Fallo al instalar Discourse a través de Docker
Relleno el archivo app.yml y uso este comando para reconstruir la imagen.
sudo ./launcher rebuild app
Sin embargo, me encontré con este problema y no tengo idea de cómo solucionarlo…
I, [2021-07-07T01:28:34.484614 #1]  INFO -- :
I, [2021-07-07T01:28:34.484941 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
** PLUGIN FAILURE **
No se puede compilar Discourse debido a este error durante la inicialización del plugin:
uninitialized constant Onebox
/var/www/discourse/plugins/google_docs_onebox/plugin.rb:6:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:629:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:629:in `activate!'
lib/discourse.rb:240:in `block in activate_plugins!'
lib/discourse.rb:237:in `each'
lib/discourse.rb:237:in `activate_plugins!'
/var/www/discourse/config/application.rb:313:in `block in <class:Application>'
/var/www/discourse/lib/plugin_initialization_guard.rb:5:in `plugin_initialization_guard'
/var/www/discourse/config/application.rb:312:in `<class:Application>'
/var/www/discourse/config/application.rb:73:in `<module:Discourse>'
/var/www/discourse/config/application.rb:72:in `<top (required)>'
/var/www/discourse/Rakefile:7:in `require'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/rake_module.rb:29:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/rake_module.rb:29:in `load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/application.rb:710:in `raw_load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/application.rb:104:in `block in load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/application.rb:103:in `load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/application.rb:82:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/lib/rake/application.rb:80:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.4/exe/rake:27:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `<top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:474:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/exe/bundle:49:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/friendly_errors.rb:130:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/exe/bundle:37:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
I, [2021-07-07T01:28:35.629849 #1]  INFO -- :
I, [2021-07-07T01:28:35.674810 #1]  INFO -- : Terminating async processes
I, [2021-07-07T01:28:35.674950 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 70
I, [2021-07-07T01:28:35.675020 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 187
2021-07-07 01:28:35.675 UTC [70] LOG:  received fast shutdown request
187:signal-handler (1625621315) Received SIGTERM scheduling shutdown...
187:M 07 Jul 2021 01:28:35.675 # User requested shutdown...
187:M 07 Jul 2021 01:28:35.675 * Saving the final RDB snapshot before exiting.
2021-07-07 01:28:35.742 UTC [70] LOG:  aborting any active transactions
187:M 07 Jul 2021 01:28:35.742 * DB saved on disk
187:M 07 Jul 2021 01:28:35.742 # Redis is now ready to exit, bye bye...
2021-07-07 01:28:35.745 UTC [70] LOG:  background worker "logical replication launcher" (PID 79) exited with exit code 1
2021-07-07 01:28:35.747 UTC [74] LOG:  shutting down
2021-07-07 01:28:36.300 UTC [70] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3841 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
1eaf7abdf201a825d63cd5c85f3e2217f718c135926b71519cda2050340da3d5
Aquí está el registro completo:
Note.txt (75.4 KB)
El problema es que no sé por qué no puedo agregar el plugin en el archivo app.yml.
En mi app.yml, la sección de plugins es la siguiente:
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-checklist.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-whos-online.git
          - sudo -E -u discourse git clone https://github.com/gdpelican/babble.git
          - sudo -E -u discourse git clone https://github.com/kasperpeulen/discourse-mathjax.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-tooltips.git
          - sudo -E -u discourse git clone https://github.com/paviliondev/discourse-topic-previews.git
          - sudo -E -u discourse git clone https://github.com/naveed-ahmad/google_docs_onebox.git
Parece que se encuentra con un problema de permiso denegado…
¿Existe algún método para solucionarlo?
¡Gracias!!
google_docs_onebox probablemente está roto, ¿solo hay que eliminar la línea en app.yml?
La fuente de esa gema no se ha actualizado en 6 años. La documentación dice específicamente:
este plugin ha sido fusionado en la gema oficial Onebox. Por lo tanto, no es necesario instalarla si estás usando la última versión.
Así que necesitarás eliminar esa entrada.
¡Entendido!!
¡Gracias @Benjamin_D y @Andrew Schleifer!!
Efectivamente, lo que probé fue que después de eliminar las partes de abajo, funcionaba bien sin ningún error, pero los plugins completos no se instalaban.
¡Gracias por tu ayuda!!
Saludos cordiales,
Chieh
