フッターがDiscourseの幅に合わせられていない
I’m trying to create a foot something like: https://discuss.newrelic.com/
I snagged the footer I found there, stripped stuff out, and did my best to snag the related CSS. It’s sort-of close, but the width is the whole browser rather than just the part that Discourse is using.
What am I missing?
Example: https://s2.literatecomputing.com/
CSS: : discourse-theme-footer/desktop/desktop.scss at master · pfaffman/discourse-theme-footer · GitHub
Footer: discourse-theme-footer/desktop/footer.html at master · pfaffman/discourse-theme-footer · GitHub
You missing a div with .container class. Wrap all .footer-col and .social-icons like below
<div class="container">
  <div class="footer-col"></div>
  <div class="social-icons"></div>
</div>
Also remove the margin (only for div#footer-top) in this line.
That seems to have done it. CSS remains a twisty maze of passages that all look alike. It always makes sense when it’s right, but often I can’t guess why it’s wrong.
A thousand thank-yous.
Ah, one problem, the Social Icons are outside of the desired margins. I think they’re in the container, but there’s something else I’m missing.
コンテナ内にはありません。ここをご覧ください:
余談ですが、以下を単純に追加するだけで済みます:
.social-icons {
    margin-right: auto;
    margin-left: auto;
    padding-left: 15px;
    padding-right: 15px;
    max-width: 1170px;
あるいは、別の方法として、social-icons の div をコンテナの中に配置することもできます :wink:
編集: 63 行目に footer-col 4 番目を閉じる </div> が、64 行目にもう一つの </div>container を閉じるようになっています。最後の div を削除し、social-icons の部分の後に追加してください。
I’m using a different footer style of my own, how will I make my footer fit with Discourse on mobile
I am also having grey boxes in between categories on my forum, incorrect spacing at the bottom
Can you provide information on how to fix this?
Using media queries
Share the code you are trying to use
Here is the footer code for my forum, Can you provide how to make spacing accurate on mobile Thanks.
You have some problems with padding and margin settings in your media query.
Try to change it this way:
@media (max-width: 767px) {
  .footer {
    font-size: 14px;
    padding: 0px;
    margin-top: 0px;
  .footer .footer-left,
  .footer .footer-center,
  .footer .footer-right {
    display: block;
    width: 100%;
    text-align: center;
  .footer .footer-center i {
    margin-left: 0;
  .footer .about {
      padding-left: 15px;
      padding-top: 40px;
  .footer .name {
      padding-bottom: 40px;
it should work much better.
Thank you @dax, much appreciated :slight_smile:
