Error setting up new discourse website
I’m stuck here, what am I doing wrong? :confounded:
You forgot to configure DNS, there is no A entry for quemuse.com.
Thanks for the quick reply.
What are the values needed for the A record?
We cover that in the install guide.
The answer there should be your server IP.
Thanks! But now this error popped out of nowhere. Ideas?
Remove all unofficial plugins and rebuild. If the error persists after a rebuild, check the logs (rebuild logs and app or logs).
