Cédric_DANIEL reports an issue where new group members are not automatically set to ‘Follow’ a category, despite the group settings indicating this. Instead, the notification level defaults to ‘Maximum’, causing excessive notifications. simon investigates and suggests that a default categories setting might be overriding the group preferences. After checking and adjusting the setting, Cédric_DANIEL confirms the issue was resolved, clarifying it was not a bug.
I’m really blocked for using my discourse. I suspect a bug in the user preferences, when the user joins a group, that it gives him access to a new category and that the default setting should be “Follow”. I did a test which confirms it, with a new email address:
The user registers and then joins a group. The categories followed by this group are therefore added to the user’s preferences (/u/…/preferences/categories "). He can see the new category, but the notification level is at the maximum (here are the user settings):
The user’s notification level that you set on the group’s Categories page should match the notification level that is set on the user’s preferences page. I tested this in French just to make sure we are looking at the same thing.
If the category that is causing the problem is set there, remove the category from the setting. Select the option to apply the changes retroactively when you update the setting.
If this does not fix the issue for you, let us know what version of Discourse your site is using. So far I have not been able to reproduce the issue on a site that’s using the latest Discourse code.
