If you run your own incoming mail, and you find that you’re getting more abusive mail than you’re willing to tolerate, this guide is for you!  It’ll show you how to configure your mail-receiver container to block e-mail from any domain on a list you create, and how you can add and remove domains from that list over time.
Setup
Using the custom Postfix configuration guide, configure your mail-receivercontainer to have an/etc/postfix/sharedvolume (see the “Addendum” section at the bottom).
Create an empty file on the host, in /var/discourse/shared/mail-receiver/etc, namedsender_access, by running the following command asroot:touch /var/discourse/shared/mail-receiver/etc/sender_access
Using the custom Postfix configuration guide, set the following environment variable: env: # <existing config> POSTCONF_smtpd_sender_restrictions: 'texthash:/etc/postfix/shared/sender_access'
Your Postfix system is now ready to accept domains to block.
Blocking and unblocking domains
The list of domains you want to block is maintained in the file /var/discourse/shared/mail-receiver/etc/sender_access on the host.  The format is straightforward: just a list of domains, one per line, with the word REJECT after it.  Here is an example:
example.com    REJECT
example.org    REJECT
# etc
There are other possibilities you can use instead of REJECT, but we won’t cover them in this guide; see the fine manual if you want to get super-fancy.
Thus, to add or remove a domain from the list of blocked domains, simply add or remove the relevant line from the file, by editing it as root.
There is one final step that needs to be taken after editing this file: reloading Postfix. It doesn’t automatically notice that a change has happened, and needs to be told. The quickest and least disruptive way to do this is to send a special signal to Postfix, using this command:
docker kill -s HUP mail-receiver
If you then examine the logs for the mail-receiver container, you should see Postfix mentioning a config reload.
That’s it. Enjoy a less-abused mail system.
 for this super helpful howto. I have now implemented the above and added the offending domains to it - I’ve let it go for an hour and so far it’s been quiet.
