Facing an issue while installing some gems in the plugin
fzngagan is experiencing issues installing certain gems, specifically google-protobuf, in a plugin. The issue arises from the .gemspec file’s name not matching the spec_file’s name assumed in the code.
After further discussion, fzngagan created a pull request (#9) to fix the issue, which was merged by sam. The pull request resolves the problem by addressing the platform-specific naming convention in gem files.
This issue is particularly relevant to a plugin being developed to integrate the Google Cloud Vision API into the upload process, which is being sponsored by Terrapop.
@sam
I’m unable to install some gems in the plugin, for e.g. google-protobuf. This gem is dependency for google-cloud-vision gem.
Here’s a plugin trying to install it. GitHub - fzngagan/gem-issue · GitHub
Logs
gem install google-protobuf -v 3.13.0 -i /Users/faiz/discenv/discourse/plugins/gem-issue/gems/2.6.3 --no-document --ignore-dependencies --no-user-install
Successfully installed google-protobuf-3.13.0-universal-darwin
1 gem installed
You are specifying the gem google-protobuf in /Users/faiz/discenv/discourse/plugins/gem-issue/plugin.rb, however it does not exist!
Looked for: /Users/faiz/discenv/discourse/plugins/gem-issue/gems/2.6.3/specifications/google-protobuf-3.13.0.gemspec
The reason for this is that the .gemspec file’s name doesn’t match the spec_file’s name assumed in the code here.
IMO, this would happen probably only when using platform-specific gems as the platform name gets added to the gem name if its platform dependent. This is described here. Specification Reference - RubyGems Guides
It’s unclear why you mentioned me on this topic? I don’t know much about our custom gem resolution, sorry.
I checked the blame and you have the most commits to the file I guess? Happy to be pointed in the right direction here :slight_smile:
I think @sam might be able to help. He wrote the gem importing for plugins.
Sure, thanks for the lead.
@sam did you get a chance to take a look?
@sam could you help @fzngagan on this? I am sponsoring this plugin:
And it will be made available for everybody. It is vital to keep a forum free of images that could potentially harm and will certainly help to not getting strikes from Google Adsense for disallowed content.
I guess it looks like there is a bug here, perhaps do a PR to try and fix this quirk?
https://github.com/discourse/discourse/pull/10559
Here’s a very simple PR fixing the issue.
I tried to find a fancy way to tackle this so that the devs don’t have to worry about the platform thing but didn’t find any. Happy to improve upon this if I find a better solution.
Also, a tip for devs, you can simply put the gem in discourse’s gemfile during development and not go insane. Only worry about all of this for deployment.
Thanks for merging @sam.
