Discourse_docker: problemen met bootstrapping
Learning how to deploy discourse on docker, on premise, following/using this project. I can’t find any “Issues” there so I ask here.
I work on a packer-project deploying the whole stack via ansible, the target machine is a small local debian-12 VM right now (docker-ce 28.2.2).
The app.yml is more or less close to the default from the repo. I only add labels to the container (integration with traefik) and something like that. Same app.yml built fine on another debian server.
Things fail at ./launcher bootstrap app:
From https://github.com/discourse/discourse
 * branch              tests-passed -> FETCH_HEAD
 * [new branch]        tests-passed -> origin/tests-passed
I, [2025-06-19T15:01:57.466297 #1]  INFO -- :
I, [2025-06-19T15:01:57.466503 #1]  INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2025-06-19T15:02:00.166283 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2025-06-19T15:02:00.166430 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2025-06-19T15:02:00.173066 #1]  INFO -- :
I, [2025-06-19T15:02:00.173236 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2025-06-19T15:02:00.178867 #1]  INFO -- :
I, [2025-06-19T15:02:00.178989 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2025-06-19T15:02:00.183569 #1]  INFO -- :
I, [2025-06-19T15:02:00.183662 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2025-06-19T15:02:00.189147 #1]  INFO -- :
I, [2025-06-19T15:02:00.189258 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2025-06-19T15:02:00.195217 #1]  INFO -- :
I, [2025-06-19T15:02:00.195305 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2025-06-19T15:02:00.200411 #1]  INFO -- :
I, [2025-06-19T15:02:00.200507 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2025-06-19T15:02:00.208619 #1]  INFO -- :
I, [2025-06-19T15:02:00.208771 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2025-06-19T15:02:00.215673 #1]  INFO -- :
I, [2025-06-19T15:02:00.215824 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2025-06-19T15:02:00.222167 #1]  INFO -- :
I, [2025-06-19T15:02:00.222270 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2025-06-19T15:02:00.229600 #1]  INFO -- :
I, [2025-06-19T15:02:00.229707 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2025-06-19T15:02:00.236308 #1]  INFO -- :
I, [2025-06-19T15:02:00.236383 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2025-06-19T15:02:00.243571 #1]  INFO -- :
I, [2025-06-19T15:02:00.243892 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2025-06-19T15:02:00.249403 #1]  INFO -- :
I, [2025-06-19T15:02:00.249501 #1]  INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2025-06-19T15:02:00.258481 #1]  INFO -- :
I, [2025-06-19T15:02:00.258881 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2025-06-19T15:02:00.259572 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2025-06-19T15:02:02.757529 #1]  INFO -- :
I, [2025-06-19T15:02:02.757835 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2025-06-19T15:02:02.764975 #1]  INFO -- :
I, [2025-06-19T15:02:02.765341 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2025-06-19T15:02:02.771575 #1]  INFO -- :
I, [2025-06-19T15:02:02.771778 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2025-06-19T15:02:02.775586 #1]  INFO -- :
I, [2025-06-19T15:02:02.776449 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2025-06-19T15:02:02.776770 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2025-06-19T15:02:02.777222 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2025-06-19T15:02:02.777470 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2025-06-19T15:02:02.777812 #1]  INFO -- : > echo "done configuring web"
I, [2025-06-19T15:02:02.781599 #1]  INFO -- : done configuring web
I, [2025-06-19T15:02:02.781828 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
ERROR:  Error installing bundler:
	bundler-2.6.4 requires Ruby version >= 3.1.0. The current ruby version is 2.7.2.137.
I, [2025-06-19T15:02:03.280749 #1]  INFO -- :
I, [2025-06-19T15:02:03.281100 #1]  INFO -- : Terminating async processes
I, [2025-06-19T15:02:03.281175 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 60
I, [2025-06-19T15:02:03.281235 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 177
177:signal-handler (1750345323) Received SIGTERM scheduling shutdown...
2025-06-19 15:02:03.281 UTC [60] LOG:  received fast shutdown request
2025-06-19 15:02:03.309 UTC [60] LOG:  aborting any active transactions
2025-06-19 15:02:03.311 UTC [60] LOG:  background worker "logical replication launcher" (PID 69) exited with exit code 1
2025-06-19 15:02:03.312 UTC [64] LOG:  shutting down
177:M 19 Jun 2025 15:02:03.324 # User requested shutdown...
177:M 19 Jun 2025 15:02:03.324 * Saving the final RDB snapshot before exiting.
177:M 19 Jun 2025 15:02:03.347 * DB saved on disk
177:M 19 Jun 2025 15:02:03.347 # Redis is now ready to exit, bye bye...
2025-06-19 15:02:03.493 UTC [60] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock) failed with return #<Process::Status: pid 315 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,\"\"); print $0 }' Gemfile.lock)", "find $home ! -user discourse -exec chown discourse {} \\+"]}
3539ee62a81cc2a309d4bfcf4fc6049bd70749d8f7c87bd2bf634eaf33fa4b7b
Any hints on how to fix that? help appreciated …
Regards, Stefan
EDIT: increased RAM to 8GB, didn’t change the situation
Heeft uw lokale VM volledige internettoegang en https?
De normale lokale installatie is dev-install
Gebruik anders de standaardinstallatie voor productie.
De VM is volledig online, ja. Hoewel deze nog niet van buitenaf bereikbaar is via een werkende FQDN, DNS-record, statisch IP. Als dat ertoe doet voor bootstrapping (ik ging ervan uit van niet).
it fails at this line
Doesn’t that maybe relate to the fact that the user discourse doesn’t exist on the docker host … ? … maybe … ? Or is that inside the discourse-container?
Ik krijg dezelfde fout op een compleet andere host.
Deze heeft een werkende FQDN die naar de server wijst, enz.
OK, ik heb dat “opgelost”. Op de een of andere manier werkte de git checkout niet correct en gebruikte het een vreemde oude combinatie van afbeeldingen en configuratie.
Opnieuw gepulld, opnieuw begonnen. Ik denk dat ik nu verder kan. Bedankt.
EDIT: het lijkt erop dat de vorige git-checkout van de master-branch kwam en niet van main. Dus het was nogal verouderd.
Dingen werken nu: discourse achter traefik, leuk.
