Error with code blocks: 403 Forbidden
The discussion revolves around an issue with code blocks in Discourse, resulting in a 403 Forbidden error. gkaf89 describes the problem, which includes creating or editing posts with code blocks, Markdown code highlighting, and inline code segments.
nat suggests that the issue might be related to authorization restrictions, such as posting in a restricted category or using a restricted tag, and recommends checking with the moderator.
supermathie agrees with nat but strongly suspects that the 403 Forbidden error is caused by an overzealous Web Application Firewall (WAF) flagging the code blocks as shellcode or an injection attack. He notes that the instance is fronted by a WAF and recommends inspecting the error headers to determine the source of the rejection.
I recently took on the management of discourse server, and there are a few issues.
  1. I have persistent issues when trying to create or edit a post with code blocks. When trying to create or edit a post with the code block
(access node)$ spack list openfoam@2306
Variants:
    Name [Default]            When    Allowed values    Description
    build_system [generic]    --      generic           Build systems supported by the package
    int64 [off]               --      on, off           With 64-bit labels
    kahip [off]               --      on, off           With kahip decomposition
    knl [off]                 --      on, off           Use KNL compiler settings
    metis [off]               --      on, off           With metis decomposition
    mgridgen [off]            --      on, off           With mgridgen support
    paraview [off]            --      on, off           Build paraview plugins and runtime post-processing
    precision [dp]            --      sp, dp, spdp      Precision option
    scotch [on]               --      on, off           With scotch/ptscotch decomposition
    source [on]               --      on, off           Install library/application sources and tutorials
    vtk [off]                 --      on, off           With VTK runTimePostProcessing
    zoltan [off]              --      on, off           With zoltan renumbering
I get an error 403 Forbidden.
  1. Markdown does not support code highlighting adding any syntax specification results in an error 403 Forbidden.
  2. Inline code segments also cause 403 Forbidden in some but not all locations, relative to other code blocks.
The installed version is 3.1.1 ( 0612f0d5b6 ).
Are these issues related, and what could be causing this behavior?
Example post: Compiling OpenFOAM with Spack - 📚 Knowledge nuggets - HPC discourse
Intended result:
There are some issues when installing OpenFOAM of OpenCFD with Spack.
An environment was set up to manage the packages with Spack following the instruction in the UL HPC tutorial. In short, the following dependencies where defined for the SPACK packages,
(access node)$ cat << EOF >> $SPACK_ROOT/etc/spack/packages.yaml
packages:
    slurm:
        externals:
        - spec: slurm@22.05.5
          prefix: /usr
        buildable: False
    libevent:
        externals:
        - spec: libevent@2.1.8
          prefix: /usr
        buildable: False
    pmix:
        externals:
        - spec: pmix@4.2.3
          prefix: /usr
        buildable: False
    hwloc:
        externals:
        - spec: hwloc@2.2.0
          prefix: /usr
        buildable: False
EOF
and the following options were defined for the build cache directories,
(access)$ cat << EOF >> $SPACK_ROOT/etc/spack/config.yaml
config:
    build_stage:
        - /dev/shm/$user/spack-stage
EOF
to speed-up compilation using the ramdisk file system. Before proceeding to the installation of OpenFOAM the desired version of Open MPI is installed with the system compiler:
(compute node)$ spack install -j openmpi@4.0.5 +pmi schedulers=slurm ^pmix@4.2.3 ^hwloc@2.2.0
The distribution of OpenFOAM is installed using the system compiler as well. The available components of OpenFOAM are:
Variants:
OpenFOAM is installed using all the available partitioners (metis, scotch, zoltan, kahip) and the multi-grid generator components (mgridgen, section 6.3.1.4 of the documentation) with the command:
(compute node)$ spack install -j openfoam@2306 +source precision=dp +metis +scotch +zoltan +kahip +mgridgen ~knl ~int64 ~paraview ^openmpi@4.0.5
However, the resulting installation is missing multiple components. For instance, executing the manual post installation verification in doc/Build.md,
# Create the user "run" directory:
mkdir -p "$FOAM_RUN"
# Change to the user "run" directory:
run
# Copy tutorial
cp -r "$FOAM_TUTORIALS"/incompressible/simpleFoam/pitzDaily ./
# Run the tutorial
( cd pitzDaily && blockMesh && simpleFoam )
both the mesh generator blockMesh and the solver simpleFoam are missing.
