Fulltext should ignore accents
Hi there,
it is pretty common for search engines (e.g. google) to ignore accents on characters when doing fulltext search. Example: word kôprová omáčka should be matched by query koprova omacka and vice versa. With PostgreSQL unaccent extension this should be pretty easy. PostgreSQL: Documentation: 9.0: unaccent
Any plans to add this?
2 « J'aime »
No plans at the moment but it is a pretty simple patch I would accept.
For CJK languages we pre-parse the text prior to indexing to split up words, same concept could easily be applied in the code path
