How install discourse in home path?
Hello
I want I install discourse in a subdomain (discuss.eaxmple.com) with the following address:
/home/admin/web/discuss.eaxmple.com/public_html/
First, I installed Docker / Git by wget -qO- https://get.docker.com/ | sh command
After this, what do I do?
Follow the howto topic here on subdomain.
follow the official guide:
change any reference to /var/discourse to your path that you’re installing to. Including when you create your container template… for instance in
you’d change the volumes section to read something like:
volumes:
          - volume:
              host: /home/admin/discourse/shared/standalone
              guest: /shared
          - volume:
              host: /home/admin/discourse/standalone/log/var-log
              guest: /var/log
From the looks of your desired install directory under /home/admin/web/discuss.example.com/public_html/ it appears you are under the impression that Discourse is a collection of stuff that you can just drop into a web directory. Rather, bear in mind Discourse is a full web application that would need to be proxied to from your web host.
You’d need to look into apache reverse proxying for example.
I modify app.yml
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting by uncommenting the web.ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
  - "templates/sshd.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "80:80"   # fwd host port 80   to container port 80 (http)
  - "2222:22" # fwd host port 2222 to container port 22 (ssh)
# any extra arguments for Docker?
# docker_args:
params:
  ## On 1GB installs set to 128MB (to leave room for other processes)
  ## on a 4GB instance you may raise to 1GB
  db_shared_buffers: "128MB"
  ## Set higher on large instances it defaults to 10MB, for a 3GB install 40MB is a good default
  ## this improves sorting performance, but adds memory usage per-connection
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  ## TODO: How many concurrent web requests are supported?
  ## With 2GB we recommend 3-4 workers, with 1GB only 2
  ## If you have lots of memory, use one or two workers per logical CPU core
  UNICORN_WORKERS: 2
  DISCOURSE_DEVELOPER_EMAILS: 'info@example.com'
  DISCOURSE_HOSTNAME: 'discourse.example.com'
  ## TODO: The mailserver this Discourse instance will use
  DISCOURSE_SMTP_ADDRESS: smtp.example.com         # (mandatory)
  #DISCOURSE_SMTP_PORT: 587                        # (optional)
  #DISCOURSE_SMTP_USER_NAME: user@example.com      # (optional)
  #DISCOURSE_SMTP_PASSWORD: pa$$word               # (optional, WARNING the char '#' in pw can cause problems!)
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## The CDN address for this Discourse instance (configured to pull)
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
  - volume:
      host: /home/admin/web/discourse.example.com/public_html/shared/standalone
      guest: /shared
  - volume:
      host: /home/admin/web/discourse.example.com/public_html/shared/standalone/log/var-log
      guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discourse
## http://discourse.example.com/admin/docker
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
## Remember, this is YAML syntax - you can only have one block with a name
run:
  ## If you want to configure password login for root, uncomment and change:
  ## Use only one of the following lines:
  #- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
  #- exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'RAW_PASSWORD')" root
  ## If you want to authorized additional users, uncomment and change:
  #- exec: ssh-import-id username
  #- exec: ssh-import-id anotherusername
  - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
then run ./launcher bootstrap app (after 8 min) in end ./launcher start app but receive error:
Error response from daemon: Cannot start container e0a9864b92d1ee65eabaa6301ee00d5248535c130c0bff585219f27f25812950: failed to create endpoint app on network bridge: Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
I can install discourse on port 8000
