-07T09:47:46.876471 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-02-07T09:47:46.881434 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-02-07T09:47:46.886402 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-02-07T09:47:46.891375 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-02-07T09:47:46.896366 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-02-07T09:47:46.901193 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-02-07T09:47:46.901633 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2024-02-07T09:47:46.902195 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-07T09:47:46.904582 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
138:C 07 Feb 2024 09:47:46.917 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
138:C 07 Feb 2024 09:47:46.917 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=138, just started
138:C 07 Feb 2024 09:47:46.917 # Configuration loaded
138:M 07 Feb 2024 09:47:46.918 * monotonic clock: POSIX clock_gettime
138:M 07 Feb 2024 09:47:46.919 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
138:M 07 Feb 2024 09:47:46.919 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33715/33715), done.
I, [2024-02-07T09:47:52.123695 #1]  INFO -- : HEAD is now at 6ab1a19e9 DEV: Convert min_trust_level_to_allow_invite to groups (#24893)
I, [2024-02-07T09:47:52.124327 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-02-07T09:47:52.276708 #1]  INFO -- :
I, [2024-02-07T09:47:52.277312 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-drop-code
 - [deleted]             (none)     -> origin/bulk-button-class
 - [deleted]             (none)     -> origin/dependabot/bundler/excon-0.108.0
 - [deleted]             (none)     -> origin/dependabot/bundler/hashdiff-1.1.0
 - [deleted]             (none)     -> origin/dependabot/bundler/parallel-1.24.0
 - [deleted]             (none)     -> origin/dependabot/bundler/rubocop-discourse-3.6.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/drop-target-2.0.2
 - [deleted]             (none)     -> origin/dev/add-new-chat-metrics
 - [deleted]             (none)     -> origin/dev/allow-chat-mentions-to-have-several-notifications
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-create-tag-to-group
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-ignore-to-groups
 - [deleted]             (none)     -> origin/dev/rethink-mass-mentions-polymorphic
 - [deleted]             (none)     -> origin/feature/migrations-schema-generator
 - [deleted]             (none)     -> origin/fix-join-filter-upload
 - [deleted]             (none)     -> origin/fix-modal-flash-minor
 - [deleted]             (none)     -> origin/global-notice-reactive
 - [deleted]             (none)     -> origin/labeler
 - [deleted]             (none)     -> origin/low-ram-help
 - [deleted]             (none)     -> origin/multi-invite
 - [deleted]             (none)     -> origin/plugin-extra-js
 - [deleted]             (none)     -> origin/table-builder-modal-modifier
 - [deleted]             (none)     -> origin/wip_categories
 - [deleted]             (none)     -> origin/wizard-split
   6ab1a19e9..dea753a20  main                    -> origin/main
 * [new branch]          0-ember-bump            -> origin/0-ember-bump
 * [new branch]          0-event-helper          -> origin/0-event-helper
 * [new branch]          0-extend-native         -> origin/0-extend-native
 * [new branch]          0-rev                   -> origin/0-rev
 * [new branch]          add-api-for-forced-auth -> origin/add-api-for-forced-auth
 * [new branch]          api-image-wrapper       -> origin/api-image-wrapper
 * [new branch]          asciinema-iframe        -> origin/asciinema-iframe
 * [new branch]          bulk-select-dropdown-items -> origin/bulk-select-dropdown-items
 * [new branch]          chat-channel-settings-padding-fix -> origin/chat-channel-settings-padding-fix
 * [new branch]          convert-header-to-glimmer -> origin/convert-header-to-glimmer
 * [new branch]          decorator-transforms    -> origin/decorator-transforms
 * [new branch]          dependabot/bundler/omniauth-2.0.0 -> origin/dependabot/bundler/omniauth-2.0.0
 * [new branch]          dependabot/bundler/parallel_tests-4.4.0 -> origin/dependabot/bundler/parallel_tests-4.4.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/content-tag-2.0.1 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/content-tag-2.0.1
 * [new branch]          dev-convert-topic-map-expanded-widget-to-component -> origin/dev-convert-topic-map-expanded-widget-to-component
 * [new branch]          dev/check-whether-online-user-ids-may-be-memoized-between-job-runs -> origin/dev/check-whether-online-user-ids-may-be-memoized-between-job-runs
 * [new branch]          dev/drop-the-user-id-column-from-chat-mentions -> origin/dev/drop-the-user-id-column-from-chat-mentions
 + e0c0191bb...cf69dac7c dev/dry-up-user-status-serializers -> origin/dev/dry-up-user-status-serializers  (forced update)
 * [new branch]          dev/experiment-theme-settings-free-ui -> origin/dev/experiment-theme-settings-free-ui
 * [new branch]          dev/make-admins-tl4-in-tests -> origin/dev/make-admins-tl4-in-tests
 * [new branch]          dev/move-more-client-settings-group -> origin/dev/move-more-client-settings-group
 * [new branch]          dev/promote-plugin-post-deploy-migrations -> origin/dev/promote-plugin-post-deploy-migrations
 * [new branch]          dev/proof-of-concept-rewriting-mentions-notification-logic -> origin/dev/proof-of-concept-rewriting-mentions-notification-logic
 * [new branch]          dev_category_order_database -> origin/dev_category_order_database
 * [new branch]          dev_update_category_position -> origin/dev_update_category_position
 * [new branch]          extra-js-revert         -> origin/extra-js-revert
 * [new branch]          fast-edit-expand-regex  -> origin/fast-edit-expand-regex
 * [new branch]          feature/custom-date-range -> origin/feature/custom-date-range
 * [new branch]          feature/paste-upload-on-first-upload-input-templates -> origin/feature/paste-upload-on-first-upload-input-templates
 * [new branch]          feature_async_hashtags  -> origin/feature_async_hashtags
 * [new branch]          feature_async_load_colors -> origin/feature_async_load_colors
 * [new branch]          fix-email-category-badge -> origin/fix-email-category-badge
 * [new branch]          fix_category_chooser    -> origin/fix_category_chooser
 * [new branch]          fix_in_any_groups       -> origin/fix_in_any_groups
 * [new branch]          fix_reviewable_translation -> origin/fix_reviewable_translation
   7f2bdca65..4f57be1a8  generic-import-latest   -> origin/generic-import-latest
 * [new branch]          hijacks                 -> origin/hijacks
 * [new branch]          issue/run-admin-sidebar-init-after-logs-notice -> origin/issue/run-admin-sidebar-init-after-logs-notice
 * [new branch]          loic-rubocop-plugin-rules -> origin/loic-rubocop-plugin-rules
 + 90a3535b7...e6e64cfd5 migrations-convert      -> origin/migrations-convert  (forced update)
 * [new branch]          promote-migration-tweak -> origin/promote-migration-tweak
 * [new branch]          redesign-my-threads-index -> origin/redesign-my-threads-index
 * [new branch]          revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups -> origin/revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups
 * [new branch]          revert-bulk-topic-actions -> origin/revert-bulk-topic-actions
 * [new branch]          sidebar-above-outlet    -> origin/sidebar-above-outlet
 * [new branch]          site-logo-height        -> origin/site-logo-height
 * [new branch]          sort-chat-channels-by-activity -> origin/sort-chat-channels-by-activity
   d7f7f79b6..124aa9ac9  stable                  -> origin/stable
 * [new branch]          support-reset-bump-date-post-id -> origin/support-reset-bump-date-post-id
 * [new branch]          system-test-for-soft-load-search -> origin/system-test-for-soft-load-search
   6ab1a19e9..32ee0e3c0  tests-passed            -> origin/tests-passed
