Hello, I have been trying to install discourse on my development server but it isn’t working and I have increased the Ram to 4gb. Can anyone please help me with it?
The error is attached…
156:M 26 Dec 10:09:29.206 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
156:M 26 Dec 10:09:29.206 # Server started, Redis version 3.0.6
156:M 26 Dec 10:09:29.206 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
156:M 26 Dec 10:09:29.206 * DB loaded from disk: 0.000 seconds
156:M 26 Dec 10:09:29.207 * The server is now ready to accept connections on port 6379
I, [2017-12-26T10:09:39.203096 #14] INFO -- :
I, [2017-12-26T10:09:39.203900 #14] INFO -- : Replacing <policymap> with <policymap>
<policy domain="coder" rights="none" pattern="EPHEMERAL" />
<policy domain="coder" rights="none" pattern="URL" />
<policy domain="coder" rights="none" pattern="HTTPS" />
<policy domain="coder" rights="none" pattern="MVG" />
<policy domain="coder" rights="none" pattern="MSL" />
<policy domain="coder" rights="none" pattern="TEXT" />
<policy domain="coder" rights="none" pattern="SHOW" />
<policy domain="coder" rights="none" pattern="WIN" />
<policy domain="coder" rights="none" pattern="PLT" />
in /usr/local/etc/ImageMagick-6/policy.xml
I, [2017-12-26T10:09:39.208514 #14] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2017-12-26T10:09:39.299555 #14] INFO -- :
I, [2017-12-26T10:09:39.300016 #14] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2017-12-26T10:09:39.407569 #14] INFO -- :
I, [2017-12-26T10:09:39.408087 #14] INFO -- : > chown -R discourse /home/discourse
I, [2017-12-26T10:09:39.415458 #14] INFO -- :
I, [2017-12-26T10:09:39.415856 #14] INFO -- : > rm -f /etc/cron.d/anacron
I, [2017-12-26T10:09:39.420168 #14] INFO -- :
I, [2017-12-26T10:09:39.426503 #14] INFO -- : File > /etc/cron.d/anacron chmod:
I, [2017-12-26T10:09:39.439677 #14] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x
I, [2017-12-26T10:09:39.447354 #14] INFO -- : File > /etc/runit/1.d/enable-brotli chmod: +x
I, [2017-12-26T10:09:39.452459 #14] INFO -- : File > /etc/service/unicorn/run chmod: +x
I, [2017-12-26T10:09:39.459152 #14] INFO -- : File > /etc/service/nginx/run chmod: +x
I, [2017-12-26T10:09:39.464931 #14] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x
I, [2017-12-26T10:09:39.473536 #14] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x
I, [2017-12-26T10:09:39.473732 #14] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2017-12-26T10:09:39.474233 #14] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2017-12-26T10:09:39.477123 #14] INFO -- : > cd /var/www/discourse && git reset --hard
182:M 26 Dec 10:09:39.487 # Creating Server TCP listening socket *:6379: bind: Address already in use
Checking out files: 100% (24719/24719), done.
I, [2017-12-26T10:09:43.792385 #14] INFO -- : HEAD is now at f5d45f7 Fix broken Gemfile.lock.
I, [2017-12-26T10:09:43.799016 #14] INFO -- : > cd /var/www/discourse && git clean -f
I, [2017-12-26T10:09:43.991284 #14] INFO -- :
I, [2017-12-26T10:09:43.991431 #14] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin master
I, [2017-12-26T10:09:43.998305 #14] INFO -- :
I, [2017-12-26T10:09:43.998430 #14] INFO -- : > cd /var/www/discourse && git pull
From https://github.com/discourse/discourse
f5d45f7..f6dc992 master -> origin/master
0c40e2d..63d48a0 beta -> origin/beta
* [new branch] fix-rtl-caret-position -> origin/fix-rtl-caret-position
* [new branch] flag-history -> origin/flag-history
f18f608..c45964b stable -> origin/stable
f5d45f7..f6dc992 tests-passed -> origin/tests-passed
* [new branch] typography-2.0 -> origin/typography-2.0
* [new tag] v1.8.11 -> v1.8.11
* [new tag] v1.9.0.beta16 -> v1.9.0.beta16
* [new tag] v1.9.0.beta17 -> v1.9.0.beta17
I, [2017-12-26T10:09:50.926178 #14] INFO -- : > cd /var/www/discourse && git fetch origin tests-passed
* branch tests-passed -> FETCH_HEAD
I, [2017-12-26T10:09:52.962530 #14] INFO -- :
I, [2017-12-26T10:09:52.963089 #14] INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2017-12-26T10:09:53.517419 #14] INFO -- : Branch tests-passed set up to track remote branch tests-passed from origin.
