Did you update theme to the latest?
Yes it’s the update that’s causing these problems
This bug is the same as the previous feedback on the phone bug a
It seems that there is no limit to the size of the preview image anymore It’s fine to display small images but when the image size is large it starts to stretch the whole UI
Ah, ok I see. Thanks for the report. I fixed it, please update the theme. ![]()
Hi, in the Category in homepage, the badge style box is not complete. see the picture below.
But in new topics its okay.
Hello
Thanks for the report! I fixed it here. Please update the theme. ![]()
updated and its done. Thank you for your quick response.
hi, can you share this themes customization, it looks nice
I tested this theme FKB Pro with Topic List Preview components and Topic List Thumbnails Components but not rendering well. but in reality, we don’t need such components for FKB Pro Theme. because it already has preview feature. so, in finally chose this theme.
Hi, is there a way to reduce the gap between the topic header and logo? when there is menu sidebar present. see the picture below
@Don
Thanks
How to make FKB Pro compatible with Quote Callouts? That is, use another style for quoting.
Thanks for this great theme.
hi, its solved automatically after discourse updates.
Yeah. It works.
@Jun You can achieve that with the TC settings.
Here is what you can do.
First, define the global style: width, style and radius:
Callout border width: 0 0 0 5px
Callout border style: solid
Callout border radius: var(--d-default-border-radius)
You can also set Callout border color if you want the same border color for all the callouts.
Otherwise, you can define the color per callout.
Here in the screenshot, I use the same Color for the border.
Hey! I just updated our Discourse to the newest updates and it seems like something in it broke the topics layout as they are not contained to the “bubbles” as before. So far the option to disable the FKB Pro topic layout fixed the issue. I am attaching screenshots of the issue below together with the admin console which now shows an error. I had to blur some personal data of our users so I hope that is not too disturbing.
The SCSS mixin sticky has been removed from core recently (DEV: Remove unnecessary scss mixins (#31355) · discourse/discourse@46c568a · GitHub).
Thanks for the report @Obi_Sam_Kenobi and thanks @Arkshine for the heads up. ![]()
I merged a fix please update the theme.
Also noticed this since uploading to latest build
lightbox stopped working… is there anything I’m missing? it does work on other themes like Material design.
Hey @sok777 ![]()
Sorry I can’t repro it. I’ve installed the theme on the latest Discourse and didn’t notice this kind of errors you see. Is there any other theme component may cause this? Can you share your site url?
