דיון על AlmaLinux
Greetings,
I realize that the supported version of Discourse requires a specific set up, however…
My curiosity and amount of work put in thus far compels me to ask for help here.
I installed docker on an AlmaLinux VPS and installed Discourse, had it running and set it up, invited users, all was hunky-dory. I’ve not added any plugins or made any major modification beyond the front-end interface changes.
And then I did a security update for Discourse that came through yesterday (or the day before).
It all went smoothly.
This is where the rookie mistake happened (I’m a rookie when it comes to this for sure). I decided to change my SSH port and forgot to open that port in the firewall. Well, after I fixed that I tried to restart Discourse and…
FAIL
Anyway, here are some of the errors (let me know if there is hope, or if I’m missing the obvious, or whatever. Be gentle :stuck_out_tongue: :
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
' failed with return #<Process::Status: pid 135 exit 128>
exec failed with the params
{"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git reset --hard",
"sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n
set -o errexit\n  if [ $(git rev-parse --is-shallow-repository) == \"true\" ]; then\n
git remote set-branches --add origin main\n
git remote set-branches origin $version\n
git fetch --depth 1 origin $version\n  else\n
git fetch --tags --prune-tags --prune --force origin\n  fi\n'",
"sudo -H -E -u discourse bash -c '\n  set -o errexit\n
  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n
git pull\n  else\n
git -c advice.detachedHead=false checkout $version\n  fi\n'",
"sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp",
"chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets",
"touch tmp/.gitkeep", "mkdir -p
/shared/log/rails", "bash -c \"touch -a
/shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"",
"bash -c \"ln    -s
/shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"",
"bash -c \"mkdir -p
/shared/{uploads,backups}\"",
"bash -c \"ln    -s
/shared/{uploads,backups} $home/public\"",
"bash -c \"mkdir -p
/shared/tmp/{backups,restores}\"",
"bash -c \"ln    -s
/shared/tmp/{backups,restores} $home/tmp\"",
"chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp",
"[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
If I’m not mistaken, this used to be an error on low memory situations. How much RAM/SWAP do you have on this VM?
what is the output of free -h
 total        used        free      shared  buff/cache   available
Mem:          7.5Gi       1.0Gi       4.4Gi       6.0Mi       2.1Gi       6.2Gi
Swap:         614Mi          0B       614Mi
Definitely out of memory from what I can see. Try making a bigger swap (maybe 4GB) and see if that lets you rebuild.
