As of today, all new self hosted installs of Discourse will default to using our Ember CLI builds in production.
We’ve been running these builds ourselves in production for quite some time now and they should be stable and work with all major plugins. If you encounter any issues and need to turn it off, edit your app.yml and remove EMBER_CLI_PROD_ASSETS: 1
Otherwise, please report any bugs to us and we’ll be quick to fix them.
In the near future all installs of Discourse will be using the Ember CLI builds.
Yes @Simon_Manning is correct - you can enable it yourself manually if you wish, or you can wait for it to become the default. We are rolling it out slowly to try and catch all the bugs in advance.
Browserslist: caniuse-lite is outdated. Please run:
npx browserslist@latest --update-db
Why you should do it regularly:
https://github.com/browserslist/browserslist#browsers-data-updating
I’m super excited about this change and it’s a great thing for the future of Discourse.
I would simply recommend this: if you are running any third party theme components or plugins, please spin up a separate test instance with the same set and check it all out there before moving to ember cli on your main site.
I have just released some significant changes to one of my Theme Components without which it would have broken the host site.
The short version is: this is the officially supported way to develop Ember applications and should make it easier for people to contribute and for us to ugprade Ember in the future.