 * [new branch]          unhide_lazy_load_categories -> origin/unhide_lazy_load_categories
 * [new branch]          universal-nonce         -> origin/universal-nonce
 * [new branch]          virtual-scroll-list     -> origin/virtual-scroll-list
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.1.4                  -> v3.1.4
 * [new tag]             v3.1.5                  -> v3.1.5
 * [new tag]             v3.2.0                  -> v3.2.0
 * [new tag]             v3.2.0.beta4            -> v3.2.0.beta4
 * [new tag]             v3.2.0.beta5            -> v3.2.0.beta5
I, [2024-02-07T09:47:53.573291 #1]  INFO -- :
I, [2024-02-07T09:47:53.573724 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-02-07T09:47:59.166238 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-02-07T09:47:59.166787 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-02-07T09:47:59.178706 #1]  INFO -- :
I, [2024-02-07T09:47:59.179296 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-02-07T09:47:59.183038 #1]  INFO -- :
I, [2024-02-07T09:47:59.183411 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-02-07T09:47:59.186620 #1]  INFO -- :
I, [2024-02-07T09:47:59.186984 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-02-07T09:47:59.190393 #1]  INFO -- :
I, [2024-02-07T09:47:59.190793 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-02-07T09:47:59.194202 #1]  INFO -- :
I, [2024-02-07T09:47:59.194567 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-02-07T09:47:59.198137 #1]  INFO -- :
I, [2024-02-07T09:47:59.198505 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-02-07T09:47:59.201926 #1]  INFO -- :
I, [2024-02-07T09:47:59.202293 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-02-07T09:47:59.207056 #1]  INFO -- :
I, [2024-02-07T09:47:59.207444 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-02-07T09:47:59.212501 #1]  INFO -- :
I, [2024-02-07T09:47:59.212922 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-02-07T09:47:59.218073 #1]  INFO -- :
I, [2024-02-07T09:47:59.218463 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-02-07T09:47:59.223175 #1]  INFO -- :
I, [2024-02-07T09:47:59.223559 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-02-07T09:47:59.228838 #1]  INFO -- :
I, [2024-02-07T09:47:59.229262 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-02-07T09:47:59.234110 #1]  INFO -- :
I, [2024-02-07T09:47:59.234553 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-02-07T09:47:59.240488 #1]  INFO -- :
I, [2024-02-07T09:47:59.240915 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-02-07T09:47:59.243068 #1]  INFO -- :
I, [2024-02-07T09:47:59.243549 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-02-07T09:47:59.244199 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-02-07T09:48:01.088471 #1]  INFO -- :
I, [2024-02-07T09:48:01.089265 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.093400 #1]  INFO -- :
I, [2024-02-07T09:48:01.094048 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-02-07T09:48:01.096633 #1]  INFO -- :
I, [2024-02-07T09:48:01.097180 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-02-07T09:48:01.100107 #1]  INFO -- :
I, [2024-02-07T09:48:01.101211 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-02-07T09:48:01.101849 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.102439 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.103117 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.104031 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-02-07T09:48:01.104574 #1]  INFO -- : > echo "done configuring web"
I, [2024-02-07T09:48:01.106926 #1]  INFO -- : done configuring web
I, [2024-02-07T09:48:01.107482 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-02-07T09:48:02.049424 #1]  INFO -- : Successfully installed bundler-2.5.3
1 gem installed
I, [2024-02-07T09:48:02.050149 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-02-07T09:48:10.650184 #1]  INFO -- :
I, [2024-02-07T09:48:10.650996 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2024-02-07T09:48:10.653470 #1]  INFO -- :
I, [2024-02-07T09:48:10.653922 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I, [2024-02-07T09:50:54.046212 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)); console.log(passthrough.join(` `));')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
$ ./run-patch-package
patch-package 8.0.0
Applying patches...
@ember/test-helpers@2.9.4 ✔
babel-plugin-debug-macros@0.3.4 ✔
content-tag@2.0.1 ✔
ember-cli@5.0.0 ✔
ember-this-fallback@0.4.0 (1 deprecation-name) ✔
ember-this-fallback@0.4.0 (2 themes) ✔
ember-this-fallback@0.4.0 (3 exclude-strict-mode) ✔
virtual-dom@2.1.1 ✔
Done in 77.54s.
Done in 149.09s.
yarn cache v1.22.19
success Cleared cache.
Done in 13.34s.
I, [2024-02-07T09:50:54.077938 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local deployment true'
I, [2024-02-07T09:50:54.480628 #1]  INFO -- :
I, [2024-02-07T09:50:54.481198 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local without "development test"'
I, [2024-02-07T09:50:54.683215 #1]  INFO -- : You are replacing the current local value of without, which is currently "test:development"
I, [2024-02-07T09:50:54.683835 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
I, [2024-02-07T09:51:36.676718 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/.........
Fetching concurrent-ruby 1.2.3
Fetching minitest 5.22.0
Fetching bigdecimal 3.1.6
Fetching cbor 0.5.9.8
Installing bigdecimal 3.1.6 with native extensions
Installing minitest 5.22.0
Installing cbor 0.5.9.8 with native extensions
Installing concurrent-ruby 1.2.3
Fetching excon 0.109.0
Installing excon 0.109.0
Fetching fastimage 2.3.0
Installing fastimage 2.3.0
Fetching google-protobuf 3.25.2 (x86_64-linux)
Fetching highline 3.0.1
Installing highline 3.0.1
Fetching image_size 3.4.0
Installing google-protobuf 3.25.2 (x86_64-linux)
Installing image_size 3.4.0
Fetching regexp_parser 2.9.0
Installing regexp_parser 2.9.0
Fetching zeitwerk 2.6.13
Installing zeitwerk 2.6.13
Fetching logster 2.16.0
Fetching stackprof 0.2.26
Installing stackprof 0.2.26 with native extensions
Installing logster 2.16.0
Fetching nokogiri 1.16.2 (x86_64-linux)
Installing nokogiri 1.16.2 (x86_64-linux)
Fetching rack-protection 3.2.0
Installing rack-protection 3.2.0
Fetching bootsnap 1.18.3
Installing bootsnap 1.18.3 with native extensions
Fetching net-http 0.4.1
Installing net-http 0.4.1
Fetching sass-embedded 1.70.0 (x86_64-linux-gnu)
Fetching puma 6.4.2
Installing puma 6.4.2 with native extensions
Installing sass-embedded 1.70.0 (x86_64-linux-gnu)
Fetching rbtrace 0.5.1
Installing rbtrace 0.5.1 with native extensions
Fetching net-imap 0.4.10
Installing net-imap 0.4.10
Fetching net-smtp 0.4.0.1
Installing net-smtp 0.4.0.1
Fetching faraday-net_http 3.1.0
Installing faraday-net_http 3.1.0
Fetching activesupport 7.0.8
Installing activesupport 7.0.8
Fetching tzinfo-data 1.2024.1
Installing tzinfo-data 1.2024.1
Fetching sassc-embedded 1.70.0
Installing sassc-embedded 1.70.0
Fetching faraday 2.9.0
Installing faraday 2.9.0
Fetching activemodel 7.0.8
Installing activemodel 7.0.8
Fetching actionview 7.0.8
Installing actionview 7.0.8
Fetching activejob 7.0.8
Installing activejob 7.0.8
Fetching activerecord 7.0.8
Installing activerecord 7.0.8
Fetching actionpack 7.0.8
Installing actionpack 7.0.8
Fetching actionmailer 7.0.8
Installing actionmailer 7.0.8
Fetching railties 7.0.8
Installing railties 7.0.8
Bundle complete! 138 Gemfile dependencies, 170 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2024-02-07T09:51:36.678489 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-02-07T09:51:41.396361 #1]  INFO -- : docker_manager is already at latest compatible version
I, [2024-02-07T09:51:41.398224 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2024-02-07T09:51:49.180668 #1]  INFO -- :
I, [2024-02-07T09:51:49.181432 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Node.js heap_size_limit (1002.25) is less than 2048MB. Setting --max-old-space-size=2048.
111:M 07 Feb 2024 09:52:37.070 * 100 changes in 300 seconds. Saving...
