Gem::RemoteFetcher::FetchError error during install
when i execute ./discourse-setup script. I got message below:
I, [2016-05-22T10:46:17.514250 #36]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 235
235:signal-handler (1463913977) Received SIGTERM scheduling shutdown...
2016-05-22 10:46:17 UTC [110-2] LOG:  database system is shut down
235:M 22 May 10:46:17.534 # User requested shutdown...
235:M 22 May 10:46:17.536 * Saving the final RDB snapshot before exiting.
235:M 22 May 10:46:17.540 * DB saved on disk
235:M 22 May 10:46:17.541 # Redis is now ready to exit, bye bye...
FAILED
RuntimeError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 346 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "chown -R discourse $home"]}
440bda508369286c7ea776cfedfdc46e3909c216a8217a20d57a9a06350d0816
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
You did not follow this advice. Find the error, you didn’t print it above.
thx, the error may occur by network connection. But what should i do next ? execute ./discourse-setup again, or ./launcher rebuild ?
I, [2016-05-22T10:46:13.799929 #36]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2016-05-22T10:46:13.801295 #36]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2016-05-22T10:46:13.802423 #36]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2016-05-22T10:46:13.803562 #36]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2016-05-22T10:46:13.804808 #36]  INFO -- : > echo "done configuring web"
I, [2016-05-22T10:46:13.806273 #36]  INFO -- : done configuring web
I, [2016-05-22T10:46:13.807578 #36]  INFO -- : > cd /var/www/discourse && gem update bundler
ERROR:  While executing gem ... (Gem::RemoteFetcher::FetchError)
    Errno::ECONNRESET: Connection reset by peer - SSL_connect (https://api.rubygems.org/specs.4.8.gz)
I, [2016-05-22T10:46:17.507815 #36]  INFO -- : Updating installed gems
Either one will work, the command is ./launcher rebuild app
This topic was automatically closed after 2939 days. New replies are no longer allowed.
