The discussion revolves around installing Discourse on an existing server. khionu is seeking help to finalize the app.yml structure and suggests that the launcher script should be able to generate a copy without additional steps.
codinghorror responds by stating that only the Docker-based install method is officially supported, and this will not change.
Falco provides a solution to khionu’s query by sharing a sample standalone.yml file from GitHub and offering additional configuration steps. The steps include commenting out port exposure lines, adding a template line, and rebuilding Discourse to listen on a Unix socket. The reverse proxy can then be pointed to this socket.
I have found a few posts, such as this one, where people have wanted to install Discourse on an existing server. I’ve attempted to pull the pieces together, but this has been a headache going between 5 different sources between this instance and the GitHub. This has been a ride, and I would highly recommend adding more to your scripts to support this use case.
The last thing I have yet to figure out is the final structure of app.yml. I have found fragments only, and not enough to conclude that what I’ve compiled is everything. I would suggest that the launcher script be able to generate a copy without additional steps. That one addition would allow people to preconfigure everything they need. For now, if I could be linked to a raw file template or if one could be attached in a reply, I would be incredibly grateful.
Using the sample file I provided above, comment out the lines about exposed ports (since this server is shared they will already be busy). After that add this line to the template list on the top:
- "templates/web.socketed.template.yml"
Now, after a rebuild Discourse will be listening only on a Unix socket under the shared folder. Point your reverse proxy to that.