111:M 07 Feb 2024 09:52:37.078 * Background saving started by pid 3430
3430:C 07 Feb 2024 09:52:37.268 * DB saved on disk
3430:C 07 Feb 2024 09:52:37.269 * Fork CoW for RDB: current 1 MB, peak 1 MB, average 1 MB
111:M 07 Feb 2024 09:52:37.279 * Background saving terminated with success
Purging temp files
Bundling assets
#<Thread:0x00007f10b85813d8 /var/www/discourse/lib/tasks/maxminddb.rake:62 run> terminated with exception (report_on_exception is true):
        from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
I, [2024-02-07T09:56:57.163180 #3444]  INFO -- : Writing /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js
I, [2024-02-07T09:56:57.173780 #3444]  INFO -- : Writing /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js
I, [2024-02-07T09:56:57.178601 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js
I, [2024-02-07T09:56:57.182475 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
I, [2024-02-07T09:56:57.922268 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js
I, [2024-02-07T09:56:58.142354 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js
I, [2024-02-07T09:56:58.485685 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js
I, [2024-02-07T09:56:58.751145 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js
I, [2024-02-07T09:56:58.988759 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js
I, [2024-02-07T09:56:59.267080 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js
I, [2024-02-07T09:56:59.518029 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js
I, [2024-02-07T09:56:59.905207 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js
I, [2024-02-07T09:57:00.285336 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js
I, [2024-02-07T09:57:00.464802 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js
I, [2024-02-07T09:57:00.653950 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js
I, [2024-02-07T09:57:00.933879 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js
I, [2024-02-07T09:57:01.165769 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js
I, [2024-02-07T09:57:01.446016 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js
I, [2024-02-07T09:57:01.714231 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js
I, [2024-02-07T09:57:01.983926 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js
I, [2024-02-07T09:57:02.231200 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js
I, [2024-02-07T09:57:02.569657 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js
I, [2024-02-07T09:57:02.818672 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js
I, [2024-02-07T09:57:03.084146 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js
I, [2024-02-07T09:57:03.352798 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js
I, [2024-02-07T09:57:03.579685 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js
I, [2024-02-07T09:57:03.839930 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js
I, [2024-02-07T09:57:04.111361 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js
I, [2024-02-07T09:57:04.490944 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js
I, [2024-02-07T09:57:04.726476 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js
I, [2024-02-07T09:57:04.967437 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js
I, [2024-02-07T09:57:05.210753 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js
I, [2024-02-07T09:57:05.473690 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js
I, [2024-02-07T09:57:05.756780 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js
I, [2024-02-07T09:57:06.003191 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js
I, [2024-02-07T09:57:06.261175 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js
I, [2024-02-07T09:57:06.505804 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js
I, [2024-02-07T09:57:06.845501 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js
I, [2024-02-07T09:57:07.071806 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js
I, [2024-02-07T09:57:07.320534 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js
I, [2024-02-07T09:57:07.556332 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js
I, [2024-02-07T09:57:07.779575 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js
I, [2024-02-07T09:57:08.041938 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js
I, [2024-02-07T09:57:08.269410 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js
I, [2024-02-07T09:57:08.608550 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js
I, [2024-02-07T09:57:08.935619 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js
I, [2024-02-07T09:57:09.192326 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js
I, [2024-02-07T09:57:09.526333 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js
I, [2024-02-07T09:57:09.792019 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js
I, [2024-02-07T09:57:10.147565 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js
I, [2024-02-07T09:57:10.485426 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js
I, [2024-02-07T09:57:10.736941 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js
I, [2024-02-07T09:57:10.743579 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js
I, [2024-02-07T09:57:10.750228 #3444]  INFO -- : Writing /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js
I, [2024-02-07T09:57:10.751078 #3444]  INFO -- : Writing /var/www/discourse/public/assets/activate-account-3523016e5574f9a525ef6290fb8f4b48a26c4ce347b9abd5544100d6195d9c8c.map
I, [2024-02-07T09:57:10.967317 #3444]  INFO -- : Writing /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js
I, [2024-02-07T09:57:10.969151 #3444]  INFO -- : Writing /var/www/discourse/public/assets/admin-65e72d00354d5ad1527c564f7025df2c0c36e843a877a6e6540ec071d92ee9da.map
I, [2024-02-07T09:57:10.981073 #3444]  INFO -- : Writing /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js
I, [2024-02-07T09:57:10.982073 #3444]  INFO -- : Writing /var/www/discourse/public/assets/auto-redirect-783f6a24df430663e548fd3e8f2e37eee3a45923367ff44f6fbd7f6b9e0c3f68.map
I, [2024-02-07T09:57:10.988716 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js
I, [2024-02-07T09:57:10.989508 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-detect-d6593973a5e2ecaffb3cfe4e95c12f3a269ea4b4a7e92490d159a5bd841ec570.map
I, [2024-02-07T09:57:10.995713 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js
I, [2024-02-07T09:57:10.996589 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-update-ccac2124107451f99d1f542cf7d67a32435a9d933c8243f0579039f2cd52dc8f.map
I, [2024-02-07T09:57:11.951653 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js
I, [2024-02-07T09:57:11.958144 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.LICENSE.txt
I, [2024-02-07T09:57:11.959085 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.map
I, [2024-02-07T09:57:11.990961 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js
I, [2024-02-07T09:57:11.992098 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js.map
I, [2024-02-07T09:57:11.997018 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js
I, [2024-02-07T09:57:12.008392 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js
I, [2024-02-07T09:57:12.009416 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js.map
I, [2024-02-07T09:57:12.048364 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js
I, [2024-02-07T09:57:12.049498 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js.map
I, [2024-02-07T09:57:12.056056 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.css
I, [2024-02-07T09:57:12.059151 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.css.map
I, [2024-02-07T09:57:12.065850 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js
I, [2024-02-07T09:57:12.066755 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js.map
I, [2024-02-07T09:57:12.082214 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js
I, [2024-02-07T09:57:12.083291 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js.map
I, [2024-02-07T09:57:12.191292 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js
I, [2024-02-07T09:57:12.192659 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js.map
I, [2024-02-07T09:57:12.209804 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9ebd5cbc071c2d3f5cf7.css
I, [2024-02-07T09:57:12.213942 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9ebd5cbc071c2d3f5cf7.css.map
I, [2024-02-07T09:57:12.230199 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js
I, [2024-02-07T09:57:12.231366 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js.map
I, [2024-02-07T09:57:12.241829 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js
I, [2024-02-07T09:57:12.242841 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js.map
I, [2024-02-07T09:57:12.250112 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js
I, [2024-02-07T09:57:12.250961 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js.map
I, [2024-02-07T09:57:12.258351 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js
I, [2024-02-07T09:57:12.259326 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js.map
I, [2024-02-07T09:57:12.265456 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js
I, [2024-02-07T09:57:12.266406 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js.map
I, [2024-02-07T09:57:12.270036 #3444]  INFO -- : Writing /var/www/discourse/public/assets/discourse-07daaccc3e754332f981cc6510086e28c41cda9589ac33e33c8a96597fccb083.css
I, [2024-02-07T09:57:12.273597 #3444]  INFO -- : Writing /var/www/discourse/public/assets/discourse.d41d8cd98f00b204e9800998ecf8427e-e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855.css
I, [2024-02-07T09:57:12.280029 #3444]  INFO -- : Writing /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js
I, [2024-02-07T09:57:12.281016 #3444]  INFO -- : Writing /var/www/discourse/public/assets/embed-application-00e08d311d3285925aeed70aa17bb9b979372a54980d2c65d4ca76e61fb5707b.map
I, [2024-02-07T09:57:12.287567 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js
I, [2024-02-07T09:57:12.288498 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-tag-manager-28fec92fc63ed5152565c43f5342c098a1f3f3e9def1124373a0481b4abd4cab.map
I, [2024-02-07T09:57:12.299830 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js
I, [2024-02-07T09:57:12.300855 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v3-0bd4423881936fcc413adb3fea0296c8dfa09ce3b774cbe1369b094d10d5f94d.map
I, [2024-02-07T09:57:12.306805 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js
I, [2024-02-07T09:57:12.307680 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v4-fd5a48f039d353888be5f587b5d59fcc2a9468e578468f4832e4bc84675d294a.map
I, [2024-02-07T09:57:12.313773 #3444]  INFO -- : Writing /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js
I, [2024-02-07T09:57:12.314662 #3444]  INFO -- : Writing /var/www/discourse/public/assets/onpopstate-handler-aa17feb9a185b68dbd42e87bac3109bc26045effbc9f848929392b102d8ae0ae.map
I, [2024-02-07T09:57:12.473958 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js
I, [2024-02-07T09:57:12.475720 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/chat-d085afe6491c005413edbd82be60ec128e23e8aa22a4d5be91b74ae371663e5a.map
I, [2024-02-07T09:57:12.487376 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js
I, [2024-02-07T09:57:12.488387 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/checklist-d313dfa20c113a70f9a6a7356c86fdfad5996e2570302f9667c2ee2b5aed831d.map
I, [2024-02-07T09:57:12.494311 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js
I, [2024-02-07T09:57:12.495135 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-details-dc285aa1ef01d7a4bb93ca99bdc9cdc0ff4c05ce78dd0fa7e7198da0b066ede5.map
I, [2024-02-07T09:57:12.502222 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js
I, [2024-02-07T09:57:12.503123 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-lazy-videos-6832d6205141068be6c94993f8a6948a13bcf4d05bbb293f5fc2af59cc0cc172.map
I, [2024-02-07T09:57:12.515043 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js
I, [2024-02-07T09:57:12.516112 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-local-dates-c18813e741a7747622a6873b7f1de8b6c45f1533a603a24f2a018cd443fdc1f3.map
I, [2024-02-07T09:57:12.522278 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js
I, [2024-02-07T09:57:12.523101 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-narrative-bot-00cdd3eabafea37d524a9c9a3c1c1e727ee729f3c5b25a1ae0e43ad85b451ffd.map
I, [2024-02-07T09:57:12.530828 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js
I, [2024-02-07T09:57:12.531846 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-presence-e6e61f80036635f57d4b1319cf027210a0797d7c8af514273f941ad05d4366d0.map
I, [2024-02-07T09:57:12.543679 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js
I, [2024-02-07T09:57:12.544823 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/docker_manager_admin-1be63b922753aa8c941b2285d74440bcacf3ac1f8b38aed1b1f955d58c493070.map
I, [2024-02-07T09:57:12.551032 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js
I, [2024-02-07T09:57:12.551948 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/footnote-38ad4ddd96d53000e5606fa3bb10d539d237aa5d1367b32cfe2e7cf976c8b0a1.map
I, [2024-02-07T09:57:12.568343 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js
I, [2024-02-07T09:57:12.569433 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/poll-c38b44a06d721be7511061eda1e987daeb63ec660b3cd1585df7e20f0c5e035c.map
