The discussion revolves around the challenges of creating and managing global banners in Discourse. hellekin describes their attempt to pin a topic as a banner, only to find that replies to closed topics are still possible, and that a link to the banner appeared at the end of the original conversation. They resorted to moving posts to the banner topic and reassigning ownership, highlighting the lack of a straightforward way to edit the first post for banners without disrupting content. vinothkannans clarifies that admins can reply to closed topics and edit any post, but hellekin points out that editing the first post for a banner requires removing original content. Ultimately, hellekin suggests a better approach: creating a dedicated banner topic with a #banner tag and using an image link to the target content, avoiding edits to existing topics.
I had this nice conversation that I wanted to pin globally as a banner. However, I wanted to edit the first post so the pin is inviting. As I’m a smartass, I decided to create a ‘Site Banners’ category under /c/staff, visible to Everyone. Then I proceeded to create a topic and hit ‘Banner this topic’.
Whew, nice, it worked! Er…
But then, I had a link to that banner topic appearing at the end of the original conversation… So I decided to close the banner topic so that people would simply come back to the original discussion, and…
Yes, I could reply to a closed topic… Not what I expected.
Hacking It Anyway
So, I proceeded to move all posts from the original topic to the banner topic, gave the first post (the banner) to the original poster, and it was as if I had inserted the banner post before the existing topic. Sort of.
Questions
Isn’t replying to a closed topic a bug – even if it’s a banner?
Is there a marker for staff to edit the first post of an existing topic, e.g., before -- on its own line, to insert the banner text?
Is that something you would like to do (inserting a ‘banner post’ for an existing topic)?
Ah, good call So I could have saved myself some worry… But it remains that there’s no straightforward way to edit a first post for banner without ‘stealing’ it from the original poster.
As the banner topic mentioned a link to the original topic, the original topic had a link to the banner topic at the end.
But the entire post is used for the banner, so if you want to edit the post, you need to remove the original content, which is not what is intended. Unless there is some marker to separate the banner from the rest of the post?
J’ai donc finalement choisi une stratégie différente pour les bannières que vous pourriez vouloir appliquer à votre forum :
Créez un nouveau sujet dédié à l’hébergement de la bannière. Il peut se trouver dans n’importe quelle catégorie. Je préfère généralement utiliser Staff.
Étiquetez le sujet avec #banner, afin de pouvoir les retrouver plus tard.
Créez soit un court message, soit, comme je le fais habituellement, une image avec une taille de pixel de 627x123 (de cette façon, les barres de défilement ne seront pas déclenchées et elle apparaîtra « propre » dans la plupart des situations) ; et utilisez cette image comme ancre pour un lien vers le sujet ou le lien que vous souhaitez mettre en évidence, par exemple :
