Уважаемые участники сообщества Discourse,
При развертывании форума Discourse на сервере Aliyun в Китае я столкнулся с неразрешимой ошибкой. Сообщение об ошибке следующее:
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
git remote set-branches --add origin main
git remote set-branches origin tests-passed
git fetch --depth 1 origin tests-passed
else
git fetch --tags --prune-tags --prune --force origin
fi
' failed with return #<Process::Status: pid 144 exit 128>
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git reset --hard", "sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n set -o errexit\n if [ $(git rev-parse --is-shallow-repository) == \"true\" ]; then\n git remote set-branches --add origin main\n git remote set-branches origin $version\n git fetch --depth 1 origin $version\n else\n git fetch --tags --prune-tags --prune --force origin\n fi\n'", "sudo -H -E -u discourse bash -c '\n set -o errexit\n if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n git pull\n else\n git -c advice.detachedHead=false checkout $version\n fi\n'", "sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p /shared/log/rails", "bash -c \"touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p /shared/{uploads,backups}\"", "bash -c \"ln -s /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p /shared/tmp/{backups,restores}\"", "bash -c \"ln -s /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
0ae30c93e953921c82004a93bce079b8b85b5b6bf6e4d42968a0de6e16a2d684
Я подозреваю, что проблема связана с сетью, так как доступ к GitHub в Китае может быть ограничен. Я пробовал настроить Docker для использования зеркала Alibaba Cloud, но проблема сохраняется.
Не могли бы вы помочь мне решить эту проблему? Большое спасибо!
