Functionality to remove unneccesary posts from topics
The discussion started with davidshq suggesting some functionality to help clean up forums threads that become cluttered over time with extraneous posts. He provided an example thread on multisite configuration where the discussion diverged into an unrelated side conversation that was no longer relevant.
He proposed some possible solutions:
  • Allow collapsing a subset of posts while keeping them in the thread (post 1)
  • Split off subsets of posts into separate topics (post 1)
  • Allow moderators to simply delete clutter posts (post 1)
  • Let users delete their own unnecessary posts (post 1)
sam responded that most of this functionality already exists, it just requires discipline in using the tools properly.
Heliosurge agreed with sam, noting that some features could be better exposed, like the ability to collapse irrelevant subthreads. He suggested this could help both regular users and moderators clean up topics.
Continuing the discussion from Multisite configuration with Docker:
I love Discourse and first want to just say ‘thanks’ to you guys for your work on an excellent application.
But…
Gahh, I hate having to say that…but, I’m feeling a bit overwhelmed when I read some Discourse threads - for example the one I’ve linked to above (multisite configuration).
Over time these threads get cluttered. For example, with the thread I added below:
I’m wondering how you guys envision folks consuming this post in the best way possible currently…and if you have any ideas for how to make it more easily consumed in the future?
I’d suggest that a “cleaning” mechanism of some sort would be quite handy. For example, the above thread I made is old news. It really is pretty useless - @riking made the necessary edit - the related posts are now “useless.”
A cleaning mechanism might work something like this (and I’m just spitballing here trying to be helpful :))
  • One could select a thread of posts and “collapse” them. They would remain part of the same thread, in the same location, but individuals would click on them collapsed version to expand and see the full thread. This way the info. is still accessible, but isn’t cluttering up what’s really important.
  • One could have a “break into new topic” option that would pull off this specific sub-thread into a new topic…err, it should probably be an old topic, otherwise everyone would see this useless info. as unread when they next visited the site.
  • The moderator could just delete the clutter.
  • Users could be responsible for deleting their own clutter.
Dave
2 лайка
Pretty much all the above exists, its just a question of discipline applying the existing tools.
2 лайка
Как уже отмечал Сэм, большая часть функционала уже реализована. Однако, на мой взгляд, это отчасти обусловлено тем, как пользователи привыкли к системе, а также тем, что некоторые функции, способные упростить работу, пока не раскрыты в полной мере.
Например, в недавно добавленной настройке сайта в левом нижнем углу поста появляется стрелка с цифрой. При нажатии на неё скрываются все посты, кроме тех, которые связаны с первым нажатим постом.
Это удобно не только для участников, но и для команды модераторов, если они захотят разделить тему. Однако, возможно, потребуется добавить опцию для вставки постов позже, особенно если ответчик использовал кнопку ответа внизу, а не кнопку ответа на конкретный пост.
