Temporarily hide post / mark less important?
I’m having a problem that a Topic starts up with a good Post, but then devolves quickly into useless me too Posts, and no policy seems to fix this behavior. Then, someone actually responds with a great Post, followed by a bunch of other me toos and uselessness. Then another great Post. The thread becomes 100+ posts long, but only posts 1, 15, and 62 are worth reading.
What I’m thinking of as a solution, is a plugin or something that let’s moderators mark posts as ‘hidden’, and so when a user views the thread, those posts are collapsed. However, anyone can click on them to open them, and you can click to open them all. I don’t want the less important posts to be deleted or unviewable, but I don’t want them in the Topic browser’s face.
Is this possible now in Discourse or via an existing plugin? Do you have any suggestions other than mine to solve this problem of the long Topic with mostly useless Posts?
「いいね!」 8
This is already possible via the “Summarize Topic” button at the top of the topic. This will only appear on topics longer than {x} posts where {x} defaults to 50 out of the box, but can be adjusted via site setting.
When a topic is too long to read, and you want the TL;DR version. Try that first.
「いいね!」 1
I looked into “Summarize Topic”, and although it was a good effort, it relies on Likes and maybe some other automated things. This doesn’t really get the summary right because many of the “me toos” are liked. I really want a human moderator to pick.
「いいね!」 3
Is it realistic to expect a human moderator is going to go through every single topic and manually mark “just the good posts”?
If this kind of radical moderation is needed, I suggest deleting all the meaningless “me too” posts, which will be suppressed (soft-deleted) for all non-staff users visiting the topic. Then post a staff reply that says “hey, any me-too replies will be deleted, please only reply with {rules}”
「いいね!」 5
Me too! It could be a team of moderators or people with a high TL. Or use a weighted Like score with more weight given to higher TL users.
Yes, for some forums, and no for others. I review all posts in my forum.
「いいね!」 3
I would also appreciate manual hiding of posts as a feature. In my case, it’s to hide my own off-topic moderator posts and replies to it.
More concretely, we repeatedly have people post logfile content as plain text rather than preformatted/fenced code blocks and I keep fixing that and posting a public reply with an explanation. We are also trying to establish a culture of liking posts (no idea why people are ignoring the :heart: button) so I’m also posting public hints on that.
A lot of the time, that will be a single off-topic post and that’s okay, but sometimes people reply to my post and then I might reply again so that there is a longer sequence of OT posts and it is those that I would like to hide.
「いいね!」 3
Would this be different from the “transparent deletion” system you suggested here? It sounds to me like it solves a similar problem (which I completely agree needs solving!).
「いいね!」 3
Good point. I didn’t see this here as deleting but you are right: it corresponds to the highest level of transparency that I suggested there:
So, yes, if the transparent deletion would be implemented, it would make sense to integrate it with the hide posts feature.
But since it seems that transparent deletion is not anywhere on the roadmap at the moment, I’d still like to push for manual post hiding.
「いいね!」 2
It’s been years. Is this possible now? I think this is important for big forums.
I also think this would be a good feature to have.
Until this feature exists one workaround would be for the moderators to hide just the text of the less important posts.
Like this
Just edit the post, select all the text, press the :gear: symbol and select “hide details”.
I wish to second this so much. I too have the need to hide some posts in a topic.
In my case we don’t have that many posts, but some of them are not contributing much value, but too much to justify deleting them.
We already have a summary post at the very top, so that doesn’t solve the problem. We just simply want to make posts that aren’t contributing as much value as the other ones less apparent, but still viewable.
It would be perfectly fine if such posts were collapsed and there was a grey text saying “Click to show this post” or whatever, the important thing is that they don’t show by default and that users see that they’re posts that exist but aren’t shown fully, and that they can click on the post or similar to show it.
I searched the forum here but can’t find anything like this. Is there anything that can do this yet?
Often this request simply means:
“I am a moderator and there is tons of junk in a particular topic, I don’t ever want to delete anything cause I am afraid to hurt people’s feelings”
There are quite a few options you have:
  • People do get over being deleted, you can simply be a bit harsher and delete for the greater good
  • You can split off the gold into another topic
  • You can make the OP wiki, and just summarize and link to all the great content in the mega topic from there.
Manually “shrink” portions of conversation is an interesting request but in practice I think it is just masking dealing with an underlying problem.
「いいね!」 3
I think it is fine if you announce intention to “clean up”, explain why the topic is being pruned, and indicate it’s specific to certain topics like that one.
「いいね!」 5
Guys, this is not about an inability to clean up threads. I have personally already deleted and split/moved numerous posts in the threads I’m considering when supporting the request we’re discussing here.
In fact, that’s exactly the type of maintenance I was doing when I noticed I had gotten a reply in this topic.
Deleting posts is not the proper thing to do here, at least not in my use case. If it was, I would have done it already.
「いいね!」 2
Does not reflect the above, so maybe you should create a new topic then, if your posts are off-topic in this particular topic?
「いいね!」 3
私はフォーラムを持っています。それは債権者の集まりが法的措置を組織化しようとするものに関するものです。「非表示」の投稿や情報レイヤリングという重要な機能が不足しています。
  1. トピックは問題解決に関するものです。一部の投稿は高度な理解にとって非常に重要で関連性が高いですが、他の投稿はそうではありません。関連性の低い投稿が「無用」なわけではありません。多くの場合、それらは議論にニュアンスを加えます。時には、主要な関係者の意見(賛成/反対)の記録となっています。これらの議論を階層化して表示できることは極めて重要です。
  2. 他の人が指摘しているように、人気があることは重要であることを意味しません。また、もし相関関係があったとしても、人気はしばしば情報ではなく、ランダムな人格的要因と混同されています。投稿の要約機能は毎回ひどく失敗します。あまりにも頻繁に失敗するため、人々に使うよう促す価値さえなく、かえって混乱を招くスレッドを生み出しています。
  3. 騒がしく散漫なトピックをより整理された参照用トピックに変えることで、忙しいフォーラムはトピックを極めて迅速にウィキページのように変えることができます。モデレーターが非表示または重要性の低い投稿をマークできるようにすれば、これが可能になります。これは製品の実用性を大幅に向上させるでしょう。
もしDiscourseで投稿の非表示や可変的な重要度のマークを許可したくないのであれば、モデレーターがトピックのキュレーションされた「ビュー」を作成できるようにし、そのリンクをトピックの上部やインターフェースの他の適切な場所に配置できるようにしてください。
「いいね!」 2
個人的な意見ですが、投稿を任意に折りたたむ機能(その理由や根拠は問わず)は良いアイデアだと思います。これはプラグインで実現できないでしょうか?もし関心のある方々が資金を提供して、その機能を持つプラグインの開発を依頼すれば、皆が満足するはずです。そのようなプラグインは複雑でしょうか?(それほど難しくないように思えますが、もしかしたら私の考えが間違っているかもしれません)。
正直に申し上げますと、Discourse 以外の別のソフトウェアを選ばれることをお勧めします。ご要望の機能が実現できるフォーラムソフトウェアは、おそらく存在しないと思います。インターネット上にそのような実際の事例をご存知でしょうか?
残念ながら、ありません。また、特定の機能が私の生活をより簡単にしてくれると知っているにもかかわらず、一時的なフラストレーションを感じたとしても、明らかに優れたフォーラムプラットフォームがない限り(それはありそうにないと思いますが)、Discourse から乗り換えるつもりはありません。Discourse は多くのことを非常にうまくこなしており、優れた製品です。
「いいね!」 1
はい、特に挑戦として言ったわけではありませんが、そんなことを行うソフトウェアは本当にあるのでしょうか?