I, [2017-12-26T10:09:53.517703 #14] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2017-12-26T10:09:53.528324 #14] INFO -- :
I, [2017-12-26T10:09:53.528477 #14] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2017-12-26T10:09:53.532264 #14] INFO -- :
I, [2017-12-26T10:09:53.532518 #14] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2017-12-26T10:09:53.539192 #14] INFO -- :
I, [2017-12-26T10:09:53.539339 #14] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2017-12-26T10:09:53.542742 #14] INFO -- :
I, [2017-12-26T10:09:53.542895 #14] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr}.log"
I, [2017-12-26T10:09:53.549877 #14] INFO -- :
I, [2017-12-26T10:09:53.550020 #14] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr}.log /var/www/discourse/log"
I, [2017-12-26T10:09:53.555500 #14] INFO -- :
I, [2017-12-26T10:09:53.555687 #14] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2017-12-26T10:09:53.561742 #14] INFO -- :
I, [2017-12-26T10:09:53.561930 #14] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2017-12-26T10:09:53.566403 #14] INFO -- :
I, [2017-12-26T10:09:53.566558 #14] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups
I, [2017-12-26T10:09:53.572691 #14] INFO -- :
I, [2017-12-26T10:09:53.573494 #14] INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2017-12-26T10:09:53.573971 #14] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2017-12-26T10:09:56.407615 #14] INFO -- :
I, [2017-12-26T10:09:56.408185 #14] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2017-12-26T10:09:56.421523 #14] INFO -- :
I, [2017-12-26T10:09:56.421915 #14] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2017-12-26T10:09:56.423923 #14] INFO -- :
I, [2017-12-26T10:09:56.424202 #14] INFO -- : > mkdir -p /var/nginx/cache
I, [2017-12-26T10:09:56.430587 #14] INFO -- :
I, [2017-12-26T10:09:56.431079 #14] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2017-12-26T10:09:56.431670 #14] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2017-12-26T10:09:56.432181 #14] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2017-12-26T10:09:56.434674 #14] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2017-12-26T10:09:56.435337 #14] INFO -- : > echo "done configuring web"
I, [2017-12-26T10:09:56.443653 #14] INFO -- : done configuring web
I, [2017-12-26T10:09:56.444358 #14] INFO -- : > cd /var/www/discourse && gem update bundler
ERROR: While executing gem ... (Gem::RemoteFetcher::UnknownHostError)
timed out (https://api.rubygems.org/specs.4.8.gz)
I, [2017-12-26T10:10:57.380501 #14] INFO -- : Updating installed gems
I, [2017-12-26T10:10:57.381450 #14] INFO -- : Terminating async processes
I, [2017-12-26T10:10:57.381620 #14] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 43
156:signal-handler (1514283057) Received SIGTERM scheduling shutdown...
I, [2017-12-26T10:10:57.381888 #14] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 156
2017-12-26 10:10:57.382 UTC [43] LOG: received fast shutdown request
2017-12-26 10:10:57.382 UTC [43] LOG: aborting any active transactions
2017-12-26 10:10:57.382 UTC [50] LOG: autovacuum launcher shutting down
2017-12-26 10:10:57.390 UTC [47] LOG: shutting down
2017-12-26 10:10:57.418 UTC [47] LOG: database system is shut down
156:M 26 Dec 10:10:57.448 # User requested shutdown...
156:M 26 Dec 10:10:57.448 * Saving the final RDB snapshot before exiting.
156:M 26 Dec 10:10:57.453 * DB saved on disk
156:M 26 Dec 10:10:57.453 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 269 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "chown -R discourse $home"]}
7afdb54da45a197c6b8d3fab0383c321c4aa088144118bdfd9419b6efa4ce142
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
real 1m53.998s
user 0m1.040s
sys 0m0.472s
Also when I run free -h I get this:
total used free shared buff/cache availableMem: 3.9G 108M 799M 5.6M 3.0G 3.4G
Swap: 0B 0B 0B
