Parseerfout bij _theme_qunit_helper bij het upgraden van 2.7.0.beta7 naar 2.7.0.beta9
It’s time for my periodic Discouse upgrade failure…
2.7.0.beta7 to 2.7.0.beta9
I upgraded the Docker Manager app via the web console without issue.
I then started the upgrade of the main app which was going fine until this occurred:
2417659.54670619 Compressing: discourse/tests/theme_qunit_helper-205cf3e536cd4118ac1b02aec22cd3f45e8f74826fa96abeb697c0243882e5d2.js
uglifyjs '/var/www/discourse/public/assets/discourse/tests/_theme_qunit_helper-205cf3e536cd4118ac1b02aec22cd3f45e8f74826fa96abeb697c0243882e5d2.js' -m -c -o '/var/www/discourse/public/assets/discourse/tests/theme_qunit_helper-205cf3e536cd4118ac1b02aec22cd3f45e8f74826fa96abeb697c0243882e5d2.js' --source-map "base='/var/www/discourse/public/assets/discourse/tests',root='/assets/discourse/tests',url='/assets/discourse/tests/theme_qunit_helper-205cf3e536cd4118ac1b02aec22cd3f45e8f74826fa96abeb697c0243882e5d2.js.map'"
Parse error at _theme_qunit_helper-205cf3e536cd4118ac1b02aec22cd3f45e8f74826fa96abeb697c0243882e5d2.js:27887,17
define("sinon", () => {
ERROR: Unexpected token: punc «)»
    at JS_Parse_Error.get (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:18:1), <anonymous>:71:23)
    at fatal (/usr/lib/node_modules/uglify-js/bin/uglifyjs:409:27)
    at run (/usr/lib/node_modules/uglify-js/bin/uglifyjs:347:9)
    at Object.<anonymous> (/usr/lib/node_modules/uglify-js/bin/uglifyjs:261:5)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
rake aborted!
Errno::ENOENT: No such file or directory @ rb_file_s_size - /var/www/discourse/public/assets/discourse/tests/theme_qunit_helper-205cf3e536cd4118ac1b02aec22cd3f45e8f74826fa96abeb697c0243882e5d2.js
/var/www/discourse/lib/tasks/assets.rake:290:in `size'
/var/www/discourse/lib/tasks/assets.rake:290:in `block (4 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:181:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:281:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:272:in `each'
/var/www/discourse/lib/tasks/assets.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:181:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:269:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:196:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:104:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:59:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.5/lib/rails/commands/runner/runner_command.rb:42:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.5/lib/rails/command/base.rb:69:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.5/lib/rails/command.rb:46:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.5/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.3/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
bin/rails:17:in `<main>'
Spinning up 2 Unicorn worker(s) that were stopped initially
Does anyone have any tips on how I might go figuring this out? Was this another one of those upgrades that is meant to be done via the CLI even though the web interface supports it, for example? (That has bitten me before)
Thanks!
Ah yes indeed, it seems it was the 2.7.0.beta8 that required a manual rebuild as per 2.7.0.beta8: Share Topic Modal Improvements, Searchable User Fields, Pause Animated Images, and more
It’s strange that I only get to see the ’ You are running an old version of the Discourse image. Upgrades via the web UI are disabled until you run the latest image.’ page at /admin/upgrade after I’m allowed to try it via the web interface and it fails spectacularly. If it appeared first like that, I wouldn’t (couldn’t!) have tried… I was sure it used to work this way… anyway, all fixed :slight_smile:
