我在升级到 3.5.0.beta3-dev 时收到了 Discourse 安装错误:
Discourse 无法启动。非常感谢任何建议。
Status: Image is up to date for discourse/base:2.0.20250226-0128
I, [2025-04-18T15:16:34.677745 #1] INFO -- : cd /var/www/discourse & su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2025-04-18T15:16:40.775977 #1] INFO -- : discourse-bbcode-color is already at latest compatible version
discourse-cakeday is already at latest compatible version
discourse-chat-integration is already at latest compatible version
discourse-data-explorer is already at latest compatible version
discourse-math is already at latest compatible version
discourse-oauth2-basic is already at latest compatible version
discourse-rss-polling is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-whos-online is already at latest compatible version
discourse-yearly-review is already at latest compatible version
docker_manager is already at latest compatible version
错误:
I, [2025-04-18T15:16:50.782650 #1] INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate'
2025-04-18 15:16:59.705 UTC [911] discourse@discourse ERROR: null value in column "answer_post_id" of relation "discourse_solved_solved_topics" violates not-null constraint
2025-04-18 15:16:59.705 UTC [911] discourse@discourse DETAIL: Failing row contains (768, 16673, null, -1, null, 2021-05-10 18:32:53.008822, 2021-05-10 18:32:53.008822).
2025-04-18 15:16:59.705 UTC [911] discourse@discourse STATEMENT: INSERT INTO discourse_solved_solved_topics (
topic_id,
answer_post_id,
topic_timer_id,
accepter_user_id,
created_at,
updated_at
SELECT
tc.topic_id,
tc.answer_post_id,
tc.topic_timer_id,
tc.accepter_user_id,
tc.created_at,
tc.updated_at
FROM (
SELECT
tc.topic_id,
CAST(tc.value AS INTEGER) AS answer_post_id,
CAST(tc2.value AS INTEGER) AS topic_timer_id,
COALESCE(ua.acting_user_id, -1) AS accepter_user_id,
tc.created_at,
tc.updated_at,
ROW_NUMBER() OVER (PARTITION BY tc.topic_id ORDER BY tc.created_at ASC) AS rn_topic,
ROW_NUMBER() OVER (PARTITION BY CAST(tc.value AS INTEGER) ORDER BY tc.created_at ASC) AS rn_answer
FROM topic_custom_fields tc
LEFT JOIN topic_custom_fields tc2 ON tc2.topic_id = tc.topic_id AND tc2.name = 'solved_auto_close_topic_timer_id'
LEFT JOIN user_actions ua ON ua.target_topic_id = tc.topic_id AND ua.action_type = 15
WHERE tc.name = 'accepted_answer_post_id'
AND tc.id > 0
AND tc.id <= 0 + 10000
) tc
WHERE tc.rn_topic = 1 AND tc.rn_answer = 1
ON CONFLICT DO NOTHING
rake aborted!
StandardError: An error has occurred, all later migrations canceled: (StandardError)
