최신 버전으로 Discourse 업데이트 시 오류 발생 - db:migrate 문제 가능성
최신 버전으로 Discourse 인스턴스를 업데이트하려는 시도에 로그에서 다음 오류를 확인하고 있습니다:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 5195 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
STDERR: From https://github.com/discourse/pups
   17f04ec..e0ff889  master     -> origin/master
 * [new branch]      main       -> origin/main
 * [new tag]         v1.1.1     -> v1.1.1
 * [new tag]         v1.1.0     -> v1.1.0
Note: checking out 'v1.0.3'.
위로 스크롤하면 다음 내용을 볼 수 있습니다:
More Logs
Ran /var/discourse/launcher rebuild app returned 1
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/mixlib-shellout-2.4.0/lib/mixlib/shellout.rb:297:in `invalid!'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/mixlib-shellout-2.4.0/lib/mixlib/shellout.rb:284:in `error!'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/mixin/shell_out.rb:202:in `shell_out_compacted!'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/mixin/shell_out.rb:124:in `shell_out!'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/provider/execute.rb:58:in `block in action_run'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/mixin/why_run.rb:51:in `add_action'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/provider.rb:227:in `converge_by'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/provider/execute.rb:56:in `action_run'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/provider.rb:182:in `run_action'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource.rb:578:in `run_action'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:70:in `run_action'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:78:in `block in run_action'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:76:in `each'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:76:in `run_action'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:98:in `block (2 levels) in converge'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:98:in `each'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:98:in `block in converge'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource_collection/resource_list.rb:94:in `block in execute_each_resource'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource_collection/stepable_iterator.rb:114:in `call_iterator_block'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource_collection/stepable_iterator.rb:85:in `step'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource_collection/stepable_iterator.rb:103:in `iterate'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource_collection/stepable_iterator.rb:55:in `each_with_index'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/resource_collection/resource_list.rb:92:in `execute_each_resource'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/runner.rb:97:in `converge'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/client.rb:720:in `block in converge'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/client.rb:715:in `catch'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/client.rb:715:in `converge'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/client.rb:754:in `converge_and_save'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/client.rb:286:in `run'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/application.rb:303:in `run_with_graceful_exit_option'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-patch-0.0.0/lib/chef/application.rb:30:in `block in run_chef_client'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/local_mode.rb:44:in `with_server_connectivity'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-patch-0.0.0/lib/chef/application.rb:11:in `run_chef_client'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/application/client.rb:440:in `run_application'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/lib/chef/application.rb:66:in `run'
/opt/chef/embedded/lib/ruby/gems/2.5.0/gems/chef-14.7.17/bin/chef-client:25:in `<top (required)>'
/opt/chef/embedded/bin/chef-client:23:in `load'
/opt/chef/embedded/bin/chef-client:23:in `<main>'
>>>> Caused by Mixlib::ShellOut::ShellCommandFailed: Expected process to exit with [0], but received '1'
---- Begin output of /var/discourse/launcher rebuild app ----
STDOUT: WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20210528-1735: Pulling from discourse/base
69692152171a: Pulling fs layer
caccdbcee96e: Pulling fs layer
69692152171a: Verifying Checksum
69692152171a: Download complete
69692152171a: Pull complete
caccdbcee96e: Verifying Checksum
caccdbcee96e: Download complete
caccdbcee96e: Pull complete
Digest: sha256:b1890ab83b905ada5c9b7221264d62159bbf63bda706cdc652b0533bc90431c5
Status: Downloaded newer image for discourse/base:2.0.20210528-1735
docker.io/discourse/base:2.0.20210528-1735
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
Updating 17f04ec..e0ff889
Fast-forward
 .github/workflows/ci.yml     |  29 ++++++
 .github/workflows/lint.yml   |  27 +++++
 .rubocop.yml                 |   3 +
 Gemfile                      |   2 +
 Guardfile                    |   4 +-
 README.md                    |  21 ++++
 Rakefile                     |  14 +--
 bin/pups                     |   8 +-
 lib/pups.rb                  |  32 ++++--
 lib/pups/cli.rb              |  92 ++++++++++-------
 lib/pups/command.rb          |  25 +++--
 lib/pups/config.rb           | 240 +++++++++++++++++++++++--------------------
 lib/pups/docker.rb           |  69 +++++++++++++
 lib/pups/exec_command.rb     | 182 ++++++++++++++++----------------
 lib/pups/file_command.rb     |  60 +++++------
 lib/pups/merge_command.rb    |  94 ++++++++---------
 lib/pups/replace_command.rb  |  70 +++++++------
 lib/pups/runit.rb            |  47 +++++----
 lib/pups/version.rb          |   4 +-
 pups.gemspec                 |  37 ++++---
 test/cli_test.rb             | 102 +++++++++++++++---
 test/config_test.rb          | 215 ++++++++++++++++++++++++++++----------
 test/docker_test.rb          | 157 ++++++++++++++++++++++++++++
 test/exec_command_test.rb    |  62 ++++++-----
 test/file_command_test.rb    |  17 ++-
 test/merge_command_test.rb   |  64 ++++++------
 test/replace_command_test.rb |  86 ++++++++--------
 test/test_helper.rb          |   2 +
 28 files changed, 1158 insertions(+), 607 deletions(-)
 create mode 100644 .github/workflows/ci.yml
 create mode 100644 .github/workflows/lint.yml
 create mode 100644 .rubocop.yml
 create mode 100644 lib/pups/docker.rb
 create mode 100644 test/docker_test.rb
우리는 자체적으로 몇 가지 트러블슈팅을 해보았지만, 이전에 이런 문제를 만난 적이 없어 어떤 문제인지 파악하는 데 어려움을 겪고 있습니다. 다른 분들도 이 문제를 경험해 보셨나요?
이것은 bitnami 설치인가요? Bitnami 설치 문제 해결을 참고해 주세요.
Bitnami 설치 방식이 아닙니다. 링크 공유해 주셔서 감사합니다.
하지만 표준 설치는 아닌 것 같네요?
맞습니다, 표준 구성이 아닙니다. 비표준 구성을 사용 중인 다른 분들도 비슷한 문제를 경험해 보았는지 확인해 보려고 했습니다.
결국 문제를 해결했으며, 그 중 하나의 해결책은 Redis 6.2로 업데이트하는 것이었습니다.
