Is it possible that I could set up notifications for flagged posts?
So every time someone flags a post you can receive an email so you can respond quicker.
There is a setting called “notify about flags after”:
You could set this to 1 hour.
Is that in preferences? I don’t see it.
In “Settings” under “Other” - but you can use Settings Filter/Search to find it.
No, you have screen shot “User Preferences”.
The setting you want is a Site Setting - you will need to be an Administrator to change it.
Find it under /admin/site_settings/category/uncategorized
Oh I see now, thanks:)
Is there anyway I can immediately receive notifications? Not just after an hour.
Not that I know of, perhaps someone else will know.
But do keep in mind that the default settings will mean that:
- if 3 users flag a post it will be hidden.
- if 3 different users flag a new user, that new user will be blocked from posting
- if 5 users flag to close a topic - it will be.
I doubt it will work and it might break - but you could try a number like 0.5 as the value for 30 minutes.
@Carson1 did you ever ask Philippe to make this change?
No I have not asked Philippe
Note that this is a total of 12 flags on a topic from at least 5 users - so multiple posts need to be extremely bad for this to trigger. (And trigger it does…)
This topic was automatically closed after 2953 days. New replies are no longer allowed.
