Try to solve the problem with file migration to s3. The first thing is that the command returns
GlobalSetting.use_s3?
false
And now the question. If loading new images works (i.e. S3 is set well) then what causes this error (I want to transfer existing images with DRY_RUN=1 rake uploads:migrate_to_s3) ?
Should I set something apart from the settings in the admin panel
I tried to edit discourse.conf like this:
If I am not mistaken, you cannot change global settings from the rails console; but you can change site settings from the console:
Basice example changing site setting:
pry(main)> SiteSetting.site_description
=> "My Cool Site"
pry(main)> SiteSetting.site_description = "My Great Discourse Site"
=> "My Great Discourse Site"
A specific example, comparing global settings with site settings:
pry(main)> GlobalSetting.force_https
=> true
pry(main)> SiteSetting.force_https = false
false
=> false
pry(main)> SiteSetting.force_https = true
=> true
=> true
pry(main)> GlobalSetting.force_https = false
NoMethodError: undefined method `force_https=' for GlobalSetting:Class
Did you mean? force_https
from (pry):61:in `__pry__'
pry(main)> GlobalSetting.force_https = true
from (pry):62:in `__pry__'
When I did this type of testing from the rails console, it led me to believe that global settings cannot be changed in the application after the application is build; however site settings can be changed in the app after it is build and running.
For example, the developer email addresses are set in the container yml file, and this value cannot be changed in the app, which adds a layer of security to the site.
In some cases, we see that a global setting is assigned to a site setting, and then the site setting is used in the app and so it can be changed; however, when the global setting is used in the app, this value cannot be changed (or so it seems during testing).
This appears, based on my limited testing, to be one of the fundamental differences between global settings and site settings.
So, I think this is the underlying reason when @eextra tried to set GlobalSetting.use_s3? true, they found it did not work as expected:
pry(main)> GlobalSetting.use_s3?
=> false
pry(main)> GlobalSetting.use_s3 = true
NoMethodError: undefined method `use_s3=' for GlobalSetting:Class
Did you mean? use_s3?
from (pry):8:in `__pry__'
