I’ve followed the LetsEncrypt installation procedure for installing SSL for my website.
What I did:
- Created an image of the original Discourse forum (EC2 AMI)
- Launched it again
- Checked that it works (it did)
- Followed the installation procedure and rebuilt the app
- Tried to access the app via HTTPS and also via HTTP, neither worked. I got "“This site can’t be reached” error in Chrome
In the logs:
nginx: [emerg] PEM_read_bio_X509_AUX("/shared/ssl/sub.domain.com.cer") failed (SSL: error:0906D06C:PEM routines: PEM_read_bio_no start line: Expecting: TRUSTED CERTIFICATE)
That error repeat itself several times in the log.
When I check the certificate in the /var/discourse/shared/standalone/ssl directory, I see that it is empty.
I also checked the acme.sh.log and there is shows:
Invalid response from http://forum.example.com/.well-known/acme-challenge/xxxxxxxxxxxx-xxxxxxx
I believe that during that command, the server wasn’t accessible via HTTP as it wasn’t even available after the rebuild of the app as well.
I have root access to the AWS EC2 server via SSH.
Help would be greatly appreciated. Thanks.
