Fatal: argumento ambiguo '@': revisión o ruta desconocida en el árbol de trabajo
Errors for a test deployment, while issued launcher rebuild app:
fatal: ambiguous argument '@': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
fatal: Not a valid object name @
./launcher: line 770: [: @: unary operator expected
./launcher: line 780: [: ee207cb4d2809f08d403bbd22370d64d4ffe657a: unary operator expected
Launcher has diverged source, this is only expected in Dev mode
And the build result, with restored backup data, I can not access the forum via browser, connection refused.
Is this a standard production install (discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub)?
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 2
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: sitedomain
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'webmaster@sitedomain,admin@sitedomain'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: postmaster@sitedomain
  DISCOURSE_SMTP_PASSWORD: "the password --"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: webmaster@sitedomain
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  DISCOURSE_CDN_URL: https://xyz-feaa.kxcdn.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-sitemap.git
          - git clone https://github.com/angusmcleod/discourse-question-answer.git
          - git clone https://github.com/angusmcleod/discourse-topic-previews.git
run:
It’s standard quick install
it was tested on Aliyun HongKong ECS. I think web.china.template.yml should only be needed for servers in mainland China, not needed for HongKong server?
Will try a new ecs and clean install without backup, see if it works
