减小类别列的宽度
Hello,
As as you can see in the picture blow we use latest posts and categories view on our home page, what i need to know here is the best way to reduce the width of the categories column and make posts column wider to the right
Thanks in advance
This CSS should get you started
.categories-and-latest {
 flex-flow: row;
  div.column {
    flex: 1 1 75%;
    &.categories {
      flex: 0 1 25%;
Adjust the 25% until the categories column is your desired width. The other column will fill the remaining space.
To explain how the flex layout works a bit more… the shorthand is:
flex: grow shrink basis;
grow: a non-zero value allows the div to grow to fill the space available, 0 will prevent this behavior
shrink: a non-zero value allows the div to shrink to fill the space available, 0 will prevent this behavior
basis: essentially it’s the width (or height) the div starts off at before growing/shrinking
More in-depth explanations from MDN
7 个赞
The above goes to CSS?
1 个赞
Yes sorry, should have noted that it’s CSS.
1 个赞
Much appreciated, worked like charm.
the 25% is not enough, how i can go further ? i mean the 25% is the maximum i can shrink the column, i need to shrink it more.
ah, there’s also a minimum width set… so you can override that and then if you decrease the 25% it should be narrower.
 flex-flow: row;
  div.column {
    min-width: unset;
    flex: 1 1 75%;
    &.categories {
      flex: 0 1 15%;
3 个赞