I, [2024-02-07T09:57:12.576083 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js
I, [2024-02-07T09:57:12.576972 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/spoiler-alert-c117d91598beb6e547891e4e9fb9c1d814ecb4547858e57c0f253e10f8ca0521.map
I, [2024-02-07T09:57:12.616918 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js
I, [2024-02-07T09:57:12.619886 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/styleguide-101ca23730c843d08fad554bf102779c495ce88eb84ac5536f8f1b092f843e14.map
I, [2024-02-07T09:57:12.636512 #3444]  INFO -- : Writing /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js
I, [2024-02-07T09:57:12.637551 #3444]  INFO -- : Writing /var/www/discourse/public/assets/print-page-b9a8366d333fa5ef54d14b5cfa40885b3aea3c8d49f7d332ccf7a42a250cdbba.map
I, [2024-02-07T09:57:12.662672 #3444]  INFO -- : Writing /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js
I, [2024-02-07T09:57:12.663722 #3444]  INFO -- : Writing /var/www/discourse/public/assets/publish-999a41b17ddf0224b00fc888ea37d6cbd4629b472676926122fe5206d5ba717b.map
I, [2024-02-07T09:57:12.674386 #3444]  INFO -- : Writing /var/www/discourse/public/assets/qunit-custom-23d2cc579f152b7ddd11e425e3eff4bcc80264f5bbc0494154e099810ed938fc.css
I, [2024-02-07T09:57:12.826484 #3444]  INFO -- : Writing /var/www/discourse/public/assets/qunit-03ec5e47030fa3064c6befc72bae7d8ac6ca3605370754cf3e0f7579980f50bf.css
I, [2024-02-07T09:57:12.836847 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js
I, [2024-02-07T09:57:12.845922 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js
I, [2024-02-07T09:57:12.855830 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
I, [2024-02-07T09:57:12.865006 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js
I, [2024-02-07T09:57:12.874325 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js
I, [2024-02-07T09:57:12.920728 #3444]  INFO -- : Writing /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js
I, [2024-02-07T09:57:12.921833 #3444]  INFO -- : Writing /var/www/discourse/public/assets/splash-screen-38153d76aa3609862ff8d5d5c04e41ba7280f21051bf82999734482adb7e8d4f.map
I, [2024-02-07T09:57:12.945788 #3444]  INFO -- : Writing /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js
I, [2024-02-07T09:57:12.946850 #3444]  INFO -- : Writing /var/www/discourse/public/assets/start-discourse-5d7f503971ee51084b839dabaf96da17c03351df51736ce06fb063b64e816149.map
I, [2024-02-07T09:57:13.120427 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js
I, [2024-02-07T09:57:13.122822 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-i18n-3d7e1954db574b8753bf00eded5e2e5dfc5c5c598b9ba2268aa85e424498a6c2.map
I, [2024-02-07T09:57:13.146986 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js
I, [2024-02-07T09:57:13.149836 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-site-settings-09fdd7327b1593bc2a3ad73cfe23a068ae8ae94213e0224f36b24767f44b06a8.map
I, [2024-02-07T09:57:13.284182 #3444]  INFO -- : Writing /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js
I, [2024-02-07T09:57:13.287444 #3444]  INFO -- : Writing /var/www/discourse/public/assets/vendor-9e7ee12d4e946d040429cc0640822ca10bb8a4099126d35f8dc8d3461b508026.map
I, [2024-02-07T09:57:13.313482 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js
I, [2024-02-07T09:57:13.314599 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js.map
I, [2024-02-07T09:57:13.321321 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js
I, [2024-02-07T09:57:13.322195 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js.map
I, [2024-02-07T09:57:13.339080 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js
I, [2024-02-07T09:57:13.340232 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js.map
I, [2024-02-07T09:57:13.347715 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js
I, [2024-02-07T09:57:13.348836 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js.map
I, [2024-02-07T09:57:13.362558 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js
I, [2024-02-07T09:57:13.363628 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js.map
I, [2024-02-07T09:57:13.371534 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js
I, [2024-02-07T09:57:13.372495 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js.map
I, [2024-02-07T09:57:13.386981 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js
I, [2024-02-07T09:57:13.388086 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js.map
I, [2024-02-07T09:57:13.395154 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js
I, [2024-02-07T09:57:13.396048 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js.map
I, [2024-02-07T09:57:13.414468 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js
I, [2024-02-07T09:57:13.415568 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js.map
I, [2024-02-07T09:57:13.423533 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js
I, [2024-02-07T09:57:13.424487 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js.map
I, [2024-02-07T09:57:13.430474 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js
I, [2024-02-07T09:57:13.431385 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js.map
I, [2024-02-07T09:57:13.435249 #3444]  INFO -- : Writing /var/www/discourse/public/assets/favicon-24b22a63aae0cf353d72b6b728504377bfc42edc6563f202e3a1401763497249.ico
I, [2024-02-07T09:57:13.438322 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-dev-0b53838dc1ee09248b94e3d4aa5c70d4a9897f26b8133d147e17bf8d41d3be7b.png
I, [2024-02-07T09:57:13.441108 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-single-dev-5545f7e0d4d1d1d5ba821a6d8c1e394033558324e90acc1c6045cf382b4880c8.png
I, [2024-02-07T09:57:13.443571 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-single-d7a0dacc998273856c42737dba8693fbdb9e5fd929d36afeb3f13844f147e865.png
I, [2024-02-07T09:57:13.446227 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-ba2f2da6eac779d8b34d4aa977be739e4de07f7d34e970f4b8ac32682706c122.png
I, [2024-02-07T09:57:13.452049 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/README-cd3d86d8264ad01fe0966bc06caabc962948261d4dc6e7b9e8749ea67e23fd42.md
I, [2024-02-07T09:57:13.454583 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/assigned-822196daa0f5cef80e0ba05c2a1731f61aa12b1f9efc83d3d13fab4e3d4d467c.png
I, [2024-02-07T09:57:13.457120 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/chat_mention-bbf06e5b63dac6c41418517847799a61d6fc389facc46c372dc25eb9d815f6f8.png
I, [2024-02-07T09:57:13.459560 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/chat_message-1665cc2e8f27e3409776bd96d51ad1483a3f325afe206528e1d0032b9e826687.png
I, [2024-02-07T09:57:13.463549 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/check-dd4b108020453fcfb68e0dfc5d8558dd3bca63988e48a9de1ef9c6e4772300b7.png
I, [2024-02-07T09:57:13.466120 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/discourse-bdbc548a4e328f39b017bb143b679c5dfe7b060574760cd71d77971c2a9eff1f.png
I, [2024-02-07T09:57:13.468754 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/group_mentioned-d8f97cc6b3933d27d9f87beba43e4281b59ea9a7bcd4280cfb023f606abfe15f.png
I, [2024-02-07T09:57:13.471309 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/linked-07ccda5efd10981a2deb5c4e7e8b395e250b6744e77736994c70dba426b5906d.png
I, [2024-02-07T09:57:13.473927 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/mentioned-d8f97cc6b3933d27d9f87beba43e4281b59ea9a7bcd4280cfb023f606abfe15f.png
I, [2024-02-07T09:57:13.476500 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/posted-05bfde0bc18cfa3ec1864e2a828614cfbc00e19545a71860fa19eca01db240fe.png
I, [2024-02-07T09:57:13.479032 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/private_message-7884f8d7291161e2ebb4a4c7ba6f1bf13310ba6a4265294aafb1c5a20782cbc8.png
I, [2024-02-07T09:57:13.482046 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/quoted-2133a9d118a10109b6d72f96918ff6bfa1529dd808600cbd280871d44d43cc75.png
I, [2024-02-07T09:57:13.484714 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/replied-05bfde0bc18cfa3ec1864e2a828614cfbc00e19545a71860fa19eca01db240fe.png
I, [2024-02-07T09:57:13.487339 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/watching_first_post-05bfde0bc18cfa3ec1864e2a828614cfbc00e19545a71860fa19eca01db240fe.png
Compressing: break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js
terser '/var/www/discourse/public/assets/_break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js' -m -c -o '/var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js > /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js.gz
part two
brotli -f --quality=11 /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js --output=/var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js.br
Done 'break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js' : 0.23 secs
Compressing: service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js
terser '/var/www/discourse/public/assets/_service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js' -m -c -o '/var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js > /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js --output=/var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js.br
Done 'service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js' : 0.24 secs
Compressing: locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js > /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js --output=/var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js.br
Done 'locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js' : 0.01 secs
Compressing: scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js > /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js --output=/var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.br
Done 'scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js' : 0.01 secs
Compressing: locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js > /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js --output=/var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js.br
Done 'locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js' : 0.12 secs
Compressing: locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js > /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js --output=/var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js.br
Done 'locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js' : 0.08 secs
Compressing: locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js > /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js --output=/var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js.br
Done 'locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js' : 0.11 secs
Compressing: locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js > /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js --output=/var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js.br
Done 'locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js' : 0.09 secs
Compressing: locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js > /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js --output=/var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js.br
Done 'locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js' : 0.09 secs
Compressing: locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js > /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js --output=/var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js.br
Done 'locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js' : 0.09 secs
Compressing: locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js > /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js --output=/var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js.br
Done 'locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js' : 0.09 secs
Compressing: locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js > /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js --output=/var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js.br
Done 'locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js' : 0.09 secs
Compressing: locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js > /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js --output=/var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js.br
Done 'locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js' : 0.11 secs
Compressing: locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js
terser '/var/www/discourse/public/assets/locales/_en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js' -m -c -o '/var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js' --source-map "base='/var/www/discourse/public/assets/locales',root='/assets/locales',url='en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js > /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js --output=/var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js.br
Done 'locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js' : 4.67 secs
Compressing: locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js
terser '/var/www/discourse/public/assets/locales/_en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js' -m -c -o '/var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js' --source-map "base='/var/www/discourse/public/assets/locales',root='/assets/locales',url='en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js > /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js --output=/var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js.br
