Errors in console related to loading account preferences route directly
http://localhost:4200/u/merefield/preferences/account
This is generating the following error currently:
Error occurred:
- While rendering:
  -top-level
    application
      discourse-root
        user
          user-nav
            horizontal-overflow-nav
              d-navigation-item
                link-to
<anonymous> discourse-boot.js:21
Uncaught ReferenceError: While generating link to route "userPrivateMessages": can't access lexical declaration 'queryParams' before initialization
This without any Theme Components or plugins installed on current dev build …
Hmm, I don’t see this issue on my local environment.
How about on Meta, does it work ok for you here? (meta is running Ember 5)
No issues on Meta … odd!
Does using safe mode locally help? (I know you said there aren’t any custom plugins/themes, but perhaps it’s being affected by one of the plugins bundled in core)
No /safe-mode makes no difference and FYI I’ve just re-pulled from repo
David, I tried my Raspberry Pi (5 :rocket:) dev install and this doesn’t exhibit the same issue.
I’m going to assume my local install is corrupted for some reason, but it doesn’t make a lot of sense atm.
Aha, we had some other reports of this @merefield and managed to track it down. Looks like it happens when the navigation mode is “dropdown” (not sidebar)
@vinothkannans sorted a fix here: FIX: convert the route to Ember Octane to fix the dependency issue. by vinothkannans · Pull Request #25221 · discourse/discourse · GitHub
Aaaah. That’s awesome. Thanks.
FYI I could in that configuration (classic dropdown format - which I :heart: btw) reproduce it on the Pi :+1: - what a weird one!
This topic was automatically closed after 44 hours. New replies are no longer allowed.
