It should for the most part be possible to modify the regex
~* '\[quote[^]]*]'
regexp_replace(posts.raw, '\[(/)?quote([^]]*)]', E'\n[\\1quote\\2]\n', 'g')
so that it can find (the ~* case insensitive “LIKE” line) and replace (the table.field, pattern, replacement, flag line) characters and combinations of characters.
The trick is knowing exactly what to match so that it will both match what you want it to and not match what you want it not to. If the pattern is always and only the same characters it can be matched more easily. But maybe at times too easily eg. it is easy to match “cat” but you wouldn’t want to change “category” to “egory”.
As for trailing content a pattern something like ‘character string(.)*’ (google “regex everything atom”) should work as long as the string doesn’t include any “special” characters.
As for the font and color bbcode tags, if these are in only raw and not causing a problem with the cooked, I wouldn’t bother worrying about them. If they are a problem, changing the string “quote” to “font” and then “color” and changing the replacement to an empty string should work if you only want to remove the tags entirely. If case is a concern, changing the flag to ‘gi’ should work. Test First!
Documentation:
https://www.postgresql.org/docs/9.3/static/functions-matching.html