Done 'locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js' : 4.56 secs
Compressing: locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js > /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js --output=/var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js.br
Done 'locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js' : 0.09 secs
Compressing: locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js > /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js --output=/var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js.br
Done 'locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js' : 0.09 secs
Compressing: locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js > /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js --output=/var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js.br
Done 'locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js' : 0.11 secs
Compressing: locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js > /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js --output=/var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js.br
Done 'locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js' : 0.09 secs
Compressing: locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js > /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js --output=/var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js.br
Done 'locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js' : 0.09 secs
Compressing: locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js > /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js --output=/var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js.br
Done 'locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js' : 0.09 secs
Compressing: locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js > /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js --output=/var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js.br
Done 'locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js' : 0.13 secs
Compressing: locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js > /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js --output=/var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js.br
Done 'locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js' : 0.08 secs
Compressing: locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js > /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js --output=/var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js.br
Done 'locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js' : 0.09 secs
Compressing: locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js > /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js --output=/var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js.br
Done 'locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js' : 0.1 secs
Compressing: locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js > /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js --output=/var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js.br
Done 'locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js' : 0.09 secs
Compressing: locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js > /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js --output=/var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js.br
Done 'locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js' : 0.09 secs
Compressing: locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js > /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js --output=/var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js.br
Done 'locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js' : 0.08 secs
Compressing: locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js > /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js --output=/var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js.br
Done 'locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js' : 0.08 secs
Compressing: locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js > /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js --output=/var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js.br
Done 'locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js' : 0.08 secs
Compressing: locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js > /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js --output=/var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js.br
Done 'locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js' : 0.09 secs
Compressing: locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js > /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js --output=/var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js.br
Done 'locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js' : 0.09 secs
Compressing: locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js > /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js --output=/var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js.br
Done 'locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js' : 0.09 secs
Compressing: locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js > /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js --output=/var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js.br
Done 'locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js' : 0.09 secs
Compressing: locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js > /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js --output=/var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js.br
Done 'locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js' : 0.09 secs
Compressing: locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js > /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js --output=/var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js.br
Done 'locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js' : 0.09 secs
Compressing: locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js > /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js --output=/var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js.br
Done 'locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js' : 0.09 secs
Compressing: locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js > /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js --output=/var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js.br
Done 'locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js' : 0.12 secs
Compressing: locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js > /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js --output=/var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js.br
Done 'locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js' : 0.08 secs
Compressing: locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js > /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js --output=/var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js.br
Done 'locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js' : 0.08 secs
Compressing: locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js > /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js --output=/var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js.br
Done 'locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js' : 0.09 secs
Compressing: locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js > /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js --output=/var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js.br
Done 'locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js' : 0.09 secs
Compressing: locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js > /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js --output=/var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js.br
Done 'locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js' : 0.09 secs
Compressing: locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js > /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js --output=/var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js.br
Done 'locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js' : 0.09 secs
Compressing: locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js > /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js --output=/var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js.br
Done 'locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js' : 0.09 secs
Compressing: locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js > /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js --output=/var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js.br
Done 'locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js' : 0.1 secs
Compressing: locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js > /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js --output=/var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js.br
Done 'locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js' : 0.09 secs
Compressing: locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js > /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js --output=/var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js.br
Done 'locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js' : 0.12 secs
Compressing: locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js > /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js --output=/var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js.br
Done 'locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js' : 0.1 secs
Compressing: locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js > /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js --output=/var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js.br
Done 'locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js' : 0.09 secs
Compressing: locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js > /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js --output=/var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js.br
Done 'locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js' : 0.08 secs
Compressing: locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js > /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js --output=/var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js.br
Done 'locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js' : 0.09 secs
Compressing: plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js
terser '/var/www/discourse/public/assets/plugins/_footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js' -m -c -o '/var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js > /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js --output=/var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js.br
Done 'plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js' : 0.5 secs
Compressing: activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js
gzip -f -c -9 /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js > /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js --output=/var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js.br
Done 'activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js' : 0.01 secs
Compressing: admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js
gzip -f -c -9 /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js > /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js --output=/var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js.br
Done 'admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js' : 0.1 secs
Compressing: auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js
gzip -f -c -9 /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js > /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js --output=/var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js.br
Done 'auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js' : 0.01 secs
Compressing: browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js
gzip -f -c -9 /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js > /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js --output=/var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js.br
Done 'browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js' : 0.01 secs
Compressing: browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js
gzip -f -c -9 /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js > /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js --output=/var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js.br
Done 'browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js' : 0.01 secs
Compressing: chunk.29563816297bab23578d.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js > /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.br
Done 'chunk.29563816297bab23578d.d41d8cd9.js' : 0.56 secs
Compressing: chunk.32579d39db9b922cbf59.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js > /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js.br
Done 'chunk.32579d39db9b922cbf59.d41d8cd9.js' : 0.01 secs
Compressing: chunk.400de55c235850808ecf.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js > /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js.br
Done 'chunk.400de55c235850808ecf.d41d8cd9.js' : 0.01 secs
Compressing: chunk.5dcc7f080d915da65582.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js > /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js.br
