FAILED TO BOOTSTRAP on setup
The user DursunCan is experiencing an error when setting up Discourse with the message “FAILED TO BOOTSTRAP” and is seeking help.
DursunCan has tried running ./discourse-doctor, which also failed. The output indicates a problem pulling the base image, possibly due to Docker Hub rate limits or an expired login.
Pfaffman suspects the issue is with Docker, and DursunCan confirms Docker works by installing other images.
DursunCan wonders if the virtual server’s security rules could be the cause, but Pfaffman suggests testing Docker with a simple program.
After reinstalling from scratch, DursunCan encounters the same error. Pfaffman points out that Discourse cannot be set up if another service is running on ports 80 or 443.
DursunCan wants to know how to change the Nginx port for Discourse, as they have Ghost installed on their server and want to use it on ports 80 and 443.
This error on setup Discourse:
FAILED
Pups::ExecError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 297 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "find $home ! -user discourse -exec chown discourse {} \\+"]}
d85fae83cd3f933238f0e21e6e562469400baf63643d9c6dcd138c739dfa0830
I tried some solutions, it didn’t work.
Did you try discourse doctor?
./discourse-doctor
FAILED
Pups::ExecError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 298 exit 1>
00e8acc18f87b395d0b4f8de4d859dad8c8824b148243fa8f0c6085e5b0982a4
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to sosyal.dursuncanpoyraz.com.tr succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
+ /usr/bin/docker run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=4 -e UNICORN_SIDEKIQS=1 -e RUBY_GLOBAL_METHOD_CACHE_SIZE=131072 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e LETSENCRYPT_DIR=/shared/letsencrypt -e DISCOURSE_DEFAULT_LOCALE=en -e DISCOURSE_HOSTNAME=sosyal.dursuncanpoyraz.com.tr -e DISCOURSE_DEVELOPER_EMAILS=poyrazdursuncan@gmail.com -e DISCOURSE_SMTP_ADDRESS=smtp.gmail.com -e DISCOURSE_SMTP_PORT=587 -e DISCOURSE_SMTP_USER_NAME=poyrazdursuncan@gmail.com -e 'DISCOURSE_SMTP_PASSWORD=Poyraz!19681973' -e DISCOURSE_SMTP_ENABLE_START_TLS=true -e LETSENCRYPT_ACCOUNT_EMAIL= -h localhost-app -e DOCKER_HOST_IP=172.17.0.1 --name app -t -p 80:80 -p 443:443 -v /var/discourse/shared/standalone:/shared -v /var/discourse/shared/standalone/log/var-log:/var/log --mac-address 02:78:00:1c:c3:10 local_discourse/app /sbin/boot
Unable to find image 'local_discourse/app:latest' locally
docker: Error response from daemon: pull access denied for local_discourse/app, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'.
Failed to restart the container.
==================== PLUGINS ====================
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/master/lib/plugin/metadata.rb for the official list.
Please include a few more lines above the FAILED message. I’m assuming this is a fresh install? If not, did you make any changes to app.yml file?
It looks like docker can’t pull the base image. I’ve seen this happen, I think, when I’d previously logged in to docker hub but the login expired? Or you’ve hit rate limits?
Could the problem be from the security rule on the virtual server? The first day I entered the virtual server, it gave the same error.
Edit:
I don’t know docker. I started learning yesterday. I pulled at most 20 images yesterday.
No solution? Is there anyone to help?
You can try spinning up a new vm and /or running a trivial docker program. They have some hello world kind of thing. You can see if docker works at all.
Docker works. I installed teamspeak3 with docker. I even installed nginx and tested port 80. But it gives an error at discourse’s command.
I started setup from scratch.
root@localhost:~# su -
root@localhost:~# git clone https://github.com/discourse/discourse_docker.git /var/discourse
Cloning into '/var/discourse'...
remote: Enumerating objects: 5025, done.
remote: Total 5025 (delta 0), reused 0 (delta 0), pack-reused 5025
Receiving objects: 100% (5025/5025), 1.10 MiB | 2.40 MiB/s, done.
Resolving deltas: 100% (3259/3259), done.
root@localhost:~# cd /var/discourse
root@localhost:/var/discourse# ./discourse-setup
Docker not installed. Enter to install from https://get.docker.com/ or Ctrl+C to exit
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 13857  100 13857    0     0   6805      0  0:00:02  0:00:02 --:--:--  6809
# Executing docker install script, commit: 3d8fe77c2c46c5b7571f94b42793905e5b3e42e4
+ sh -c apt-get update -qq >/dev/null
+ sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sh -c curl -fsSL "https://download.docker.com/linux/ubuntu/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=amd64] https://download.docker.com/linux/ubuntu bionic stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
+ sh -c docker version
Client: Docker Engine - Community
 Version:           20.10.2
 API version:       1.41
 Go version:        go1.13.15
 Git commit:        2291f61
 Built:             Mon Dec 28 16:17:32 2020
 OS/Arch:           linux/amd64
 Context:           default
 Experimental:      true
Server: Docker Engine - Community
 Engine:
  Version:          20.10.2
  API version:      1.41 (minimum version 1.12)
  Git commit:       8891c58
  Built:            Mon Dec 28 16:15:09 2020
  Experimental:     false
 containerd:
  Version:          1.4.3
  GitCommit:        269548fa27e0089a8b8278fc4fc781d7f65a939b
 runc:
  Version:          1.0.0-rc92
  GitCommit:        ff819c7e9184c13b7c2607fe6c30ae19403a7aff
 docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
  sudo usermod -aG docker your-user
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
         containers which can be used to obtain root privileges on the
         docker host.
         Refer to https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface
         for more information.
Port 80 appears to already be in use.
This will show you what command is using port 80
COMMAND  PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
nginx    958     root    8u  IPv4  20899      0t0  TCP *:http (LISTEN)
nginx    958     root    9u  IPv6  20901      0t0  TCP *:http (LISTEN)
nginx   3368 www-data    8u  IPv4  20899      0t0  TCP *:http (LISTEN)
nginx   3368 www-data    9u  IPv6  20901      0t0  TCP *:http (LISTEN)
If you are trying to run Discourse simultaneously with another web
server like Apache or nginx, you will need to bind to a different port
See https://meta.discourse.org/t/17247
If you are reconfiguring an already-configured Discourse, use
./launcher stop app
to stop Discourse before you reconfigure it and try again.`
root@localhost:/var/discourse# ./launcher stop app
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20201221-2020: Pulling from discourse/base
6ec7b7d162b2: Pull complete
488a5181297e: Extracting [========================>                          ]  384.9MB/775.2MB
^C
Please be patient
488a5181297e: Pull complete
Digest: sha256:e181dd9046cc293b10c5b29bbc21c5aa8b939ba5f0c500da4a9e952ed0b5195d
Status: Downloaded newer image for discourse/base:2.0.20201221-2020
docker.io/discourse/base:2.0.20201221-2020
Config file was not found, ensure containers/app.yml exists
ls: cannot access '*.yml': No such file or directory
Available configs ( )
Like it shows, you can’t use discourse setup if something is running on port 80 or 443.
Yes it works. How can I change the Nginx port for Discourse? I have Ghost installed on my server. Why can’t I use it on port 80 and 443?
