Ottieni gli ID dei post che un utente ha messo mi piace
I would like to get the id’s of posts that a specific user has liked. How can I do this?
You can find that with the Data Explorer Plugin with a query like this:
-- [params]
-- string :username
WITH sample_user AS (
SELECT
u.id
FROM users u
WHERE u.username = :username
SELECT
p.topic_id,
pa.post_id,
pa.created_at AS liked_at
FROM post_actions pa
JOIN posts p
ON p.id = pa.post_id
WHERE pa.post_action_type_id = 2
AND pa.user_id = (SELECT id FROM sample_user)
ORDER BY pa.created_at DESC
If you need to see the actual id, instead of a link to the topic and an excerpt of the post, change the line
pa.post_id
to
pa.post_id AS id
To get the post_ids with an ActiveRecord query, do something like this, with the user_id of the user you are looking for:
PostAction.where(post_action_type_id: 2, user_id: 1).pluck(:post_id)
5 Mi Piace
this looks really cool!
Specifically, I was wondering if there was a way to get this through api
You can query the Data Explorer through the API. Take a look at Access to query data from API endpoints.
2 Mi Piace
