Upgrade to Failure Discourse 2.8
Hello,
I tried to upgrade to the latest released version and I'm running into issues.  I upgrade the docker-manager and was instructed to use the CLI to update.  That's fine, happens once in a while.
After doing a git pull, and running ./launcher rebuild app it fails and I’m not exactly sure where the issue is happening. Here’s my plugin list and logs.
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-staff-notes.git
          - git clone https://github.com/discourse/discourse-chat-integration.git
          - git clone https://github.com/gdpelican/retort.git
#          - git clone https://github.com/Ebsy/discourse-nationalflags.git
          - git clone https://github.com/angusmcleod/discourse-locations.git
          - git clone https://github.com/discourse/discourse-steam-login.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/discourse/discourse-oauth2-basic
          - git clone https://github.com/discourse/discourse-perspective-api.git
          - git clone https://github.com/procourse/procourse-installer.git
Logs:
I, [2022-02-26T02:55:14.922993 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
cd /var/www/discourse/plugins && git clone https://github.com/pmusaraj/discourse-jitsi.git
Cloning into 'discourse-jitsi'...
cd /var/www/discourse/plugins && git clone https://github.com/paviliondev/discourse-question-answer.git
Cloning into 'discourse-question-answer'...
cd /var/www/discourse/plugins && git clone https://github.com/critcola/discourse-twitch-onebox.git
Cloning into 'discourse-twitch-onebox'...
cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-akismet.git
Cloning into 'discourse-akismet'...
fatal: destination path 'discourse-jitsi' already exists and is not an empty directory.
Cannot clone directory
fatal: destination path 'discourse-question-answer' already exists and is not an empty directory.
fatal: destination path 'discourse-twitch-onebox' already exists and is not an empty directory.
fatal: destination path 'discourse-akismet' already exists and is not an empty directory.
I, [2022-02-26T02:55:40.287227 #1]  INFO -- : gem install geocoder -v 1.4.4 -i /var/www/discourse/plugins/discourse-locations/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed geocoder-1.4.4
1 gem installed
gem install ruby-openid -v 2.9.2 -i /var/www/discourse/plugins/discourse-steam-login/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openid-2.9.2
1 gem installed
gem install rack-openid -v 1.3.1 -i /var/www/discourse/plugins/discourse-steam-login/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed rack-openid-1.3.1
1 gem installed
gem install omniauth-openid -v 1.0.1 -i /var/www/discourse/plugins/discourse-steam-login/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-openid-1.0.1
1 gem installed
gem install omniauth-steam -v 1.0.6 -i /var/www/discourse/plugins/discourse-steam-login/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-steam-1.0.6
1 gem installed
I, [2022-02-26T02:55:40.287755 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
** PLUGIN FAILURE **
You are unable to build Discourse due to this error during plugin
initialization:
uninitialized constant Onebox
/var/www/discourse/plugins/discourse-twitch-onebox/plugin.rb:8:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:671:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:671:in `activate!'
lib/discourse.rb:279:in `block in activate_plugins!'
lib/discourse.rb:276:in `each'
lib/discourse.rb:276:in `activate_plugins!'
/var/www/discourse/config/application.rb:324:in `block in <class:Application>'
/var/www/discourse/lib/plugin_initialization_guard.rb:5:in `plugin_initialization_guard'
/var/www/discourse/config/application.rb:323:in `<class:Application>'
/var/www/discourse/config/application.rb:73:in `<module:Discourse>'
/var/www/discourse/config/application.rb:72:in `<top (required)>'
/var/www/discourse/Rakefile:7:in `require'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/rake_module.rb:29:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/rake_module.rb:29:in `load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:710:in `raw_load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:104:in `block in load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:103:in `load_rakefile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:82:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:25:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:25:in `<top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:484:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:31:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:25:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:48:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:36:in `<top (required)>'
I, [2022-02-26T02:55:43.858479 #1]  INFO -- :
I, [2022-02-26T02:55:43.859326 #1]  INFO -- : Terminating async processes
I, [2022-02-26T02:55:43.859684 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2022-02-26T02:55:43.860155 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
2022-02-26 02:55:43.860 UTC [41] LOG:  received fast shutdown request
102:signal-handler (1645844143) Received SIGTERM scheduling shutdown...
2022-02-26 02:55:43.862 UTC [41] LOG:  aborting any active transactions
2022-02-26 02:55:43.865 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
2022-02-26 02:55:43.867 UTC [45] LOG:  shutting down
2022-02-26 02:55:43.889 UTC [41] LOG:  database system is shut down
102:M 26 Feb 2022 02:55:43.896 # User requested shutdown...
102:M 26 Feb 2022 02:55:43.896 * Saving the final RDB snapshot before exiting.
102:M 26 Feb 2022 02:55:43.979 * DB saved on disk
102:M 26 Feb 2022 02:55:43.979 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 608 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
4d132e6fe184252d1944e826993f8ae2528b2d4d6bfb05a5f69a9ff282646cc9
You’ve got these plugins (and more) listed somewhere twice.
I mean, nothing has changed since the last time I installed updated discourse. I do see it cloning the plugins twice but not sure why it would be the case. None of the yml file (and there’s only one app.yml) has any duplicate references to it.
Maybe remove this plugin?
I have a funny feeling that this is not an official install and you are looking at the wrong yml file.
The plugins you mention is not the plugins in the rebuild
@pfaffman I think that was it. I was installing the plugin via GitHub - procourse/procourse-installer: A Discourse plugin for installing other Discourse plugins. which I probably should stop using since it seems like it’s listed under broken plugins. Though it IS so nice to install a plugin without having to SSH into the server, add a line and have to rebuild and restart the entire app.
I think you should remove both procourse installer & retort (use discourse-reactions instead) because both the plugins are not maintained to their best. There is a high chance those could cause issue while rebuilding.
