CSS für einzelne Tabellen in einem Beitrag
Ist es möglich, Tabellen in einem Beitrag individuell zu gestalten? Discourse entfernt alle Gestaltungselemente aus dem HTML in einem Beitrag.
Can you share a screenshot of what you want to do? In discourse you can do pretty much anything you want, but it gets harder the more crazy the idea is
I simply want some tables to have a fixed layout, and some auto layout.
I’m referring to tables created with Markdown, BBCode or HTML in composer.
If you can’t target them by id or class, by position? eg. instead of main-st → smith, main-st → second-house
What I generally do is go up the DOM until I find an ancestor element with an id, or in lieu of that a few elements with classes, and then go to the child element I want to target. If need be, a “first”, “last” or “nth” pseudo-class should do the job.
I think you mean modifying CSS from the admin panel.
What I’m asking is formatting in the composer window.
You will need to write a plugin that exposes the classes you want to allow users to use to format their tables. Once you do that, they can apply the classes to their posts.
If you’re on a recent version of Discourse - as this is a recent change - you can also use data-theme attributes.
For example:
<div data-theme-table="fixed">
	<table>
		<thead>
			<tr>
				<th>Col A</th>
				<th>Col B</th>
				<th>Col C</th>
			</tr>
		</thead>
		<tbody>
			<tr>
				<td>A1</td>
				<td>B1</td>
				<td>C1</td>
			</tr>
		</tbody>
	</table>
</div>
Or with markdown
| Col A | Col B | Col C|
| A1 | B1 | C1 |
</div>
Would look like this:
Col A Col B Col C
A1 B1 C1
No difference visually - but can be targeted with CSS like this:
[data-theme-table="fixed"] table {
    background: red;
The result is a red background for tables inside divs with the attribute data-theme-table="fixed" but no effect on other tables.
Capture18
So all you need to do is define the CSS once and then use the attributes in posts where you want the styles to apply.
This is exactly what I was looking for. Thank you @Johani
looking at white-lister.js.es6, I notice:
  'div[data-*]', /* This may seem a bit much but polls does
                    it anyway and this is needed for themes,
                    special code in sanitizer handles data-*
                    nothing exists for data-theme-* and we
                    don't want to slow sanitize for this case
does it mean that div[data-theme-*] is no longer required and we can simply use div[data-*] (e.g. div[data-table-layout])?
Yes, but I’d say to stick with the -theme- prefix for stuff that’s actually handled by a theme.
Yes, you’re correct @BlackKnob, you can use div[data-*] like div[data-table-layout] and it would have the same effect.
However, like @riking said earlier, you’re much better off sticking with div[data-theme-*] since there might be some work in the future to narrow down whitelisted attributes to div[data-theme-*]. When that happens, all of your posts with div[data-*] would need to be updated accordingly.
That’s why using div[data-theme-*] is recommended here, so that you can stay futureproof.
Wo platziere ich das CSS, um das benannte Div, das ich um die Tabelle gelegt habe, anzusprechen?
Muss ich ein benutzerdefiniertes Theme erstellen und installieren, um diese Methode zur Tabellenformatierung anwenden zu können?
Willkommen zurück @kaefert :wave:
Ja, ich würde dir empfehlen, das zu tun.
  1. Gehe zu admin/customize/themes
  2. Klicke auf Installieren
  3. Wähle Neu erstellen
  4. Gib ihm einen Namen und stelle den Typ auf component
  5. Füge dein CSS hinzu
  6. Füge die Komponente deinen aktiven Themes hinzu, indem du neben der Einstellung Include_component_on_these_themes auf der Komponentenseite auf Alle Themes hinzufügen klickst.
