Échec du redémarrage du conteneur ?
Donc, je viens de tout configurer sur ma machine Ubuntu 20.04 LTS (première configuration de Discourse ici) et je continue d’obtenir l’erreur « Failed to restart the container. » (discourse-doctor a également affiché cela en haut).
De plus, lors de la tentative d’envoi d’un e-mail de test, j’obtiens : « Error: No such container: app ».
Concernant l’échec du redémarrage du conteneur :
Unable to find image 'local_discourse/app:latest' locally
docker: Error response from daemon: pull access denied for local_discourse/app, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'.
J’ai également ceci lors de l’utilisation de discourse-setup :
./discourse-setup
The configuration file containers/app.yml already exists!
. . . reconfiguring . . .
Saving old file as app.yml.2021-05-12-102820.bak
Stopping existing container in 5 seconds or Control-C to cancel.
app was not started !
Lors de l’exécution de launcher rebuild app :
Fetching origin
Launcher is up-to-date
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
Already up to date.
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-05-12T09:50:18.718488 #1]  INFO -- : Loading --stdin
I, [2021-05-12T09:50:18.725717 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2021-05-12T09:50:18.765005 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-05-12T09:50:18.765246 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2021-05-12T09:50:18.770660 #1]  INFO -- :
I, [2021-05-12T09:50:18.771117 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-05-12T09:50:18.775863 #1]  INFO -- :
I, [2021-05-12T09:50:18.776526 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2021-05-12T09:50:18.784118 #1]  INFO -- :
I, [2021-05-12T09:50:18.784732 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2021-05-12T09:50:18.789096 #1]  INFO -- :
I, [2021-05-12T09:50:18.789666 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-05-12T09:50:18.794763 #1]  INFO -- :
I, [2021-05-12T09:50:18.795410 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/05/12 09:50:18 socat[28] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-05-12T09:50:18.802633 #1]  INFO -- :
I, [2021-05-12T09:50:18.802834 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-05-12T09:50:18.807914 #1]  INFO -- :
I, [2021-05-12T09:50:18.808476 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-05-12T09:50:18.814386 #1]  INFO -- :
I, [2021-05-12T09:50:18.814595 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-05-12T09:50:18.819542 #1]  INFO -- :
I, [2021-05-12T09:50:18.820160 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-05-12T09:50:18.824774 #1]  INFO -- :
I, [2021-05-12T09:50:18.834404 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2021-05-12T09:50:18.844948 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2021-05-12T09:50:18.853870 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2021-05-12T09:50:18.862785 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2021-05-12T09:50:18.863660 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-05-12T09:50:50.039399 #1]  INFO -- :
I, [2021-05-12T09:50:50.039806 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-05-12T09:50:50.045475 #1]  INFO -- :
I, [2021-05-12T09:50:50.045688 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-05-12T09:50:50.058739 #1]  INFO -- :
I, [2021-05-12T09:50:50.059712 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-05-12T09:50:50.064419 #1]  INFO -- :
I, [2021-05-12T09:50:50.064669 #1]  INFO -- : > /root/upgrade_postgres
I, [2021-05-12T09:50:50.072435 #1]  INFO -- :
I, [2021-05-12T09:50:50.073015 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2021-05-12T09:50:50.078047 #1]  INFO -- :
I, [2021-05-12T09:50:50.079038 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.080583 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.081391 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.082345 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.083082 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.083973 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.084828 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-05-12T09:50:50.090354 #1]  INFO -- :
I, [2021-05-12T09:50:50.090969 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.092485 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.093092 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-05-12T09:50:50.094187 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-05-12T09:50:50.094726 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-05-12T09:50:50.095089 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-05-12T09:50:50.098332 #1]  INFO -- : > sleep 5
2021-05-12 09:50:50.117 UTC [51] FATAL:  data directory "/shared/postgres_data" has invalid permissions
2021-05-12 09:50:50.117 UTC [51] DETAIL:  Permissions should be u=rwx (0700) or u=rwx,g=rx (0750).
I, [2021-05-12T09:50:55.105204 #1]  INFO -- :
I, [2021-05-12T09:50:55.105785 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: error: could not connect to database template1: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
I, [2021-05-12T09:50:55.179154 #1]  INFO -- :
I, [2021-05-12T09:50:55.179389 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
psql: error: could not connect to server: No such file or directory
I, [2021-05-12T09:50:55.272457 #1]  INFO -- :
I, [2021-05-12T09:50:55.272673 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-05-12T09:50:55.370163 #1]  INFO -- :
I, [2021-05-12T09:50:55.370560 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-05-12T09:50:55.462132 #1]  INFO -- :
I, [2021-05-12T09:50:55.462739 #1]  INFO -- : Terminating async processes
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 77 exit 2>
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
e6e8899182c075f3a312723ed5ed1935643882a33b9e6adf5a2cc00212962753
Veuillez m’aider. C’est la toute première fois que je configure cela sur mon PC Ubuntu 20.
Rebondir ^
Je rencontre le même problème. À la place, j’obtiens une erreur rake.
lieu de l'échec : /pups/lib/pups/exec_command.rb:112:in `spawn'
Je ne sais pas pourquoi spawn a un ` et un '.
→ Erreur complète ←
