Failed to install
I’m trying to install Discourse but am getting this
2023-08-01 12:27:18.881 UTC [42] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
' failed with return #<Process::Status: pid 147 exit 128>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git reset --hard", "sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  if [ $(git rev-parse --is-shallow-repository) == \"true\" ]; then\n      git remote set-branches --add origin main\n      git remote set-branches origin $version\n      git fetch --depth 1 origin $version\n  else\n      git fetch --tags --prune-tags --prune --force origin\n  fi\n'", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n      git pull\n  else\n      git -c advice.detachedHead=false checkout $version\n  fi\n'", "sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
2b0150a1aac20c041b7de6173429a0a0b0133f8a63b5172a0e63f4d2ca5f22b0
==================== END REBUILD LOG ====================
Failed to rebuild app.
Can you post the whole log please?
sure! EUR1Okdcax | SourceBin
Error is
fatal: unable to access 'https://github.com/discourse/discourse.git/': Could not resolve host: github.com
Your host or containers have internet connectivity problems.
i managed to git clone it fine tho…
The git clone action is taken in the host, so that shows the host is OK, but the subsequent actions take place in the container. If they fail, it indicates trouble within the container (docker) and in this case, DNS (name resolution) trouble.
There have been situations before where people report this kind of connectivity problem inside docker. Perhaps see
It might be useful to have details of your provider and the location. It might be useful to test inside the container using commands something like this:
./launcher enter app
ping -c2 github.com
exit