Done 'chunk.5dcc7f080d915da65582.d41d8cd9.js' : 0.01 secs
Compressing: chunk.5df408b55017d116a754.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js > /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js.br
Done 'chunk.5df408b55017d116a754.d41d8cd9.js' : 0.02 secs
Compressing: chunk.89013733dad766244082.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js > /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js.br
Done 'chunk.89013733dad766244082.d41d8cd9.js' : 0.01 secs
Compressing: chunk.899f6c640294036601c1.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js > /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js.br
Done 'chunk.899f6c640294036601c1.d41d8cd9.js' : 0.01 secs
Compressing: chunk.9c430abf9bff67e3096e.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js > /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js.br
Done 'chunk.9c430abf9bff67e3096e.d41d8cd9.js' : 0.06 secs
Compressing: chunk.cf19b316e63f3692ad55.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js > /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js.br
Done 'chunk.cf19b316e63f3692ad55.d41d8cd9.js' : 0.01 secs
Compressing: chunk.e364c4bb60ad86f543bb.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js > /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js.br
Done 'chunk.e364c4bb60ad86f543bb.d41d8cd9.js' : 0.01 secs
Compressing: chunk.e6715d7d674703ce9537.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js > /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js.br
Done 'chunk.e6715d7d674703ce9537.d41d8cd9.js' : 0.01 secs
Compressing: chunk.ebbf0472e39001e0eb82.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js > /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js.br
Done 'chunk.ebbf0472e39001e0eb82.d41d8cd9.js' : 0.01 secs
Compressing: chunk.fd1533f5879c37cf4984.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js > /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js.br
Done 'chunk.fd1533f5879c37cf4984.d41d8cd9.js' : 0.01 secs
Compressing: embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js
gzip -f -c -9 /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js > /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js --output=/var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js.br
Done 'embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js' : 0.01 secs
Compressing: google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js
gzip -f -c -9 /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js > /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js --output=/var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js.br
Done 'google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js' : 0.01 secs
Compressing: google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js
gzip -f -c -9 /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js > /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js --output=/var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js.br
Done 'google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js' : 0.01 secs
Compressing: google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js
gzip -f -c -9 /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js > /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js --output=/var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js.br
Done 'google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js' : 0.01 secs
Compressing: onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js
gzip -f -c -9 /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js > /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js --output=/var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js.br
Done 'onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js' : 0.01 secs
Compressing: plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js > /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js --output=/var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js.br
Done 'plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js' : 0.07 secs
Compressing: plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js > /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js --output=/var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js.br
Done 'plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js' : 0.01 secs
Compressing: plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js > /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js --output=/var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js.br
Done 'plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js' : 0.01 secs
Compressing: plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js > /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js --output=/var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js.br
Done 'plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js' : 0.01 secs
Compressing: plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js > /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js --output=/var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js.br
Done 'plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js' : 0.01 secs
Compressing: plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js > /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js --output=/var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js.br
Done 'plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js' : 0.01 secs
Compressing: plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js > /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js --output=/var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js.br
Done 'plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js' : 0.01 secs
Compressing: plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js > /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js --output=/var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js.br
Done 'plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js' : 0.01 secs
Compressing: plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js > /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js --output=/var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js.br
Done 'plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js' : 0.01 secs
Compressing: plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js > /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js --output=/var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js.br
Done 'plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js' : 0.01 secs
Compressing: plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js > /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js --output=/var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js.br
Done 'plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js' : 0.01 secs
Compressing: plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js > /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js --output=/var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js.br
Done 'plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js' : 0.02 secs
Compressing: print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js
gzip -f -c -9 /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js > /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js --output=/var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js.br
Done 'print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js' : 0.01 secs
Compressing: publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js
gzip -f -c -9 /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js > /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js --output=/var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js.br
Done 'publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js' : 0.01 secs
Compressing: scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js > /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js --output=/var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js.br
Done 'scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js' : 0.01 secs
Compressing: scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js > /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js --output=/var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js.br
Done 'scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js' : 0.01 secs
Compressing: scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js > /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js --output=/var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.br
Done 'scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js' : 0.01 secs
Compressing: scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js > /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js --output=/var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js.br
Done 'scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js' : 0.01 secs
Compressing: scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js > /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js --output=/var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js.br
Done 'scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js' : 0.01 secs
Compressing: splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js
gzip -f -c -9 /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js > /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js --output=/var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js.br
Done 'splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js' : 0.01 secs
Compressing: start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js
gzip -f -c -9 /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js > /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js --output=/var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js.br
Done 'start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js' : 0.01 secs
Compressing: test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js
gzip -f -c -9 /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js > /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js --output=/var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js.br
Done 'test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js' : 0.09 secs
Compressing: test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js
gzip -f -c -9 /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js > /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js --output=/var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js.br
Done 'test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js' : 0.01 secs
Compressing: vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js
gzip -f -c -9 /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js > /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js --output=/var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js.br
Done 'vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js' : 0.06 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js.br
part 3
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js' : 0.01 secs
Done 'Done compressing all JS files' : 15.84 secs
Start compiling CSS: 2024-02-07 09:57:38 UTC
Compiling CSS for default 2024-02-07 09:57:38 UTC
precompile target: desktop
precompile target: mobile
precompile target: admin
precompile target: wizard
precompile target: desktop_rtl
precompile target: mobile_rtl
precompile target: admin_rtl
precompile target: wizard_rtl
precompile target: chat
precompile target: checklist
precompile target: discourse-details
precompile target: discourse-lazy-videos
precompile target: discourse-local-dates
precompile target: discourse-narrative-bot
precompile target: discourse-presence
precompile target: docker_manager
precompile target: footnote
precompile target: poll
precompile target: spoiler-alert
precompile target: chat_mobile
precompile target: chat_desktop
precompile target: poll_desktop
precompile target: chat_rtl
precompile target: checklist_rtl
precompile target: discourse-details_rtl
precompile target: discourse-lazy-videos_rtl
precompile target: discourse-local-dates_rtl
precompile target: discourse-narrative-bot_rtl
precompile target: discourse-presence_rtl
precompile target: docker_manager_rtl
precompile target: footnote_rtl
precompile target: poll_rtl
precompile target: spoiler-alert_rtl
precompile target: chat_mobile_rtl
precompile target: chat_desktop_rtl
precompile target: poll_desktop_rtl
precompile target: desktop_theme Default
precompile target: mobile_theme Default
precompile target: color_definitions Default (Solarized Dark)
precompile target: color_definitions Default (Dark)
precompile target: color_definitions Default (WCAG Light)
precompile target: color_definitions Default (WCAG Dark)
precompile target: color_definitions Default (Dracula)
precompile target: color_definitions Default (Solarized Light)
precompile target: color_definitions Default (Base)
Done compiling CSS: 2024-02-07 09:57:45 UTC
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
    filename = File.basename(gz_file.path)
        from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
I, [2024-02-07T09:57:45.765426 #1]  INFO -- : yarn run v1.22.19
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build
Building
Environment: development
WARNING: ember-test-selectors: You are using an unsupported ember-cli-babel version. data-test properties are not automatically stripped from your JS code.
