realcasey
(Casey)
25 Novembre 2017, 12:03pm
1
I try this script in post:
<div>
<style>
.dataframe thead tr:only-child th {
text-align: right;
.dataframe thead th {
text-align: left;
.dataframe tbody tr th {
vertical-align: top;
</style>
<table border="1" class="dataframe">
<thead>
<tr style="text-align: right;">
<th></th>
<th>date</th>
</tr>
</thead>
<tbody>
<tr>
<th>0</th>
<td>2007-01-07</td>
</tr>
<tr>
<th>1</th>
<td>2007-01-14</td>
</tr>
<tr>
<th>2</th>
<td>2007-01-21</td>
</tr>
<tr>
<th>3</th>
<td>2007-01-28</td>
</tr>
<tr>
<th>4</th>
<td>2007-02-04</td>
</tr>
</tbody>
</table>
</div>
But the table failed to be styled.
Could you give me some instructions?
Thanks!
fefrei
(Felix Freiberger)
25 Novembre 2017, 4:32pm
Discourse only allows a limited subset of HTML in posts, use of the <style> tag is not allowed.
If you’re an administrator in your Discourse instance, you could use themes to apply custom CSS to the site.
Have you considered using Markdown? eg.
||date|
|0|2007-01-07|
|1|2007-01-14|
|2|2007-01-21|
|3|2007-01-28|
|4|2007-02-04|
date
0
2007-01-07
1
2007-01-14
3
2007-01-28
4
2007-02-04
This guide explains how to add tables to your Discourse posts using Markdown.
Required user level: All users
Adding tables to your posts can help present data in a structured and easy-to-read format. This guide will walk you through creating tables in Markdown on Discourse, covering table basics, alignment, and special features like adding emojis and images.
Using the Table Builder
Discourse includes a built-in Table Builder that lets you create and edit ta…
Thank you @fefrei !
I am the admin of that site. If it does not interrupt you too much, could you tell me where to apply the custom CSS, “CSS” or “Embedded CSS”? I tried adding the following script to “Embedded CSS” just now, but it seems not to work.
text-align: right;
text-align: left;
Thanks again!
@Mittineague Thanks!
It is more convenient to create table with Markdown than HTML. Actually, I’d like to add some custom style to the plain table, so the CSS may be a better choice.
Have a good day!
fefrei
(Felix Freiberger)
27 Novembre 2017, 7:05am
6
Your CSS code should go into the CSS section
You may want to make sure that the CSS is only applied to the post you want. You can use this attribute to target a single topic by its ID:
