Corregir las deprecaciones de Faraday en el gem de la API de Discourse
Continuing the discussion from GitHub so that we aren’t discussing things in an unrelated closed PR…
@blake:
Sweet thanks for the PR. Those errors are related to a new faraday version. if you run bundle install you should get the new version, and see the errors. Would you like to make another PR for the Faraday fix?
I think all you will need to do is find all occurrences for Faraday::Error::ClientError and replace it with Faraday::ClientError
@kimardenmiller:
My faraday seems to be staying at 0.15.4, where I think gemlock has it. So I’m not able to reproduce the error locally. Should I bundle update faraday to bump the gemlock to 0.16.2 ?
The Gemfile.lock is in the .gitignore file, so you can just delete it and re-run bundle install.
Merged:
https://github.com/discourse/discourse_api/pull/184