building...
...[ConfigLoader]
...[Babel: @embroider/macros > applyPatches]
...[Babel: discourse-widget-hbs > applyPatches]
...[Babel: ember-source > applyPatches]
...[ember.js]
...[Babel: @glimmer/component > applyPatches]
...[Babel: pretty-text > applyPatches]
...[Babel: discourse-common > applyPatches]
...[Babel: truth-helpers > applyPatches]
...[Babel: @ember/render-modifiers > applyPatches]
...[Babel: @ember/test-waiters > applyPatches]
...[Babel: ember-destroyable-polyfill > applyPatches]
...[Babel: ember-this-fallback > applyPatches]
...[Babel: ember-cached-decorator-polyfill > applyPatches]
...[Babel: ember-load-initializers > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
...[SourceMapConcat]
...[Babel: discourse > applyPatches]
...[Babel: discourse-plugins > applyPatches]
cleaning up
cleaning up...
Built project successfully. Stored in "dist/".
File sizes:
 - dist/assets/activate-account.js: 600 B (343 B gzipped)
 - dist/assets/admin.js: 1.06 MB (159.84 kB gzipped)
 - dist/assets/auto-redirect.js: 175 B (157 B gzipped)
 - dist/assets/browser-detect.js: 425 B (300 B gzipped)
 - dist/assets/browser-update.js: 1.51 kB (862 B gzipped)
 - dist/assets/chunk.29563816297bab23578d.d41d8cd9.js: 4.4 MB (990.44 kB gzipped)
 - dist/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js: 46.79 kB (15.36 kB gzipped)
 - dist/assets/chunk.400de55c235850808ecf.d41d8cd9.js: 149 B (137 B gzipped)
 - dist/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js: 4.06 kB (1.82 kB gzipped)
 - dist/assets/chunk.5df408b55017d116a754.d41d8cd9.js: 126.09 kB (50.68 kB gzipped)
 - dist/assets/chunk.89013733dad766244082.css: 20.97 kB (4.87 kB gzipped)
 - dist/assets/chunk.89013733dad766244082.d41d8cd9.js: 211 B (189 B gzipped)
 - dist/assets/chunk.899f6c640294036601c1.d41d8cd9.js: 58.76 kB (10.29 kB gzipped)
 - dist/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js: 447.97 kB (119.69 kB gzipped)
 - dist/assets/chunk.9ebd5cbc071c2d3f5cf7.css: 70.35 kB (12.39 kB gzipped)
 - dist/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js: 57.28 kB (17.43 kB gzipped)
 - dist/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js: 21.3 kB (8.22 kB gzipped)
 - dist/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js: 6.54 kB (2.66 kB gzipped)
 - dist/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js: 6.67 kB (2.52 kB gzipped)
 - dist/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js: 209 B (187 B gzipped)
 - dist/assets/discourse.css: 171 B (157 B gzipped)
 - dist/assets/discourse.d41d8cd98f00b204e9800998ecf8427e.css: 0 B
 - dist/assets/embed-application.js: 1.19 kB (579 B gzipped)
 - dist/assets/google-tag-manager.js: 526 B (357 B gzipped)
 - dist/assets/google-universal-analytics-v3.js: 654 B (404 B gzipped)
 - dist/assets/google-universal-analytics-v4.js: 461 B (298 B gzipped)
 - dist/assets/onpopstate-handler.js: 157 B (143 B gzipped)
 - dist/assets/plugins/chat.js: 950.94 kB (147.99 kB gzipped)
 - dist/assets/plugins/checklist.js: 3.66 kB (1.71 kB gzipped)
 - dist/assets/plugins/discourse-details.js: 1.25 kB (614 B gzipped)
 - dist/assets/plugins/discourse-lazy-videos.js: 6.7 kB (2.37 kB gzipped)
 - dist/assets/plugins/discourse-local-dates.js: 33.3 kB (8.95 kB gzipped)
 - dist/assets/plugins/discourse-narrative-bot.js: 1.7 kB (788 B gzipped)
 - dist/assets/plugins/discourse-presence.js: 11.25 kB (2.66 kB gzipped)
 - dist/assets/plugins/docker_manager_admin.js: 38.28 kB (7.45 kB gzipped)
 - dist/assets/plugins/footnote.js: 2.6 kB (1.17 kB gzipped)
 - dist/assets/plugins/poll.js: 63.62 kB (16.4 kB gzipped)
 - dist/assets/plugins/spoiler-alert.js: 3.24 kB (1.38 kB gzipped)
 - dist/assets/plugins/styleguide.js: 153.9 kB (21.41 kB gzipped)
 - dist/assets/print-page.js: 111 B (124 B gzipped)
 - dist/assets/publish.js: 294 B (213 B gzipped)
 - dist/assets/qunit-custom.css: 2.56 kB (746 B gzipped)
 - dist/assets/qunit.css: 887.96 kB (126.39 kB gzipped)
 - dist/assets/scripts/discourse-boot.js: 866 B (511 B gzipped)
 - dist/assets/scripts/discourse-test-listen-boot.js: 122 B (106 B gzipped)
 - dist/assets/scripts/discourse-test-load-dynamic-js.js: 1.14 kB (599 B gzipped)
 - dist/assets/scripts/discourse-test-trigger-ember-cli-boot.js: 122 B (106 B gzipped)
 - dist/assets/scripts/module-shims.js: 1.95 kB (883 B gzipped)
 - dist/assets/scripts/start-app.js: 220 B (177 B gzipped)
 - dist/assets/splash-screen.js: 1.17 kB (551 B gzipped)
 - dist/assets/start-discourse.js: 518 B (345 B gzipped)
 - dist/assets/test-i18n.js: 569.58 kB (134.8 kB gzipped)
 - dist/assets/test-site-settings.js: 12.37 kB (4.61 kB gzipped)
 - dist/assets/vendor.f196a698a6a811ae0583c1ea5284644b.js: 450.66 kB (126.63 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js: 6.93 kB (1.79 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js: 603 B (354 B gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js: 37.73 kB (8.89 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js: 3.13 kB (1.46 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js: 32.82 kB (8.82 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js: 6.37 kB (2.51 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js: 33.29 kB (7.73 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js: 3.5 kB (1.47 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js: 52.47 kB (10.13 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js: 6.88 kB (2.29 kB gzipped)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js: 1.36 kB (749 B gzipped)
 - dist/javascripts/@json-editor/json-editor/2.10.0/jsoneditor.js: 523.75 kB (99.29 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/ace.js: 371.81 kB (101.02 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/ext-searchbox.js: 11.91 kB (3.57 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-html.js: 60.88 kB (18.24 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-scss.js: 24.03 kB (7.98 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-sql.js: 4.84 kB (1.86 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-yaml.js: 5.09 kB (1.77 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/theme-chaos.js: 3.18 kB (1.04 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/theme-chrome.js: 3.04 kB (1.06 kB gzipped)
