Filter Tags on change Category
While creating new post/ topic on select Category should automatically filter the Tags. Currently it shows static tags just like this post
Hello :wave:
The display and filtering of tags when creating a topic depends on the category settings. It is possible to filter by tag and tag group, which tags should appear in the tags dropdown for the exact category. On Meta this isn’t seem to be restricted.
If this topic was specifically for Meta, I think it would be better to move to site feedback? :slight_smile:
@Don From where I can specify the tags to particular category so that on selection those tags should appears
Any suggestion would be helpful
Thanks for the quick feedback
Here is a great guide how it works :slight_smile:
