Get list of topics pinned globally
AI 生成的摘要
The discussion revolves around finding a way to retrieve a list of globally pinned topics. adopilot initially asked if it’s possible, and codinghorror suggested viewing the site in incognito mode, but this approach wasn’t feasible due to login requirements.
cpradio provided a solution using the Data Explorer Plugin, sharing a JSON file that can be used to retrieve pinned topics. adopilot modified the query to specifically retrieve globally pinned topics.
However, Bathinda encountered a syntax error while running the query. nathank later provided an updated query that returns a tidier list of all pinned posts by category, with globally pinned topics at the top.
Note: sam pointed out that using in:pinned in the search bar should find all pinned topics, regardless of whether they’re globally or locally pinned.
Is there a way to get list of topics which are pinned globally.
In advanced search there is “are pinned” but it does list all pined topics.
We wold like to find globally pined topics so we can clear our latest list.
The usual way is to view the site in incognito mode in your browser.
We unfortunately require logins to view any content .
I need then dummy account to reuse.
If you have Data Explorer Plugin installed, this should do it.
pinned-topics.dcquery.json (213 Bytes)
Thanx for tip here is corrected version for others.
Added pinned_globally=TRUE in where clue
SELECT id, title, user, category_id ,pinned_globally FROM topics WHERE pinned_at IS NOT NULL and pinned_globally=TRUE
{"query":{"id":12,"sql":"SELECT id, title, user, category_id ,pinned_globally FROM topics WHERE pinned_at IS NOT NULL and pinned_globally=TRUE","name":"Pinned Topics","description":"Enter a description here","param_info":[]}}
Note in:pinned should find all pinned topics be they globally or locally pinned.
运行时会报以下错误:
PG::SyntaxError: ERROR:  syntax error at or near "{"
LINE 9: {"query":{"id":12,"sql":"SELECT id, title, user, category_id...
这是更新后的 Data Explorer 查询,它将返回一个更整洁的按类别排序的所有置顶帖子的列表,全局置顶主题将显示在顶部:
SELECT pinned_globally, TO_CHAR(pinned_until,'DD/MM/YYYY') as pinned_till, id as topic_id, user_id, category_id
FROM topics
WHERE deleted_at IS NULL
AND pinned_at IS NOT NULL
AND (pinned_until IS NULL OR pinned_until > CURRENT_TIMESTAMP)
ORDER BY pinned_globally desc, category_id