 - dist/javascripts/ace.js/1.4.13/worker-html.js: 208.1 kB (47.44 kB gzipped)
 - dist/javascripts/ace/ace.js: 370.75 kB (100.77 kB gzipped)
 - dist/javascripts/ace/ext-searchbox.js: 11.91 kB (3.57 kB gzipped)
 - dist/javascripts/ace/mode-html.js: 60.88 kB (18.24 kB gzipped)
 - dist/javascripts/ace/mode-scss.js: 24.03 kB (7.98 kB gzipped)
 - dist/javascripts/ace/mode-sql.js: 2.21 kB (1.01 kB gzipped)
 - dist/javascripts/ace/mode-yaml.js: 5.09 kB (1.77 kB gzipped)
 - dist/javascripts/ace/theme-chrome.js: 3.04 kB (1.06 kB gzipped)
 - dist/javascripts/ace/worker-html.js: 208.1 kB (47.44 kB gzipped)
 - dist/javascripts/chart.js/3.5.1/chart.min.js: 188.37 kB (65.2 kB gzipped)
 - dist/javascripts/chartjs-plugin-datalabels/2.2.0/chartjs-plugin-datalabels.min.js: 12.94 kB (5.24 kB gzipped)
 - dist/javascripts/count.js: 1.44 kB (636 B gzipped)
 - dist/javascripts/diffhtml/1.0.0-beta.30/diffhtml.min.js: 22.41 kB (8.53 kB gzipped)
 - dist/javascripts/embed-topics.js: 1.34 kB (630 B gzipped)
 - dist/javascripts/embed.js: 2.47 kB (1.01 kB gzipped)
 - dist/javascripts/magnific-popup/1.1.0/jquery.magnific-popup.min.js: 20.22 kB (7.35 kB gzipped)
 - dist/javascripts/media-optimization-worker.js: 5.01 kB (1.75 kB gzipped)
 - dist/javascripts/pikaday/1.8.2/pikaday.js: 42.54 kB (9.66 kB gzipped)
 - dist/javascripts/squoosh/mozjpeg_enc.js: 39.03 kB (10.74 kB gzipped)
 - dist/javascripts/squoosh/squoosh_resize.js: 4.53 kB (1.29 kB gzipped)
Done in 295.21s.
Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
I, [2024-02-07T09:57:45.856251 #1]  INFO -- : Terminating async processes
I, [2024-02-07T09:57:45.861977 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2024-02-07T09:57:45.864780 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
2024-02-07 09:57:45.863 UTC [42] LOG:  received fast shutdown request
111:signal-handler (1707299865) Received SIGTERM scheduling shutdown...
2024-02-07 09:57:45.870 UTC [42] LOG:  aborting any active transactions
2024-02-07 09:57:45.888 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-02-07 09:57:45.893 UTC [46] LOG:  shutting down
111:M 07 Feb 2024 09:57:45.904 # User requested shutdown...
111:M 07 Feb 2024 09:57:45.904 * Saving the final RDB snapshot before exiting.
2024-02-07 09:57:45.997 UTC [42] LOG:  database system is shut down
111:M 07 Feb 2024 09:57:46.277 * DB saved on disk
111:M 07 Feb 2024 09:57:46.277 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3342 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
2a12c656e06b5582a2cb414e35e7be3ce5f412fc3b8af27b83d61532c9595a73
Looks like a maxmindb config issue, or plugin issue? Can you remove that part of your config? (It’s just IP address geolocation, fairly optional for most people, and you can add it back once it’s clear what the problem is.)
@Ed_S Thank you for taking time to responding to my queries. i really appricate it.
i uncommented the maxmind then made a rebuild and here are the results:
I am aming for a clean server as possible without errors
htop for 1 min after isntallation if it helps
download url for video (8mb) https://global.discourse-cdn.com/meta/original/4X/2/c/7/2c72c17a42dfa11c6c2745c20ab12fb940db2806.mp4
I think that’s success - looks good to me. Hopefully you can access your forum successfully.
And if so, it does seem, then, that there’s something wrong in the area of maxmindb. I don’t have any expertise with that, hopefully someone can say more.
some of the errors from the pastetbin:
111:M 07 Feb 2024 10:59:07.639 # WARNING Your system is configured to use the 'xen' clocksource which might lead to degraded performance. Check the result of the [slow-clocksource] system check: run 'redis-server --check-system' to check if the system's clocksource isn't degrading performance.
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has unmet peer dependency "@typescript-eslint/parser@^6.15.0".
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has incorrect peer dependency "typescript@^5.3.3".
warning " > @glint/environment-ember-loose@1.3.0" has unmet peer dependency "@glimmer/component@^1.1.2".
I, [2024-02-07T10:59:37.634934 #1]  INFO -- :
I, [2024-02-07T10:59:37.635504 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning Pattern ["wrap-ansi@^7.0.0"] is trying to unpack in the same destination "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/node_modules/wrap-ansi-cjs" as pattern ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. This could result in non-deterministic behavior, skipping.
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
is their anything i can do to resolve these errors
It would be nice to see fewer warnings! Especially when they are WARNINGs. It might be worth a new thread for that. I think the answer is likely to be that they are harmless and not a priority. But it’s always possible that they are not harmless.
If the forum appears to work, that’s a good sign.
For the warning about xen clocksource, perhaps see
I will try to change the clocksource to tsc and see if redis/discourse is more happy.
Im unsure how i am going to solve the missing npm packages, i dont know if it will give sense to run them manually or if their is any discourse config file which will override something.. can u give me any hint?
I think what’s probably happening is not that anything is missing, but that the versions of things are not quite right, to make everything happy. I can’t be sure. It looks like my installation does have rsvp 4.8.5… as well as several other versions:
root@ubuntu-2gb-nbg1-1:~# egrep -h rsvp `find / -xdev -name yarn-error.log` | egrep -B1 resolved
  "@types/rsvp@*", "@types/rsvp@^4.0.2":
    resolved "https://registry.yarnpkg.com/@types/rsvp/-/rsvp-4.0.2.tgz#bf9f72eaa6771292638a85bb8ce1db97e754b371"
  rsvp@^3.0.14, rsvp@^3.0.17, rsvp@^3.0.18, rsvp@^3.0.21, rsvp@^3.0.6, rsvp@^3.1.0, rsvp@^3.3.3, rsvp@^3.5.0:
    resolved "https://registry.yarnpkg.com/rsvp/-/rsvp-3.6.2.tgz#2e96491599a96cde1b515d5674a8f7a91452926a"
  rsvp@^4.7.0, rsvp@^4.8.1, rsvp@^4.8.2, rsvp@^4.8.3, rsvp@^4.8.4, rsvp@^4.8.5:
    resolved "https://registry.yarnpkg.com/rsvp/-/rsvp-4.8.5.tgz#c8f155311d167f68f21e168df71ec5b083113734"
  rsvp@~3.2.1:
    resolved "https://registry.yarnpkg.com/rsvp/-/rsvp-3.2.1.tgz#07cb4a5df25add9e826ebc67dcc9fd89db27d84a"
  rsvp@~3.2.1:
