المنتدى يواجه خطأ 502 Bad Gateway Error
مرحبًا
نستخدم منصة Discourse في منتدانا منذ سنوات دون مواجهة العديد من المشاكل. لكن فجأة اليوم، عند محاولة زيارة منتدانا، تظهر لنا رسالة خطأ 502 Bad Gateway Error. إليك لقطة الشاشة لتوضيح المشكلة بشكل أفضل.
نرجو مساعدتنا في حل هذه المشكلة.
First, try to reboot the system and see if it resolves the issue.
If it does not, check your disk space.
(Or you can do it the other way around).
إعجاب واحد (1)
Hello Richard,
Thank you for your quick reply. We have tried the way which you mentioned and we also tried in different system but we are facing the same problem(502 Bad Gateway). What else we can do?
What does this mean?
So did you check your disk space?
إعجاب واحد (1)
We also tried in different system(Which means when we are trying to visit our forum url on different Machines(Laptops)) it is giving the same issue.
When the forum is up and running without 502 Bad Gateway at that time posting the answer to the question is not working it is giving Internal Server error. For clear understanding below is the screenshot.
Thank You
It seems to be working now although it’s very slow.
إعجاب واحد (1)
It’s working but we are not able to post the answer. Below is the log file error we are getting
How fast is the CPU? How much RAM? Are the disks SSD?
إعجاب واحد (1)