It turns out that the METIS partitioner causes the installation of multiple components to fail. Recompiling with only the SCOTCH partitioner,
(compute node)$  spack install openfoam@2306  +source +scotch +mgridgen precision=dp ~int64 ~kahip ~knl ~metis ~paraview ~vtk ~zoltan ^openmpi@4.0.5
solves the issue. All solver components are installed, but a few utilities are still missing.
We use the following script to detect all missing components:
(access node)$ cat list_spack_openfoam
#!/usr/bin/bash
set -euo pipefail
declare variant="${1}" # e.g. @2306%gcc@8.5.0 @2306+mgridgen
declare type="${2}" # solvers, utilities
find_makefile_directories() {
    local directory="${1}"
    find "${directory}" -type d | grep -E '\/Make$' || true
extract_executable_name() {
    local makefile_directory="${1}"
    cat "${makefile_directory}/files" | ( grep -E '^EXE[[:space:]]*=' || true ) | sed 's/^EXE[[:space:]]*=[[:space:]]*\$(FOAM_APPBIN)\///g'
main() {
    local variant="${1}"
    local type="${2}"
    local foam_location="$(spack location -i openfoam"${variant}")"
    local pagkage_directory=""
    local executable_name=""
    local installed=""
    local package_makefile_directory=""
    while read -r package_makefile_directory; do
        executable_name=$( extract_executable_name "${package_makefile_directory}" )
        if [ -n "${executable_name}" ]; then
            if [ -x "${foam_location}/platforms/linux64GccDPInt32-spack/bin/${executable_name}" ]; then
                installed="Y"
            else
                installed="N"
            fi
            package_directory="$( echo "${package_makefile_directory}" | xargs -I % dirname % )"
            echo "${installed} : ${executable_name} => ${package_directory#${foam_location}}"
        fi
    done < <( find_makefile_directories "${foam_location}/applications/${type}" )
main "${variant}" "${type}"
A simple run of the script indicates that the following utilities are missing:
(access node)$ ./list_spack_openfoam utilities @2306 | grep -E '^N'
N : addr2line => /applications/utilities/miscellaneous/OSspecific/addr2line
N : foamyHexMeshSurfaceSimplify => /applications/utilities/mesh/generation/foamyMesh/foamyHexMeshSurfaceSimplify
N : foamyHexMeshBackgroundMesh => /applications/utilities/mesh/generation/foamyMesh/foamyHexMeshBackgroundMesh
N : cellSizeAndAlignmentGrid => /applications/utilities/mesh/generation/foamyMesh/cellSizeAndAlignmentGrid
N : foamToCcm => /applications/utilities/mesh/conversion/ccm/foamToCcm
N : ccmToFoam => /applications/utilities/mesh/conversion/ccm/ccmToFoam
It’s hard to tell, Markdown-related issues tend to not be 403s but have some UI feedback to the author. Our 403 errors tend to be related to authorisation, like posting in a category that is restricted, or using a restricted tag.
I used your text chunks in a vanilla instance of Discourse and it seems to be fine.
Could I suggest you check with your moderator to see if such restrictions are in place?
Further to this, we nearly always find that 403 errors like this when attempting to create posts (especially with code blocks!) are due to an overzealous WAF believing the code blocks are shellcode or an injection attack.
I note that the instance in question seems to be fronted by a WAF:
○ → host hpc-discourse.uni.lu
hpc-discourse.uni.lu is an alias for fstc-waf2.uni.lu.
and thus I strongly suspect the 403 errors are coming not from Discourse, but from your WAF.
Inspecting the headers of the errors in the browser should be able to tell you the source of the rejection.
